Nitrous Oxide Too soon, jr.
Best way to install Fuel Pressure Gauge?
Old May 5, 2008 | 03:06 PM
tnk210's Avatar
tnk210
Default Best way to install Fuel Pressure Gauge?
In searching I see most FI or NA people will use the AAM/Dynotune fuel adapter when installing a fuel pressure gauge. How do the nitrous people do it? Is there an alternative to having to cut the line and install a t-fitting?
Old May 5, 2008 | 06:42 PM
BabyZiLLa's Avatar
BabyZiLLa
Same way.. Get a Fuel Tap from Dynotune and put it on the drivers side fuel rail. Plug your pressure sender into that. Done.
I have a fuel tap on the passenger side for the fuel solenoid. Then I have another one on the drivers side with a T Adaptor for my fuel pressure cut off switch and my fuel pressure guage.
Old May 5, 2008 | 06:43 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
http://www.dynotunenitrous.com/store...?idproduct=245
^That's what people use to tap into the fuel line for nitrous.
edit - BabyZilla got to it before I did.
Old May 5, 2008 | 06:49 PM
tnk210's Avatar
tnk210
I had no clue there was one for each side. Thanks.
Old Aug 12, 2011 | 11:50 AM
nathanwl2004's Avatar
nathanwl2004
Is this necessary if you have a return fuel system like the CJM that already has a fuel gauge. Could you run a regular fp gauge off the port that the fuel guage that came with the system is supposed to operate from?
Old Aug 12, 2011 | 01:56 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
assuming you mean an electronic gauge, just need to install the sensor inline so it will see the pressure, from there it converts the pressure to an electronic signal to a pressure reading inside the cabin
Old Aug 12, 2011 | 07:32 PM
nathanwl2004
just to make sure that I am clear, I will still need to buy a dynotune/aam fuel line tap to install the guage right?
thanks for the help.
Old Aug 13, 2011 | 03:27 AM
Z1 Performance
Former Sponsor
You need some place to install the sensor
Which fuel setup are you running? Which gauge are you considering?
Old Aug 13, 2011 | 12:14 PM
nathanwl2004
don't have any of the parts right this second because I'm trying to sort out what exactly I will need in advance before I start buying.
however I will probably be going with the CJM stage 0 return fuel arrangement, and probably all prosport evo digital guages.
Old Aug 13, 2011 | 01:25 PM
Z1 Performance
Former Sponsor
you would need to look at that gauge, I am not at all familiar with that brand sorry
Old Aug 16, 2011 | 07:36 PM
nathanwl2004
thats cool thanks for the help.
Old Sep 27, 2011 | 10:06 PM
CTZ860's Avatar
CTZ860
Lil bump....
Do you guys see any difference in analog vs digital guages as far as accuracy?
Old Sep 27, 2011 | 10:13 PM
3hree5ive0ero
Retired Admin
I would think that accuracy is dependent on the calibration and quality of the gauge. As for you reading the exact pressure, analog can only give the reader an approximate reading as the viewing angle will change how you read the needle even if it's the same position. With digital, what it outputs is what you read so no user "error" but your resolution is limited to the set increment.
Old Oct 30, 2011 | 07:16 PM
nathanwl2004
update: the evo guages have a massive fuel pressure sensor, but it mounted up quite nicely to the port on the CJM retun system where the analog pressure guage would normally reside.
can't speak as to the accuracy just yet because the car hasn't been run as of yet. hopefully tuesday (for the first time in 6 months).
