Nitrous Oxide Too soon, jr.
Just Installed...Need help at DragStrip!!
Old Oct 10, 2004 | 10:02 AM
PimpinPearl's Avatar
PimpinPearl
Default Just Installed...Need help at DragStrip!!
I just intstalled a 75 shot wet nitrous system. It have a fuel pressure switch, an arming button, purge button, etc. I filled the bottle up Wednesday, purged maybe once for 10secs, then on friday went to the track. The way my system is set up, there is a micro switch on the floor so that when you are WOT, it injects... It will not inject until I hit that arming button. I went to the track for the first time and I am had horrible results. I should have easily been in the mid to low 13s, but couldn't break 14.3...
I had my VDC off and I hit the switch once I got into second gear.
I got 3 runs in and my bottle was practically empty, which is also not right because I should have been able to get at least 10 runs in on a practically FULL bottle.
My query is, what is the best time to arm the system on the track, before I start in first( heard bad things) or wait till 3rd???? Also, any ideas on why my bottle is emtpy so quick? I am currently testing the lines for any kinks, leaks, etc.
Any help would be appreciated, I will be going back to the installer sometime this week for him to check things out.
Old Oct 11, 2004 | 05:19 AM
g35irish's Avatar
g35irish
Can you tell us a little more? Were the results less than expected because the system didn't work properly, because of tire spin, etc.?
Old Oct 13, 2004 | 06:01 AM
PimpinPearl
It is very possible that tire spin was a factor. I couldn't get good grip from the start at all the whole night. I didn't loose any grip when I was spraying though. I ran a 13.9 w/intake, exhaust, AFC awhile ago when my car was gutting for the stereo install. Now I have a whole bunch of weight on the car and I can run usually a 14.3 without nitrous. I was expected to shave at least a second with a 75 shot. W/O nitrous I can a 14.88 best and with a 14.33 best, WTF??? Is you have any specific questions, please ask! Thanks!
Old Oct 15, 2004 | 11:06 PM
juicedZ's Avatar
juicedZ
just so you know...purging takes up more nitrous then spraying it when you drive...your wasting all of it so you can hear that cool sound! lol...i had a purge kit on my acura and 10 seconds of that will waste a loooooooooooot of nitrous.
-Eric
-PS make sure your bottle pressure is around 900-1000
Old Oct 17, 2004 | 05:26 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Josh why the hell did you not tell me. I'm gonna PM you my #.
Old Oct 21, 2004 | 06:44 AM
neffster's Avatar
neffster
Have you gotten things worked out yet JOsh?
Old Oct 28, 2004 | 04:18 AM
neffster's Avatar
neffster
I'll take that as a NO, since there has been no replies for 1 week.
SuperBlack350z
Drag
13
Feb 29, 2008 06:25 PM
twitch579
Drag
55
Jun 15, 2007 05:27 AM
westpak
South East
Apr 13, 2007 08:49 AM
THE_SCHROED
South Central
Apr 8, 2007 07:09 PM
tropicalypso
Drag
25
May 25, 2006 09:06 AM
