Nitrous Oxide Too soon, jr.
dumb question
Old Jun 7, 2004 | 08:08 AM
Street Visionz, Inc.'s Avatar
Default dumb question
Lets say you active the arming switch and you have it setup for when you go wot the nitrous activatves. then you shift into and slam the gas down but do not hit rev limiter. Anything happen? Sorry I'm a newbie when it comes to nitrous. Also whats the best way to net a good 1/4 mile ET using nitrous in an auto tranny? Should I just activate it before I launch or after first gear?
Old Jun 7, 2004 | 03:47 PM
coletta z's Avatar
coletta z
I hit wot as soon as I get tracktion as for your other ? you should only use nitrous when the car is not under a load.For example if you had a stick shift do not use in a high gear while the car is at too low of a rpm. the motor should be free from a stressfull load.
Old Jun 7, 2004 | 03:48 PM
coletta z's Avatar
coletta z
By the way you kit should be on its way in a day or two! :0)
Old Jun 7, 2004 | 07:01 PM
Hey thanks bro. As for my first post sorry I was in a rush and didn't make my question too clear, what I meant was that if you have the nitrous armed and go wot for a brief second in neutral without hitting the rev limiter, does anything really happen? Also I have a ricer question to ask, lol, any flames with nitrous? Yes the fast and the furious has blinded me.
Old Jun 8, 2004 | 02:28 AM
mjedens's Avatar
mjedens
Default Flames !!
I can't picture someone being WOT in neutral while armed. If you do the system will of course spray. In addition, the "book" says to not go WOT unless you're past 3000rpms when armed. If you see flames (fire), get out & run !!!
Old Jun 8, 2004 | 08:03 AM
Oh I see. Also, can you arm the switch for a quick run, then after the run while you're slowing down can you quickly flick off the arming switch and deactivate the system?
Old Jun 8, 2004 | 01:16 PM
coletta z's Avatar
coletta z
(can you arm the switch for a quick run, then after the run while you're slowing down can you quickly flick off the arming switch and deactivate the system?)
YES
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
