Nitrous Oxide Too soon, jr.
direct port idea
Old 04-20-2012, 07:00 PM
  #81
mgrotel
mgrotel's Avatar
yea, should be fine
Old 04-23-2012, 06:31 PM
  #82
wird06
wird06's Avatar
With their track prep you would get better tracking on the hwy in the middle of a oil tanker spill.
Old 05-02-2012, 11:09 AM
  #83
mgrotel
mgrotel's Avatar
yup, i copied you...
Old 05-02-2012, 01:37 PM
  #84
2bad240
2bad240's Avatar
nice. good to see other people experimenting too. im excited to see progress with it.
Old 05-02-2012, 01:56 PM
  #85
mgrotel
mgrotel's Avatar
so you got 410hp on a 150 shot, right?
what other mods do you have?
are you built?
cams?
etc?
Old 05-02-2012, 02:13 PM
  #86
2bad240
2bad240's Avatar
are you built?
cams?
etc?
yea 410/470 on 150 with the bottle psi at 1150. but we tuned it with the psi at 950 and it made 396/441
megan longtube headers
aam 3" y pipe
3" single exhaust off evo X modified to fit
walbro 255 fuel pump
revup lower plenum extremely shaved
kinetix upper plenum
ported throttle body
550cc injectors off ebay
1 step colder plugs
stock flywheel f1 racing stage 3 clutch
takeda intake with 4" filter
uprev osiris
thats really it as far as power mods. its the stock engine that was in the car when i got it. stock cams and everything. i have never had the valve covers off.
Old 05-02-2012, 02:34 PM
  #87
mgrotel
mgrotel's Avatar
sweet, so i should be able to hit 450 with a 180 shot, considering i have cams and other stuff. the only parts that are holding me back is the auto transmission with more drivetrain loss and the fact that i am at 4500ft elevation. thanks for the inspiration
Old 05-02-2012, 02:45 PM
  #88
2bad240
2bad240's Avatar
yea i would think you probably could. if i wanted to run the psi up some more and pay for more tuning i could probably have made a lil more power but i was scared with the torque so high of compressing a rod or breaking something. i was tempted to hit my second dry stage since its still on the car and try to hit 500 ft/lbs but like i said i was scared of breaking stuff and i was on pump gas.
Old 05-02-2012, 02:50 PM
  #89
mgrotel
mgrotel's Avatar
i know a guy on a wet 150 and his piston failed before the rod. blew a ring land. anyway, good numbers, that torque must feel good!
Old 05-12-2012, 01:27 AM
  #90
juicinjake
juicinjake's Avatar
2bad- what gears and tire size?
Old 05-12-2012, 06:42 AM
  #91
2bad240
2bad240's Avatar
Stock gearing. 26" slicks
Old 05-12-2012, 08:21 PM
  #92
juicinjake
juicinjake's Avatar
whats your take on more gear and 28's on your setup?
Old 06-10-2012, 01:16 AM
  #93
juicinjake
juicinjake's Avatar
do you have any pics of this plumbed? i bought an extra set of lower runners and was wanting to start setting up a direct port lower. have you run it yet?
Old 06-10-2012, 07:21 AM
  #94
mgrotel
mgrotel's Avatar
Haven't run it yet, chasing a bank 1 cam phasing problem then need to get tuned
Old 06-10-2012, 01:47 PM
  #95
2bad240
2bad240's Avatar
i got mine back together but im getting a cel for cam over advanced. but it runs great.
Old 06-10-2012, 03:14 PM
  #96
mgrotel
mgrotel's Avatar
P0011? That's what I'm getting
Old 06-10-2012, 03:50 PM
  #97
2bad240
2bad240's Avatar
P0021 which is the same just bank 2. Mine was leaking around the solenoid /valve on the top on the head so i pulled it apart and cleaned that metal gasket and took solenoid apart and cleaned it all and put it back together and so far it has been good.
Old 02-23-2013, 10:07 PM
  #98
nova15566
nova15566's Avatar
anything else new in your setup? I rarely come on here but figured i'd add a bit... I know it is an old thread.
I am running a few setups depending on what I'm running for a car that day... I normally dd with a 55n/32f in a custom plate i made after the tb and a 28n dry premaf with fuel added in the map (5% as the maf wasn't keeping up). I am on osiris with a controller and lean saftey and hit at 3k-7200 and hit the dry at 4-4.5k to redline to make up for tq fall off.
I have yet to put it on a dyno with this jetting and current map. I norm run a -13-15 deg timing map (from my 32-34deg timing na map) with very aggressive cam phasing. My more aggressive map is -8-12deg off that map but I don't like it on winter gas.
I've been shooting for low to mid 400's on pump and mid to high on methanol and racegas.
The largest jetting i've run is a 62n/38f (a tad rich) and a 26n dry hit after 5.5k. This was on 105blend (torco mix and xylol +93) and was a very hard hit in my car... I don't like to run it that high but it does hold up and doesn't puddle as long as ur not launching on spray.
Dynotune and Nos silver foggers are the same btw the only diff is the inside diam of the fittings into the nozzle itself that are slightly larger on the dynotune.
I am in the process of testing a few map/meth/wet+dry out of sep bottles and noids/ and a plate I made out of a few nozzles I modded as well as a spray bar I am working on. The nos single and dual nozzle plate i made hits very hard compared to the pre tb nozzle.
Lets keep some nitrous info going... there are not a lot of us out there and the info is far and few between.
Old 02-24-2013, 04:45 PM
  #99
3hree5ive0ero
Retired Admin
3hree5ive0ero's Avatar
That all sounds very interesting. Would love to see some pictures and/or videos.
Old 02-24-2013, 08:29 PM
  #100
Scrildo
Scrildo's Avatar
Sweet Z i would love to see this car in person one of these days.
Quick Reply: direct port idea
