Nitrous Oxide Too soon, jr.
No2 and using the Crawford Plenum?
Old May 20, 2004 | 07:22 PM
cloudkid's Avatar
cloudkid
Default No2 and using the Crawford Plenum?
Anyone utilizing the Crawford V5 Plenum with No2? Just curious how you like/dislike it? I have the Crawford Cats and the JWT-Pop and Borla TD. Just curious if the A/F gets really lean? I know without spraying it will probably be leaner because there is more air, but when running the "wet" kit you are actually sparying the engine with No2 and more gas. This would richen it up at the time you are running No2? If this was the case and your jet was big enough (gas jet) then you are in good shape because you have richened up your mix while using the No2.
Thanks!!
Old May 27, 2004 | 04:54 PM
Carlitos's Avatar
Carlitos
Default Re: No2 and using the Crawford Plenum?
Thanks!!
you got it!
I wouldn't spray more than 125hp w/o the V5.
I'm spraing with 73N & 46F for a 145shot at the wheels (403rwhp). I never went pass 365rwhp w/o the V5.
BTW my base line was 258rwhp
Old May 27, 2004 | 07:06 PM
2003z's Avatar
2003z
as long as your nitrous and fuel nozzles don't stick open after a run, you;ll be ok!
Old May 28, 2004 | 04:13 AM
mjedens's Avatar
mjedens
I "resemble" that remark!!
Old May 28, 2004 | 05:34 AM
PoWeRtRiP's Avatar
PoWeRtRiP
that was quite the explosion im sure!
allmycarsdie
May 13, 2016 04:38 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
