Nitrous Oxide Too soon, jr.
Hidden Nitrous
Old Apr 9, 2011 | 06:07 PM
wird06's Avatar
wird06
Default Hidden Nitrous
Well Im about to get a ZEX kit shortly and I really want to hide the kit. Well the one thing that give hidden kits away is where the nitrous jet is install. So I was thinking, what if i get a throttle body spacer and tape the jet into the bottom of the spacer to hide it. Well my only concern is that being so close to the plenum would it cause the nitrous more of the nitrous to the closer cyls that are near the tb? I know I have seen ppl use this idea for meth injection but the system is pressurized. What are your opinions on this?
Old Apr 9, 2011 | 06:10 PM
JPsZ's Avatar
JPsZ
I'm about to post a thread tomorrow showing my kit. I've been lagging on these pics for a while, and everything is fairly hidden. Keep an eye out for my thread.
Old Apr 9, 2011 | 06:42 PM
wird06's Avatar
wird06
Did you do the thing with the throttle body spacer like I am talking about?
Old Apr 9, 2011 | 07:11 PM
JPsZ's Avatar
JPsZ
No I mounted it under the intake pipe. It's pretty stealth, you'd have to be looking for it to find it. The only thing that would worry me with a throttle body spacer setup is the fact that you'd be spraying close to the bend on the intake manifold.
Old Apr 9, 2011 | 08:04 PM
R350Zz33's Avatar
R350Zz33
mount it on the bottom of the intake
Old Apr 10, 2011 | 05:36 AM
drivessidewayz's Avatar
drivessidewayz
^^ about 6 inches (I believe) from the TB and on the bottom. Just cover it up with wire loom or something like that.
Old Apr 10, 2011 | 06:06 PM
JPsZ's Avatar
JPsZ
posted my install.. check it out
https://my350z.com/forum/nitrous-oxi...s-install.html
Old Apr 10, 2011 | 06:32 PM
k6750gsxr's Avatar
k6750gsxr
^^^^^ this was a clean install. Great write up. Perfect example of a nice diy
Old Apr 10, 2011 | 08:39 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Just think about it: the nitrous is at ~1000psi so when it's released, it'll shoot pretty much straight. The TB spacer doesn't allow enough room for the nitrous/fuel mixture to mix with the air and will probably end up on the plenum neck wall.
You could argue and say you'd point the nozzle so it clears the plenum wall, but then you run into the problem of spraying into the passenger bank more.
In short, stick to tapping the intake tube to mount your nozzle, imho.
BTW, this has been discussed a few times in other threads.
Z CRAZY
Dec 17, 2024 11:02 AM
Miguel Albanez
Oct 17, 2022 10:13 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Ricky
Apr 22, 2003 11:35 AM
