Nitrous Oxide Too soon, jr.
Clean Hidden Install
Old Oct 16, 2011 | 03:10 PM
winger492's Avatar
winger492
Default Clean Hidden Install
Being inspired by JPsZ and his install: https://my350z.com/forum/nitrous-oxi...s-install.html I decided to go with something similar and hidden. It's an NX kit with some Dynotune accessories and gauges that I picked up for cheap in the Market Place. It's only a 75 shot for now until I get the jets from NX for a 100 shot and then I'll tune it. It has everything including remote bottle opener, bottle heater, purge kit, and it runs on an MSD with an RPM window and afr cutoff like the microedge. Everything bought and done with a custom install ran me about $1200. The lines run through openings in the frame rails so nothing can be punctured.
Onto the pictures:
Mounted behind the drivers seat where the Sub usually goes:
If you look behind the bottle you can see the MSD mounted:
Custom mount for the gauges to match my PPW:
No lines in the engine compartment!:
Solenoids mounted in the brake fluid compartment:
And a short video of the purge that shoots out in between the hood and windshield:
BIG thanks goes out to Curtis and Hasan at Motion Motorsports for doing an amazing job with the install!
Old Oct 16, 2011 | 03:25 PM
iceman09's Avatar
iceman09
Looks great man, only thing I'd say is that the bottle brackets should be switched so that the pickup tube will be able to pick up the nitrous when the bottle is starting to get empty or under heavy acceleration.
Old Oct 16, 2011 | 03:28 PM
winger492's Avatar
winger492
It looks odd in the picture but we installed the brackets backwards of to how you would have them if they were bolted to the floor rather than hanging like they are now. Gives it the right angle like the bottle should be in. Good looking out though and thanks for the compliment!
Old Oct 16, 2011 | 08:35 PM
TreeFiddyGee's Avatar
TreeFiddyGee
Awesome!
Old Oct 16, 2011 | 08:38 PM
kemps's Avatar
kemps
Pretty clean install!
_bit
Oct 2, 2015 07:49 AM
nanotech
Oct 2, 2015 05:02 AM
