Can anyone in MA help with +2 timing advance
Old Jun 25, 2009 | 08:03 PM
Stellanti's Avatar
Stellanti
Default Can anyone in MA help with +2 timing advance
Hey guys,
Noob here, but not really. My previous car was an 03 350Z and I now have an 07 FX35. I am looking to advance my timing to +2. Anyone know where I can have this done. Infiniti dealers think I am nuts, but guys on the FX board swear by it.
Any help is appreciated.
Thanks
Old Jun 26, 2009 | 03:18 AM
DavesZ#3's Avatar
DavesZ#3
I didn't think that was possible on ULEV vehicles.
Old Jun 26, 2009 | 04:51 AM
Dr. Venture's Avatar
Dr. Venture
turn the distributor..LOL!
No, i believe if you pick up a utec or unichip they are capable of being tuned to advance timing.
Old Jun 26, 2009 | 04:57 AM
cdoxp800's Avatar
cdoxp800
http://www.uprev.com/products.php
Cipher Data & Diagnostics
Our popular data logging and diagnostic tool for today’s Nissan and Infiniti vehicles. Cipher allows you to connect your USB equipped Windows PC directly to your vehicle and communicate with on-board systems such as the ECU.
With Cipher, you can log various sensors/parameters and retrieve DTC (Diagnostic Trouble Codes) so you can see how your vehicle is running and see what needs to be repaired or adjusted. Data that is retrieved with Cipher can be viewed in real time or saved to a file for later viewing or comparison. Cipher’s .csv files can be viewed through Cipher’s built-in graphical display or through many spreadsheet programs.
Buy through our
online store.
Cipher
$300
Buy Cipher Now
More on Cipher
Cipher communicates using Nissan’s proprietary communication protocol which enables you to view data with more speed than generic OBDII scan tools giving the user better insight into how the vehicle is running. Sample rates of 20 times per second can be achieved on more than 15 sensors at a time.
Simple ECU and BCM Control
Cipher also provides the user with basic dealership work support routines for the ECU and BCM including:
* Target Idle RPM
* +/- 2 degree static timing adjustment
* Cylinder power testing
* Clear Learned Fuel settings
* Manual control of BCM functions, ie. Windows UP/Down, Activate Locks, Wipers, Lamps, etc.
* Fuel Pressure purge
* Ethanol Adjustments (if vehicle is equipped)
* Coolant Test
Supported Parameters:
Below is a short list of available data parameters...
* Engine Speed - RPM
* Throttle Position Sensor
* Vehicle Speed
* MAF Sensor
* Calculated Load Value
* Oxygen Sensor
* Ignition Timing
* Accelerator Position
* Wide Band A/F Voltage (equipped vehicles)
* Coolant Temperature
Cipher supports most Nissan/Infiniti vehicles from 2003–2007. 2007 vehicles with the HR motors are not supported at this time, but will be in the near future. To see a list of fully supported vehicles please check our support page. Some vehicles may have limited functionality.
Old Jun 26, 2009 | 05:05 AM
Stellanti's Avatar
Stellanti
Yep, that would be it. Anyone have a Cipher in the MA area?
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
Cashwin
Oct 1, 2015 06:36 AM
