Nitrous Oxide Too soon, jr.
Nitrous install on 05 FX35 AWD questions
Old Jan 27, 2011 | 03:28 PM
TheGreatBear's Avatar
TheGreatBear
Start a 3.5K; there's no need to go lower and it only increases the chance of you breaking things.
Plenum spacer is different than a throttle body spacer. You tap between your MAF and TB, usually less than 12" away from the TB.
Tune with whatever you can afford and whatever your tuner is comfortable with. UTEC, UpRev, Cobb, E-Manage are all within your budget.
Again, N/A tunes and nitrous don't mix, so ditch the TS reflash and get something else for N/A and nitrous tunes. If I have to explain this any further, then you shouldn't be messing with nitrous.
Dyno numbers don't mean jack. Dynos are tools for tuning and getting a relatively percentage increase/decrease. They're not accurate measuring tools. My nitrous numbers are all messed up for multiple reasons, so ignore them.
Man I enjoy your attitude, right to the point haha
I know the difference between a plenum spacer and a TBS...I have both and installed them both.. The ztube sounds like a good place to tap then.
Im waiting on VinnyTen to call me back about tuning possibilities, since they have an AWD dyno now so can tune me. You dont really need to explain the tuning much further, lol I understand: I will need to switch between the two maps. I am not talking about your numbers per say just the general increase.
Thanks for the help, I'll continue my research and wait on Vinny Ten to get back to me with tuning info.
Old Jan 27, 2011 | 04:04 PM
TheGreatBear
p.s. does anybody know how to flip the order of the posts in the thread? for me they read newest first, then my OP is on page two as the last post.... basically the post #s are in reverse...its annoying to read haha
Old Jan 27, 2011 | 05:18 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I used to be pretty verbose with explaining every aspect, but I try to keep things pithy nowadays to allow the user to research on their own for in depth answers.
I actually was very blunt and even flamed you a bit in my original post (The one you quoted), but I edited it to soften it up for you.
Follow the below instructions:
User CP -> Edit Options -> find "Thread Display Mode" and change setting to "Linear - Oldest First"
Problem solved.
Old Jan 27, 2011 | 10:46 PM
TheGreatBear
Problem solved.
Haha no problem man, I can take the flames if its for a respectable reason.....
Ill go to my settings, thanks.
Old Jan 27, 2011 | 11:10 PM
03threefiftyz's Avatar
03threefiftyz
There is too much in here for me to pick through....so I will simply address the auto w/ nitrous question. The AWD will obviously put a greater stress on parts, but the auto in the z is fairly robust. User ajcool2 runs a 100 shot through his bolt-on auto car. It comes out of the hole with AUTHORITY. Stock 5at with a stall. No VB upgrade.
I'll leave this here: Pulls low-mid 1.6 60' times on slicks. My belief is it will pull high 1.5's on a track with some heat in it. We'll see.
http://www.youtube.com/watch?v=S6ZWudeW6tE
Old Jan 28, 2011 | 01:26 PM
hellsoldiers08's Avatar
hellsoldiers08
lol what was his time?
Old Jan 28, 2011 | 03:55 PM
03threefiftyz
12.0 I believe. Still not tuned yet either.
Old Jan 28, 2011 | 06:09 PM
NissanZ03's Avatar
NissanZ03
12 flat with no tune? That's really good. I'm guessing he has all the normal bolt-ons (exhaust, TPS, headers, intake, spacer, etc...). But still, 12 flat is pretty nasty. Especially since you can pick up a nitrous kit with everything you need + a tune for around $1k
Old Jan 28, 2011 | 10:25 PM
hellsoldiers08
i thought it wasnt a good idea to do more than a 25 or 50 shot untune...
Old Jan 29, 2011 | 07:09 AM
03threefiftyz
I think he just has a spacer, tp's, and exhaust.....plus the giggle gas.
Old Jan 29, 2011 | 08:37 AM
TheGreatBear
Nice, too bad my car is 1200 lbs heavier with AWD.....
exactly...I spent 10 times that on my stupid bolt ons anyway
Thats good to know, with my luck mine will blow up during the dyno tuning haha
Old Jan 29, 2011 | 08:56 AM
drivessidewayz's Avatar
drivessidewayz
3hree5ive0ero basically says it all.
While I have no experience with other setups, I can say Dynotune is a really nice company to deal with regarding customer service. I've had no issues with their products either.
Just remember lower engagement means more stress on the drivetrain. I'm having my re-tuned this Spring to start at 4k instead of 3.5.
Old Feb 2, 2011 | 10:23 AM
TheGreatBear
makes sense.
i was talking to Performance Motorsport in NY, who has Uprev tuning capabilities and mentioned n20 to them. They do nitrous builds, and us NXpress so maybe Ill have them do the build, make a map for nitrous and a map for "normal" driving....
Old Feb 2, 2011 | 10:26 AM
NissanZ03's Avatar
NissanZ03
makes sense.
I've heard good things about that place. So they give you the nitrous kit, they install it, and they tune it? How much does all that go for?
Old Feb 4, 2011 | 11:28 AM
TheGreatBear
well its $600 for a dyno-tune ECU with Uprev, and I think they can do a map for n20 with that, and the kit installed with everything i need NX is about 1200
Old Feb 4, 2011 | 06:17 PM
NissanZ03's Avatar
NissanZ03
So around $1800 for everything? Not terrible
Old Feb 18, 2011 | 08:51 PM
StuLax18's Avatar
StuLax18
General & Tech Moderator
Listen to 3hree5ive0ero. He knows his stuff.
Workshop12
Mar 23, 2020 01:45 PM
RiujinZero
Sep 25, 2015 01:19 PM
Suffolk350z
Sep 13, 2015 02:43 PM
