Nitrous Oxide Too soon, jr.
direct port idea
Old Dec 24, 2011 | 02:22 PM
2bad240's Avatar
2bad240
Default direct port idea
so i have been debating on doing a direct port setup on my car for awhile and i could do it the normal way and use 6 wet foggers or i had a friend come by and suggest using 6 dry nozzles and just add the extra fuel with tuning.
he said he had heard of some hondas using that setup.
any ideas on this setup on the Z? i used my spare engine on the stand and bolted the heads and lower collector on to use to mock up fogger fitment.
https://www.jegs.com/webapp/wcs/stor...rderItemUpdate
Old Dec 24, 2011 | 02:31 PM
denchan350gt's Avatar
denchan350gt
Why and is your car going to be strictly for drag? I take it you are shooting for 10's.
I don't know of anyone that has done a setup like that with a Z maybe Audiblemayhem or the guys from performance motorsports back in the day. I think they have a vid on YouTube.
Old Dec 24, 2011 | 02:34 PM
juicinjake's Avatar
juicinjake
a lot of guys have gone really fast on a single nozzle. unless you are running a really big shot its not worth it. the jet sizes are very small. imagine a 150 shot, broken into three nozzles... thats 25hp a nozzle. that said, if you are dead set on a direct port setup, look into the kinetix manifold. that would be the easiest one to plumb by far, and you could use wet nozzles with a rail. thats what i would do if it were me. i think you could also do it with a cosworth intake, several ways... there isnt a lot of room with the stock setup. how big of a shot are you really gonna run?
Old Dec 24, 2011 | 02:42 PM
2bad240's Avatar
2bad240
yea pretty much drag only. i never drive it anymore and yea i got 10.80s on my brain now and its gonna make me crazy
i have a plastic kinetix on the car now and the issue with the single wet fogger is that the fuel and nitrous dont mix and distribute evenly with my 150 shot. and i have blown up 2 kinetix from the fuel puddling up in the plenum.
and i have a spare engine on a stand i have plenty of room for the nozzles and lines with a wet or dry direct port. i will be running a 150 shot.
Old Dec 24, 2011 | 04:21 PM
denchan350gt
Do you think it's from your 25 dry shot? Maybe the ECU is dumping too much fuel to compensate for the extra nitrous.
I don't think you started blowing plenums until you started 125 wet and 25 dry.
Old Dec 24, 2011 | 04:27 PM
2bad240's Avatar
2bad240
i dont know exactly. i only had a 100 shot before. i went to the 2 stage. i may could switch to a different fogger that flows better and not have any issues.
the last time it happened i know it was fuel puddling up because the plenum blew apart and the hood blew up at the back and i could see the fuel burning and it actually scorched some stuff in the bay.
Old Dec 24, 2011 | 04:31 PM
2bad240's Avatar
2bad240
and do you still have the link to that nozzle test?
Old Dec 24, 2011 | 04:33 PM
denchan350gt
Your 2nd stage is setup before your 1st right I cant remember? Maybe when the 2nd stg hits it causes your 1st to not atomize properly anymore.
Old Dec 24, 2011 | 04:42 PM
2bad240's Avatar
2bad240
no the 1st 125 is on a wot switch. the 2nd 25 is on a button i hit in second gear.
but the problem with it is flow. i dont have the 2 solenoids hooked up with a Y they are inline and i have had the car on 2 different dynos and when i hit the second stage i lose 10-20 ft-lbs but gain 20 hp
on 125 shot i make 370/409
on 150 shot 2 stage i make 389/393
Old Dec 24, 2011 | 04:49 PM
denchan350gt
YouTube search NOS vs NX nozzle or nitrous express.
No what I mean is when your 2nd stg hits maybe it disrupts the flow of your wet shot if the dry is before the wet on your intake.
Old Dec 24, 2011 | 04:57 PM
2bad240's Avatar
2bad240
yea its before it on the tube. i see what your saying. im probably not gonna use it anymore. i may try getting some 150 shot jets and get a nice fogger before i try the direct port.
for the 125 wet im running 52n 28f right now and my 100 shot was a 46n 24f
i just think my nos fogger is maxed out and not getting a good mixture
Old Dec 24, 2011 | 05:34 PM
2bad240's Avatar
2bad240
i just bit the bullet and ordered a dynotune nozzle and jets for a 150 shot.
il try that before i do the direct port setup
Old Dec 24, 2011 | 07:16 PM
denchan350gt
You will notice a difference what jet sizes for a 150shot?
Old Dec 24, 2011 | 07:25 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Interesting. Keep us updated.
Old Dec 25, 2011 | 02:04 AM
juicinjake's Avatar
juicinjake
fyi i didnt mean the plenum... i meant the velocity manifold with the 6 visible, separated runners... it would be easy to mount 6 wet nozzles on that and have easy access for jetting changes at the track. thats why i suggested it.
that said, i think the trying the 150 shot single nozzle is a good idea before you take the direct port plunge. ive read about a few people running that much on a z with good results. good luck and keep us posted!
Old Dec 25, 2011 | 04:11 AM
2bad240's Avatar
2bad240
i ordered a 58n 32f
Old Dec 25, 2011 | 07:43 AM
denchan350gt
i ordered a 58n 32f
Hope you have enough fuel and good choice on the dynotune nozzle they were at the top of the list that nozzle shootout (10+ nozzles) NOS was last.
I'll post the link later.
Old Dec 25, 2011 | 08:19 AM
2bad240's Avatar
2bad240
yea im nervous about spraying the big single 150. i was gaining 182 ft-lbs off of just a 125 shot. i think the car will be faster all around with the single 150 because i wont have the dip in tq when i spray the second stage. im hoping with the bigger shot i will be able to get my 60' times down in the 1.57 range. im probably gonna install that diff bushing i got from you, and a set of soild engine mounts i had fabricated.
Old Dec 25, 2011 | 08:46 AM
denchan350gt
here is that link for the nozzle shootout.
http://www.tredalign.com/nozzleshootout.html
See what your A/F is before the track and I would get different size fuel jets to adjust if needed.
Threefivezero what size dynotune jets are you using?
Old Dec 25, 2011 | 09:25 AM
denchan350gt
here is that video don't know what shot, but it looks like a direct port.
http://youtu.be/u34UXqNY6hg
