Nitrous Oxide Too soon, jr.
Where do I install the Nitrous Nozzle?
Old Oct 17, 2011 | 04:18 AM
tuckerst85's Avatar
tuckerst85
Default Where do I install the Nitrous Nozzle?
Hi everyone, looking for some help with my nitrous express wet kit. I've looked through a ton of threads and can't find my answer, so I had to make a new post.
I am trying to install the nitrous express piranha nozzle on my air intake tube. Problem is that I don't know where I am supposed to put it. There is a PCV hose connected under the air intake.
Do I put the nozzle in between the PCV hose and throttle body? Or do I put the nozzle in between the MAF sensor and PCV hose?
The instructions say to put the nozzle 2-6 inches from the throttle body.
Also my second question is how do I install the nitrous nozzle in my aluminum air intake pipe (Nismo R-tune CAI)? There has to be a better way then just drilling a hole and shoving it in there, if I did that over time it would turn slightly as the engine shakes and then the nozzle wouldn't be facing towards the throttle body.
Thank you for the help.
p.s.
if I didn't search prior threads thoroughly enough and this has already been answered, please post the link so I can read that thread. Thanks
Old Oct 17, 2011 | 04:35 AM
2bad240's Avatar
2bad240
Here is a pic of mine. You can see it. I have a nos nozzle. And I drilled a hole in it. And have a piece that the nozzle threads into.
Old Oct 17, 2011 | 04:46 AM
2bad240's Avatar
2bad240
Google. Nitrous nozzle nut
Old Oct 17, 2011 | 06:00 AM
tylerxfire's Avatar
tylerxfire
u dont just drill it and throw it in there..has to be threaded in...i think with the questions i have read from u op u should seek professional help and pay the extra bucks to have it done correctly..
Old Oct 17, 2011 | 07:21 AM
tuckerst85's Avatar
tuckerst85
@ 2bad240, thank you, I will contact NX for the nozzle nut. For some reason that didn't come with my kit.
@ tylerxfire, I already have everything installed except the N20 and fuel lines to the nitrous nozzle because I didn't know how to properly install the nozzle into the air intake tube.
Old Oct 17, 2011 | 08:09 AM
tylerxfire's Avatar
tylerxfire
^^^^^lmfao..op is so butt hurt out of my nice reply he had to pm me..cant wait to see how bad he cries over a tough reply from someone, i gave good advice this time..lol..op will cry his way out of this forum in 3....2....1....must make this a sig now i guess....
Originally Posted by tuckerst85
Did I offend you in a previous life? Not sure why you are commenting on my thread disgruntled. I was looking for some extra help. I'm not an expert of course, but with guidance I can learn competency in a lot of things with cars. Thanks
Old Oct 17, 2011 | 08:40 AM
350Zenophile's Avatar
350Zenophile
When you tell someone they "should seek professional help" that could easily be misconstrued to mean they need psychiatric evaluation and/or meds because they are a crazy person. Maybe that's what he thought you meant?
Old Oct 17, 2011 | 08:43 AM
tylerxfire's Avatar
tylerxfire
lol..maybe..either way dont see him lasting long here if hes upset over something like that even if he took it the wrong way and felt the need to pm me and cry about it.. op if ur looking for advice take it dont give **** back if its not the advice you wanted to hear
Old Oct 17, 2011 | 10:50 AM
tuckerst85's Avatar
tuckerst85
I called nitrous express and they told me that for my piranha nitrous nozzle there isn't a nozzle nut. They suggested to not tap into the aluminum intake tube, but to just tap into the plastic coupler right next to the throttle body. They said in this set up for a 350z it wouldn't matter if it's too close to the throttle body. The guy even went on to say that he's had people drill right into the throttle body and insert the nozzle there and spray right into the intake manifold with no problems.
Any thoughts on this?
@tylerxfire, I'm sure yours will be great
Old Oct 17, 2011 | 10:58 AM
tylerxfire's Avatar
tylerxfire
ill give u this and its just my thoughts...i would not tap into the throttle body just because it will be much easier to remove down the road it if its tapped into the intake or coupler as u stated..I would not put it into the flexible plastic coupler for that reason i wouldnt want it to flex. I would absolutely tap into the aliminum intake tube.
Old Oct 17, 2011 | 11:51 AM
2bad240's Avatar
2bad240
I personally would order a nozzle and a nozzle nut and put it in my tube.
Old Oct 17, 2011 | 11:53 AM
tylerxfire's Avatar
tylerxfire
^^def, thats the only way ive ran it in the past......
not something to play around with and have the nozzle turn and spray wrong and puddle up or something...
Old Oct 17, 2011 | 12:23 PM
tuckerst85's Avatar
tuckerst85
Okay, thanks for the help. I will order a nitrous nozzle nut from a different vendor, since NX told me they don't make one for my size nozzle. Then I will install it in the air intake tube.
Old Oct 17, 2011 | 05:38 PM
CTZ860's Avatar
CTZ860
Ive seen some use a throttle body spacer to tap their lines into. However, i think that most mfg. say to place nozzle like 6-8 inch away from the TB?.....
On another note....which angle should the nozzle be facing in the intake....directly at the throttle body? Was readin today bout some ppl having it pointing wrong way and that can cause pooling.....
Old Oct 17, 2011 | 06:08 PM
Italianjoe1's Avatar
Italianjoe1
I've used TB spacers on other apps and on my Z and they work great, have the added advantage of not having to drill into any part of the car. I'm using my stock intakes, so the spacers give me a place to put the nozzles that I wouldn't have otherwise.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
