Maximum shot of a zex 82220 kit
hey guys i'm new around here, i got a nissan fairlady Z 2004 (the japan version of the 350z).
i'm installing a zex kit 82220 and i want to shot more than 100 shot
(like 120). Is it possible that i only buy bigger jest or should i also buy bigger solenoids? because the manual tells maximum of the kit is 100 shot.
I did alot of searching on the forum. You have to decide on what size shot u want to run. 150 at the wheels or at the crank. Zex measures at the crank. NOS brand measures at the wheels. The 350Z has 51psi base fuel pressure (higher than most cars). I used a calculator i found. I have not dynoed yet to see where my AF ratio is at yet. I run .057 and .033, which is about a 145hp shot
CLyons0203, what are you using to pull timing to -4?
Also, regardless of what's recommended as jet sizes, I suggest you check the AFR just in case.
