Nitrous Oxide Too soon, jr.
has any one made 500 on nitrous yet?
Old Mar 27, 2013 | 05:07 AM
kellam's Avatar
kellam
Default has any one made 500 on nitrous yet?
anyone?
Old Mar 27, 2013 | 06:06 AM
Bmurray350z's Avatar
Bmurray350z
nope no one never hasnt never not done nothing like that
Old Mar 27, 2013 | 06:32 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I made 499. But motor blew
Old Mar 27, 2013 | 07:18 AM
wird06's Avatar
wird06
That just blew my mind. I read that three times, tongue twister.
Old Mar 27, 2013 | 07:34 AM
kellam's Avatar
kellam
hmmm bad thread im guessing.
Old Mar 27, 2013 | 08:10 AM
FWM69's Avatar
FWM69
Lol anywayssss, how's everyone's morning going?
Old Mar 27, 2013 | 08:13 AM
wird06's Avatar
wird06
EHHH its been OK. Just got Sheetz for lunch, beat a guy I work with in his late 90's mustang.
Day is Complete.
Thanks for asking.
Old Mar 27, 2013 | 10:57 AM
kellam's Avatar
kellam
was more looking for is there a build for a no2 car. built engine with good power.
sorry if i wasnt clear. i didnt find what i was looking for under search.
Old Mar 27, 2013 | 12:49 PM
wird06's Avatar
wird06
I have not seen one, but there are a few people in the 11's with virtually stock motors (as far as internals go).
Are you shooting for a dyno queen or 1/4 mile times?
Old Mar 27, 2013 | 01:06 PM
KingBaby's Avatar
KingBaby
Hardest Setting
present
Old Mar 27, 2013 | 04:15 PM
kellam's Avatar
kellam
Just looking to round out the Z. I have had low 9 "street" cars in the past. Really looking to pass 11.99 or better on the 19s with drag radials. A real street car.
It would be nice to make 500. It would be an easy 11.99. The wife could make that math work.
I have a 2jz on the engine stand. I think there is potential in this car and would rather hold off on it.
Old Mar 27, 2013 | 04:17 PM
kellam's Avatar
kellam
Originally Posted by KingBaby
present
Care to share sir?
Old Mar 27, 2013 | 10:15 PM
FWM69's Avatar
FWM69
Day is Complete.
Thanks for asking.
Nice Nice, I just got done spanking the twin to my Z and a DE, same old, same old.
Old Mar 27, 2013 | 10:49 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
What year Z do you have? Budget?
If you want to be sub 11.99, you can do that on a single 150 shot.
Originally Posted by ACEMAN
Nitrous Oxide Systems
1. 2bad240 -------------05 Base 6spd 150 shot 11.398@118.99mph 1.626 60ft Slicks
2. izit26 --------------06 Base 6spd 140 shot 11.825@117.02mph 1.682 60ft Slicks
3. one350zfan ----------03 Base 6spd 150 shot 11.832@113.32mph 1.653 60ft DRs
4. AudibleMayhem -------03 Tour 6spd 150 shot 11.833@115.53mph 1.639 60ftSlicks
Are you looking at any of the following as parts of your build, or are you just talking about plugging up a bottle to your stock Z:
plenum spacer or aftermarket plenum
exhaust
suspension
Nitrous safety features - lean cut, fuel pressure cut, progressive control
New clutch & flywheel
Smaller set of wheels for the drag radials
Revup oil pump if DE
Rod bolts, head bolts at a minimum
colder plugs
NANO + dyno tune
Quaiffe differential
4.08 gears
Old Mar 27, 2013 | 11:07 PM
jerryd87's Avatar
jerryd87
good luck with 19's and traction we have a hard enough time with 18's and 17's your going to have to get absolute perfect wheel fitment and 28 inch tall tires, which the taller tires is going to slow acceleration.
Old Mar 27, 2013 | 11:18 PM
SparkleCityHop
Living in 350Z
Yeah, that jumped out at me too Jerry, that's why I wanted to get an idea of what he has in mind for his build. Makes a lot more sense to have dedicated drag wheels & tires on a 150 shot with some other "bolt on items" if he's purely interested in getting the sub 12 time on the cheap.
If he's also interested in the dyno numbers and wants 500 to the ground, that's going to take some building or some breaking, then building.
If this is a pipe dream about bragging rights/looking cool, we're just wasting our time, so I'm waiting to find out more about his goals, budget, and build plans.
Old Mar 28, 2013 | 02:48 AM
kellam's Avatar
kellam
I don't have the experience you guys have with this car clearly. So I will maybe track the car a hand full of times a year. I have only track time with v8 mostly turbo cars. Kinda want to do something different to me. I though an engine swap would have been the best plan but seems like a waste to only be able to do a stock engine swap. So the budget I have is 6k at the moment. I won't be going to slicks or a tire that could wrinkle so if it impossible to pass fast without a tall soft tire them imok with it. I haven't seen any products that allow for pinion adjustment or manipulation of instant center for the Z. I don't know as much as you guys and really looming to learn the car a bit more. I have an 03 m6 car with137k miles. Because the install of the 2jz I have is my whole budget I decided to freshen up the 3.5 the car has hks duals on the car.
So I figured pistons, rods, cams clutch and some items to complete the NX kit I won at a track event. Because I don't know the car is why I as if anyone made good no power. That's where my head is at right now. I change my mind a lot but this seems like a good fun street car. Thank you guys for the input.
BTW it was way more fun racing my mustang @ 10.80 .when I went low 9s it turned into work.
Old Mar 28, 2013 | 03:01 AM
kellam's Avatar
kellam
exhaust
suspension
colder plugs
NANO + dyno tune
4.08 gears
yes all of the above. what is a NANO? 2 tunes?
Old Mar 28, 2013 | 04:09 AM
SparkleCityHop
Living in 350Z
Nitrogen assisted Nitrous Oxide system. It keeps your nitrous at a constant pressure. Usually NO2 systems have to be heated to reach the correct pressure, the pressure drops throughout the pull/run, etc. What NANO does is act as a pressure regulator by using a second, extremely high pressure nitrogen bottle to keep your NO2 delivery consistent thoughout the entire run and always ready for use. You can also use every drop of your nitrous bottle instead of having to get it refilled once it is half full, etc.
www.nanonitrous.com
This is my setup:
Old Mar 28, 2013 | 04:20 AM
Alberto's Avatar
Alberto
Cranky FI Owner
4.08 gears with N2O with 11's in mind?? C'mon I expect better advice from a mod.
OP-the chances of 11's on 19" wheels even with radials is SLIM.
I've helped a friend with I/TP/E and an untuned 100 shot on slicks to a 12.0@113mph. If he had more drag experience that's 11's. For most on a DR and avg driving you will need 125-150 shot, colder plugs and a tire.
Don't get caught up on everything else when talking 1/4 times the driver will make the biggest difference.
