Nitrous Oxide Too soon, jr.
Dynotune Air/Fuel Ratio Lean Shut-Down Switch Review
Old Sep 10, 2008 | 01:49 PM
BakaN20's Avatar
BakaN20
Default Dynotune Air/Fuel Ratio Lean Shut-Down Switch Review
Today we are going to take a look at the Dynotune Nitrous Air/Fuel Ratio Lean Shut-Down Switch. I ordered the unit on a Friday and it arrived on a Monday. It was shipped 2 day delivery. From the looks of it, it also had signature conformation and tracking. So rest assured, your package is well taken care of by USPS and will arrive in a timely manner.
Reading through the nitrous forums on my350z, I haven’t noticed too many people running this unit. So this will be a learning experience for me and for all. In fact, the only information about this unit I have found is here:
https://my350z.com/forum/nitrous-oxi...ow-switch.html
Here is a little information off of Dynotune’s website:
This tiny stand alone device(you need nothing else to make it work other than your factory o2 sensor or wideband controller) is a Microprocessor controlled Air/Fuel ratio Lean shut-down switch that will shut off the nitrous system if it goes lean during a Nitrous run and best of all, It works with your existing OEM oxygen sensor! (0-1v oxygen sensors)(or 0-5v wideband controllers).
Checkout all these features:
--Microprocessor controlled
--Built in Air/ fuel ratio display(narrow and wideband)
--Built in TPS (WOT) Switch
--Peak and Min A/F memory during the run
--Multiple outputs 12V and Ground
--Multiple Trigger inputs 12V and ground
--Programmable trip points
--Adjustable delay to let lean spikes settle
--6 Foot wire harness Light Weight
--12 Volt Operation
--Fast response
--Super Low Current
--Draw Micro Package Mounts Anywhere 1.8" Wide x 2.4" Tall x .9" Deep
There are some very important things to consider when buying this unit. As stated on their website:
It's the purchasers job to ensure their factory oxygen sensor is a 0-1V style, standard o2 sensor. This will not work with factory wideband sensors found in some new cars.
Some might not know, but the 03-04.5 350z/g35 still use a narrowband, so those output a 0-1v style, so they are compatible with this unit. 350z/g35s that are model 04.5 and up use a factory style wideband. From researching, the output is 0-2v style. So I am unsure if it will be compatible with this unit. I am still researching and talking with members who have far more knowledge than I do. If anyone has input on this, that would be great. Here are some of the threads that I have found my information from:
https://my350z.com/forum/engine-driv...2-sensors.html
https://my350z.com/forum/intake-exha...-question.html
https://my350z.com/forum/tuning/2213...deband-o2.html
https://my350z.com/forum/forced-indu...deband-o2.html
The main feature we will be talking about is the A/F lean shutdown. This unit also has the ability to also be a Wide Open Electronic TPS (Throttle Position Switch). Since most of the people who buy this probably bought this for safety, you are already probably running the 2 stage tps with window switch. So we will only talk about the A/F lean shutdown feature unless anyone really has anything to ask about it.
So let us continue. The unit came in a standard USPS shipping box, nothing out of the ordinary.
The unit is packaged well. Lots of bubble wrap, no worries about it being crushed or broken during transportation.
You have the option to add an additional warning LED from Dynotune. What this does is that if a lean condition occurs, the LED turns on to inform you that the switch has activated and shutdown your relay controlling your solenoids to avoid a catastrophic lean condition. The LED is adequate during daytime if it is right in front of you. You would drill a 5/16th hole and just plug the LED in and wire it up. I would probably add another LED and put it right in front of me so I would have an additional light just in case I don’t see the one LED or if it just happen to be really bright that day.
Now onto the packing of the unit. The package is sealed just like all other Dynotune products.
The switch is made of hard plastic to ensure that it can withstand rough handling. This unit seems to be meant to be kept inside the cabin to be monitored. I have seen other people put their 2 stage window switch in the engine bay, but the 2 stage seems to be made of much sturdier material, metal material, while this is made of hard plastic.
The switch is about the width and depth of a cigarette box.
It’s about the same height as a cigarette box.
If you cut the top off of the top of the cigarette box, you will have a pretty accurate size of the unit.
This comes with 2 Velcro tape so the unit can be removed and attached to your desired location.
It also comes with printed instructions.
If you happen to lose your instructions, you can get them here on Dynotunes website:
http://www.dynotunenitrous.com/store...structions.asp
The cable is about a total of 6 foot long
Part of the wires is also spiral loomed so that it will look good if you happen to have to move the unit and wires is exposed. It’s about 13 and half inches long.
Actual installation will be continued. If anyone has any comments or questions, please post it. I am hoping to get this to work, I think this unit can be a great safety device for anyone using nitrous.
Old Sep 10, 2008 | 01:54 PM
Sean's Avatar
Sean
will you force yourself lean to see if it does it's job?
(and give up smoking)
Old Sep 10, 2008 | 02:31 PM
BakaN20's Avatar
BakaN20
I won't force myself lean, I will test the shot, see what a/f or voltage the switch is at with nitrous, then go 2 steps or so under that to see if it cuts it off. Or i might see what the a/f is at 4500 and set the switch to cut off at that a/f. The only thing is, I am not sure if the switch will work with our factory widebands. I am talking with some knowledgeable members to find out if the factory widebands will work with the way this unit reads. Also, those are my step dads, I don't smoke, it just happen that it was the best comparison for size, lol.
Old Sep 10, 2008 | 04:05 PM
silver350tn's Avatar
silver350tn
does it read the a/f also? very interesting does it have another 02 sensor? or does it tie off an existing one? i am really thinking about getting one
Old Sep 10, 2008 | 04:10 PM
jfptbird's Avatar
jfptbird
Just wondering, how will this work with dynotune's window switch?
Old Sep 10, 2008 | 04:51 PM
BakaN20's Avatar
BakaN20
It can read a/f off of an aftermarket wideband that outputs 0-5v such as an innovative and will display as an a/f ratio. The purple wire off of the unit connects to the aftermarket unit. It does not have an 02 sensor. If you are a pre-04.5, you have a narrow band, and this unit can read 0-1v, but it will be displayed in voltage and not in a/f ratio.
Jfptbird, this unit will tap into the ground on the dynotune window switch, when the ground is activated, the a/f switch gets the signal that the nitrous has been activated, the purple wire then starts reading a/f ratio for wideband or voltage for narrowband. The yellow wire off of the a/f switch goes to pin 86 on the relay. In a normal configuration, the white wire on the 2 stage window switch just taps into a 12v acc, but with the a/f switch, the switch connects to the white wire directly and no longer goes to the relay, the yellow wire now goes to the relay. I'll try to draw a picture to make it easier if my explination is not that good.
Old Sep 10, 2008 | 04:56 PM
RobbieG35's Avatar
RobbieG35
Looking good, I am waiting for the install . . so you can do some of the work for me, haha.
Old Sep 10, 2008 | 05:24 PM
BakaN20's Avatar
BakaN20
It should be easy if you have the 2 stage window switch already. It only needs 5 wires if you are not installing the LED. Ground, power, signal from 2 stage, yellow wire to pin 86, then purple wire to wideband/o2 sensor. I'll try to do the 4 when I get a chance. The purple one I will not do until I get a solid answer if this unit can read our factory wideband. From my research, its not looking too good for the 04.5 and up, but there are ways to get it, there is the expensive way and the cheap way, and i will post both ways when I get a chance.
Old Sep 10, 2008 | 07:44 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Nice. Looking forward to more information.
Old Sep 11, 2008 | 05:21 PM
BakaN20's Avatar
BakaN20
So let’s get a basic start with the installation. As with any electronic item, you need power and ground. We will install as if you have the 2 stage window switch, since that is what the majority of the people here will have. I know a lot of guys here will run a zex kit also, and if anyone has questions about that, we can cross that bridge when we get there.
The red wire coming off the unit is power and the black is ground.
I tapped into the cigarette lighter with a wire and then tapped into the wire. You can get power from it in many different ways. You can solder, which is the best way possible, or you can use taps. These are the two best methods, you can probably tie the wires together and tape it, but that’s never a good option. The two types of taps are inline taps that is semi permanent or quick disconnect.
Semi permanent
Quick Disconnect
Both of them
You can tap into any 12v keyed accessory such as the radio or fuse block also.
As for the ground, I will ground at the shifter base, where I ground all of my wires. I have read this area is very sensitive to grounding, but it has worked fine for me. If you are **** about it, you can always do a continuity check; it should read close to 0v I believe. If that is incorrect, please correct me, I do not want to put out false information.
I know my shifter cover is jacked up, my dog messed it up, I’ll replace it, at least that’s what I tell myself.
This is where I ground all my wires.
The purple wire will connect to either your factory narrowband or aftermarket wideband
This green wire will ground the warning LED. The power can be tapped from the red wire off of the switch if you extend it or any other 12v.
These are the two wires that will connect to the relay. One is blue and the other is a yellow wire. Be careful, there is a yellow wire with white stripe, make sure you can tell the difference of which one you are using. The blue wire will tap off of the yellow wire of the two stage window switch; verify that it is pin 85 off of the relay. The yellow wire will replace the white wire off of your 2 stage window switch that was going to the relay, so you can hook the yellow wire directly into the relay, ensure that you are hooking it up to pin 86.
This is where I will be mounting the unit, since I can un mount it and mount it to the vent for easy view via cell phone holder. The reason I choose this spot is it is discrete yet still easily accessible.
More pictures will be added to supplement the other pictures when I have a chance.
Old Aug 12, 2009 | 12:06 PM
mgrotel's Avatar
mgrotel
ahhhh! update?
Old Aug 12, 2009 | 08:02 PM
BakaN20's Avatar
BakaN20
Sorry, i've been deployed for the past year and haven't been able to do any updates on this. On ls1tech though, it has very positive reviews. The only thing i wish it had was a too rich shutdown feature, easy enough to do so i wonder why they didn't. I haven't found a solution to that yet.
Old Aug 12, 2009 | 08:50 PM
mgrotel's Avatar
mgrotel
thanks man! but you were able to get it to work with the stock o2 for the 04+ year models? btw, no need to apologize!
Old Aug 12, 2009 | 11:33 PM
BakaN20's Avatar
BakaN20
If you have an +04.5, it will not work since everything afterwards uses a semi-wideband. The voltage rating is from 0-2v. The previous model years use a narrow band, which this unit can work with based off of voltage. So you if you have a 04 and below, this unit can work on narrow band mode. If you have an +04.5, you will have to either buy a wideband or buy a narrow band, but wideband is much better. If you have any other questions, I will try to answer to the best of my ability.
Old Aug 13, 2009 | 05:49 AM
mgrotel's Avatar
mgrotel
that answered my question perfectly, thanks for the review
Old Aug 16, 2009 | 11:54 PM
BakaN20's Avatar
BakaN20
As great a unit as the dynotune products are, I am actually looking into replacing my 2 stage tps/window switch and the a/f lean shut-down switch with a MicroEDGE unit. It combines the features of both units, but adds 3 programable memory, and rich shut down switch. If the dynotune had lean and rich shutdown, i would not look to upgrade, but I am trying to make the safest nitrous setup possible. Look forward to a new thread about it next month! In fact, look for a couple interesting threads from me next month, I have ordered a decent amount of things to compliment my nitrous, can't wait to get home from Iraq!
Old Aug 17, 2009 | 06:00 PM
mgrotel's Avatar
mgrotel
^what are the physical dimensions on that thing? i couldnt find them anywhere...
Old Aug 17, 2009 | 08:21 PM
BakaN20's Avatar
BakaN20
I believe it is 2"x5", I am trying to find the dimensions of the dynotune 2 stage tps/window switch for comparison, I can't exactly measure mine right now, but I can't find it so far.
Old Sep 15, 2009 | 08:07 PM
BakaN20's Avatar
BakaN20
Here are some pictures of how I mounted it. It was mounted with velcro.
Its nothing too stealthy or anything, but that was the best spot i was able to put. This unit will be for sale soon
Old Sep 15, 2009 | 08:15 PM
3hree5ive0ero
Retired Admin
Did everything work as advertised without a hitch?
Why did you choose that location?
Why are you putting it up for sale and how much?
