Nitrous Oxide Too soon, jr.
uprev tune on nitrous?
Old Jan 18, 2009 | 01:58 PM
boostn's Avatar
boostn
Default uprev tune on nitrous?
I am about done getting my zex kit installed and i am running a 100 shot. Everyone says not only is it safer but you tend to get alittle more power out of the kit with a tune for it. So i was looking at getting an uprev dyno tune. But here is my debate, I dont have cruise control on my car so i will have to leave the nitrous tune in all the time. How bad will this hurt my na power and gas milage if at all.
One other thing. I have a cobb accessport (stage2 map loaded) on the care now and i wonder if it would be safe to run the shot on that untill i get the tune. I dont know how much timing it puts in the car. And I guess im getting rid of the accessport if anybody needs one.
Old Jan 19, 2009 | 05:17 PM
boostn's Avatar
boostn
im going to hinsen performance in bessemer alabama thursday to get an uprev dynotune.
Old Jan 19, 2009 | 05:55 PM
memphis350z's Avatar
memphis350z
i would think the tune on your cobb would be ok BUT if it advances your timing at all i would not spray with that map loaded. I spray a hundred shot on a factory ecu and its fine and stays within 11.0-11.7 air/fuel while spraying.
Old Jan 19, 2009 | 06:01 PM
twitch579's Avatar
twitch579
I have a Nitrous Map from Uprev for my 100 shot. The shot made the car run to lean and +5 fuel had to be added and also 3-4 degrees timing was pulled to be safe. They will probably only program in these settings while you in your N20 window, mine is from 3500-6000rpm, before or after that the car is running on my 93 performance map.
So if u can just drive out of the nitrous window then you wont be pouring in loads of fuel for nos thats not being sprayed>>??? Does that make sense?
My car probably runs to lean from all the boltons that I have also, before the tune without nos my car ran very very lean.
-chris
Old Jan 19, 2009 | 06:08 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
If you have a tune, it almost always means that your timing was advanced to extract a bit more power from the engine. Nitrous and advanced timing is very bad in conjunction. Therefore, it is highly recommended that you do not run nitrous on a N/A map; you should always have a separate map with retarded timing in the appropriate RPM range to maximize your gain from nitrous.
Old Jan 20, 2009 | 04:49 AM
boostn's Avatar
boostn
thanks for all the input guys. And being that I don't have cruise control that tune that is only in the nitrous window is an awsome idea. I am gonna get my tune exactly like that.
Old Jan 20, 2009 | 04:52 AM
boostn's Avatar
boostn
what kinds numbers did you guys put down on the dyno? I just kinds want a ball park estimate.
One other thing is do you think I should run a 100 or 75 shot?
The car just turned over 100,000 miles.
Old Jan 20, 2009 | 08:01 AM
3hree5ive0ero
Retired Admin
Why do everybody just jump straight into 75, 100, or even retardedly into 125 shot? How about you guys be smart and start with a 35 shot? I started out with a 35 shot, moved to 50, and now I'm at 75.
My recommendation: start with 35, especially since you have such high mileage. You should always see how the car responds to the sudden increase in torque. You should bump up to a higher shot if and only if the engine checks out fine, and you are competent/comfortable enough with the shot.
Old Jan 20, 2009 | 08:16 AM
Jay'Z's Avatar
Jay'Z
Get the 125 shot!!!!!
Old Jan 20, 2009 | 08:31 AM
k6750gsxr's Avatar
k6750gsxr
Lol. I agree everyone goes big. I suggest 50shot just to see how it runs. People tend to forget how much tq nitrous give you.
2ndchanceZ
Oct 26, 2015 08:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
