Nitrous Oxide Too soon, jr.
What do you guys use to activate nitrous?
Old Nov 14, 2004 | 06:51 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Question What do you guys use to activate nitrous?
Do you guys have foot throttles or do you guys push a button?
Old Nov 15, 2004 | 08:22 PM
MySunset350Z's Avatar
MySunset350Z
i have the WOT switch and another one in the shifter to shut the system off while im shifting since i drive an auto.
Old Nov 15, 2004 | 09:24 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Hmmm,
that would be hella hard to do with a stick shift. When I plan to drag for fun what should I do since I power shift?
Old Nov 16, 2004 | 02:23 AM
mjedens's Avatar
mjedens
WOT Switch (foot throttle) and a window switch when you miss a gear.
Old Nov 16, 2004 | 03:26 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
WOT switch, window switch, and toggle switch.
Old Nov 16, 2004 | 06:48 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Thanks for the reply guys. I was planning on the same setup, but I wanted to see what everyone else was doing to see if there were any better ideas available.
Old Nov 16, 2004 | 10:49 AM
MySunset350Z
isnt it a pain to spray in manual? do you guys wait til you shift into 2nd gear and then toggle the system on?
Old Nov 16, 2004 | 04:08 PM
mjedens's Avatar
mjedens
Default What Pain
Arm the system after burn out, purge, go to the rpm level you want to leave the line (in my case I leave at 6200), and then floor it and hang on!!!
Old Nov 17, 2004 | 02:34 AM
bascelik's Avatar
bascelik
What is a window switch?
Old Nov 17, 2004 | 06:57 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
https://my350z.com/forum/search.php
Old Dec 5, 2004 | 01:46 AM
mrtomcat's Avatar
mrtomcat
use a tps switch, it's much more acurate and of course a window switch
Old Dec 5, 2004 | 08:31 AM
MySunset350Z
cant use one of those on the z cause its drive by wire. theres not cable there.
Old Dec 5, 2004 | 01:13 PM
mrtomcat's Avatar
mrtomcat
the purpose of the tps switch is if you don't have a throttle cable.
You splice the tps into the TPS sensor in the ECU and it gives you the signal. Much more accurate than a wot switch and so safer.
my old celi has drive by wire as well and that's how I did it there
Old Dec 5, 2004 | 01:29 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Interesting. More info please
Old Dec 5, 2004 | 01:46 PM
mrtomcat's Avatar
mrtomcat
here's a link from NX:
http://www.nitrousexpress.com/Pages/TPS.htm
very easy install (you just need to know where the TPS wire is)
my old setup was like this:
Arm Switch -> tps switch -> window switch (above 3000 on, 200 below limiter off) -> nitrous relay's
this way you don't risk breaking the fragile arm of the wot switch (it was not intended to go under the gas pedal) and it trully will only spray at wot.
here's another link to the maximizer that has the tps/window switches build in plus a a/f emergency shutoff and gear based spray control...this is the way to go
it allows you to spray let's say a 50 shot in first gear and then gradually go up to your 100 shot hence less spinning off the line:
http://www.nitrousexpress.com/Pages/Maximizer.htm
Old Dec 5, 2004 | 03:01 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Hmmm, that is pretty cool. I think that may be a purchase I will be making very soon
Old Jan 1, 2005 | 09:26 PM
ChromiumBlue's Avatar
ChromiumBlue
wait, the maximizer comes with a TPS switch, so if i get that i dont need to buy the TPS seperately rite?
Old Jan 2, 2005 | 05:24 PM
mrtomcat's Avatar
mrtomcat
if you get the maximizer you need nothing else other than a palm pilot to program it of course
Old Jan 6, 2005 | 08:27 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
I'd recomend using a RPM window switch along with a full throttle switch. No matter what, you don't want to use nitrous at any rpm unless you are at WOT. If you combine the two, which isn't hard to do, you'll have a pretty safe setup.
It's a bit more costly, but a lot more peace of mind.....
Old Jan 8, 2005 | 06:23 PM
mrtomcat's Avatar
mrtomcat
rpm switch is part of the maximizer...
