Nitrous Oxide Too soon, jr.
Can I tap ECU Pin 62 for the tach signal for my MSD 8969?
Old 02-03-2019, 10:47 AM
BGrieb
BGrieb's Avatar
Default Can I tap ECU Pin 62 for the tach signal for my MSD 8969?
Should I have any problem picking up a tach signal from ECU Pin 62 (Ignition coil No.1 which is also Pin 1 of connector F203) for my MSD 8969 Window Switch? Thanks in advance for your help.
2004 Enthusiast 5Spd
ZEX Wet Kit P/N 82220
Old 02-03-2019, 12:10 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
Just curious - what will your window switch control? nitrous?
Old 02-04-2019, 03:34 AM
BGrieb
BGrieb's Avatar
Yes, it will control when the additional fuel and nitrous (Wet System) comes on at a minimum rpm and off at a maximum rpm. You don't want the system firing at low rpm (Below 2500-3000) and you must have it off before you hit the rev limiter (6600). I've read the ideal "window" is from 3000 to 6000 rpm but shifting at 5500 rpm for best performance.
Old 02-04-2019, 06:35 AM
bealljk
bealljk's Avatar
Good times … from my reference pin 62 is ign #1. I don't know much (if anything about nitrous) assuming this is pretty standard to pull a rpm signal? interested to see how things play out with your setup!
Old 04-09-2019, 12:21 PM
BGrieb
BGrieb's Avatar
The kit is complete, but...it only works if I bypass the MSD 8969 Window Switch by providing a temporary ground to the Nitrous Management Unit. The window switch is operational and reads the correct rpm when in use but is dragging my idle rpm down when I arm the system. Further trouble shooting will continue but...my daughter is getting married this weekend. The 55 HP shot sure is sweet! See the photos here and thank you for your interest: https://my350z.com/forum/2003-2009-n...l#post10988272
Old 05-21-2019, 12:45 PM
350zderder
350zderder's Avatar
Default Need other parts
You need just put these part on your cyl 1 signal
Luciiifer
Nitrous Oxide
16
05-21-2019 12:52 PM
RH4motorsports
12-07-2010 11:04 PM
RedBullRR
04-01-2010 05:53 AM
Drewer
07-27-2007 09:32 AM
Vash350Z
07-27-2006 10:39 AM
Quick Reply: Can I tap ECU Pin 62 for the tach signal for my MSD 8969?
