Nitrous Oxide Too soon, jr.
06 Base Nitrous in the works.
Old May 31, 2010 | 07:25 PM
UH60z's Avatar
UH60z
Default 06 Base Nitrous in the works.
I put on my old kit thats been sitting on the shelf. I ran the N20 line through the child anchor area (already has a hole in the metal), down behind the glove box then through the fuel access hole the up to the front. I plan on running a 100 shot with one step colder NGK plugs for now.
Attached Thumbnails 06 Base Nitrous in the works.-dscn0449.jpg   06 Base Nitrous in the works.-dscn0458.jpg   06 Base Nitrous in the works.-dscn0459.jpg
Old Jun 25, 2010 | 08:24 AM
lovie_350z's Avatar
lovie_350z
Did u drill thru the firewall to hold your solenoids there? Seems like a good place for the solenoids.
Old Jul 1, 2010 | 04:04 PM
UH60z's Avatar
UH60z
No there is a hole in a bracket on the motor. I just bolted my home made bracket to that.
Old Jul 19, 2010 | 08:17 PM
oneslowz's Avatar
oneslowz
how long of a line did you use?
Old Jan 15, 2011 | 06:18 AM
UH60z's Avatar
UH60z
Sorry so long to post, the line is 18ft if I remeber right. I have moved my bottle from the hatch to behind the driver seat. This makes room for my sub box and hides the bottle. Now just pita to turn it on. But o well.
I have a .30 fuel and .53 Nitrous jet. Tried it out @800 psi can tell its there! Now just have to get some tires so it will go some where. And btw still on stock plugs
350Z_Al
Oct 29, 2020 07:44 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
