Nitrous Oxide Too soon, jr.
help! 2006 Z looking to spray...
Old Mar 18, 2010 | 06:24 PM
  #41
Barnabas's Avatar
Barnabas
National Z Club President
I would suggest getting at least test pipes as well...
you will foul those cats quick. And will also help free up air flow. And your in FL soo you can do it with no consequences
I have a set ill ship to you for 125 (AAM)
Old Mar 18, 2010 | 06:25 PM
  #42
Barnabas's Avatar
Barnabas
prob a plenum spacer as well you can get them for super cheap... I would rather wait a couple months to get this installed then to cut tooo many corners.
Old Mar 18, 2010 | 07:03 PM
  #43
MTZ33's Avatar
MTZ33
Originally Posted by mgrotel
you say just get a utec, wideband, and a/f guage?? you know how pricey those are in comparison to a meth inj kit? do you even know anything about meth injection?
how is he supposed to pull timing when he doesnt have a timing map to start with??? how much timing do you have pulled for that 100 shot?
i know alot about it, had meth inj in my 240.. u dnt need that 2 spray a Z... if that stuff is 2 expensive, then u shouldnt be modding ur car... n i have 3 degrees pulled... u NEED an a/f gauge...$200 insurance, better than blowing ur **** up...
Old Mar 19, 2010 | 09:50 AM
  #44
BakaN20's Avatar
BakaN20
Originally Posted by CamiloA98
I dont think that a 75 shot will be that bad. I've known the shop owner for a wile and they install nitrous all the time. If I went over a 100 shot I would then think about buy a wideband A/F. Im not trying to send too much money on this... If this project goes over $2000 I might as well go with a turbo kit, so my budget is 1000-1500. Im a college student, so I also need money for books!
$1500 would be A LOT to spend on a nitrous system. I haven't spent near $1500 and my nitrous system is probably a lot more intricate than yours. Shop around, there are a lot of places that are both reputable AND cheap. Places like dynotune, nitrous outlet, and so forth. You don't need to go with the big names to have reliability. Good luck with your setup and make sure you post some pictures when you are done.
Old Mar 19, 2010 | 05:51 PM
  #45
ironx's Avatar
ironx
i still get a Air/Fuel Ratio Lean Shut-Down Switch they are cheap like $150 it it shows you you a/f on the control it a cheap insurance like if you for get to look at your gauges and it suddenly goes awall to the lean side you are in big trouble at least with this this it would shut down you nitrous and save your motor id rather spend &150 on a safety catch than on a new motor which could run you over 3000+ its better to be safe i wont use my nitrous with out it i spent a total of 1800 on all my stuff here is the list
Dynotune Wet kit for the 03 to 06 350z
Nitrous filter
Bottle Warmer
Car & Truck Nitrous Oxide Purge system Kit
Covered Racing Switches
Arming racing Switch
Multi-Function Nitrous Controller Progressive, (RPM activated window switch (RPMWS) with an integrated throttle-position activation switch (TPAS))
Innovate wide band
ETC
MAsSIVrOOM
Oct 20, 2023 10:50 AM
3vilbunny
Jul 18, 2017 05:10 PM
reno56
Interior
17
Nov 20, 2015 05:21 PM
nissan1310
Oct 12, 2015 08:54 AM
