Optima Battery (locally)
Old Dec 29, 2008 | 07:17 AM
Jeff92se's Avatar
Jeff92se
Not sure who is going to have the reverse post configuration locally. I went online to get my redtop.
For the guy that had the yellow that went dead. Sure these will go dead. But these batteries are meant to be deep cycled. ie...all the way dead to all the way charged. Normal batteries can't do this.
Old Dec 29, 2008 | 08:39 AM
SlowZster's Avatar
SlowZster
hmm, ill search for the thread, but its been a while since i last saw it. might take a bit.
Old Dec 29, 2008 | 01:30 PM
Triple8Sol's Avatar
Triple8Sol
Yeah, that's a good point. I'm pretty sure my current battery is the original one, so it's completely done after 5-6yrs. Hopefully there isn't anything wrong with the alternator either. Still debating whether I want/need to get any or all of these tests: load/charging system/parasitic draw.
Old Dec 29, 2008 | 01:54 PM
Jeff92se's Avatar
Jeff92se
How long you keeping the car? Just get an interstate if you aren't going for a long term thing.
Old Dec 29, 2008 | 02:45 PM
Triple8Sol's Avatar
Triple8Sol
Not forever, but no definite plans for exactly how much longer. Ideally I could pull it and use it in the next car, but chances of that prob aren't very good, huh?
So if I go for a cheaper battery, what should I get? Interstate? DieHard? Pacific Power? Other? I recently just realized I know nothing about batteries, since I've never had to actually replace one on any of my vehicles.
Old Dec 29, 2008 | 04:33 PM
sdbarker's Avatar
sdbarker
I've always used Die Hard as replacement batteries and been nothing but satisfied. But, I'm sure there are others that would work just as well.
Old Dec 29, 2008 | 05:03 PM
Jeff92se's Avatar
Jeff92se
Since that one seems to be failing more due to age than use, almost anything would work. But Die Hards and Interstates are two of the more reconized brands.
And the chances of a reverse post fitting your next car is probably slim
Old Dec 29, 2008 | 08:16 PM
jining's Avatar
jining
Correct me if wrong but I believe interstate makes optimas so they are quite nice. I heard Die Hards are not very well made. Get an interstate.
Old Dec 31, 2008 | 01:29 PM
djSLiM's Avatar
djSLiM
johnson controls makes almost every battery out there, they just have different stickers for brands on them. i've had an optima yelow top go back and forth through cars and be beat on by demanding stereo systems in my vw's and i've loved that thing. i've had it go dead from sitting and brought it back from the dead a couple times. mine isn't the reverse terminal either, but in my gti i just stretched the cables and crossed them with zero problems. the posts are usually pretty centered and closer together than all other batteries so you may either cross the cables, or stretch the to the front a little to reach. right now i work at the autozone on 272 and pac in federal way (i'd really like a new job, though ) so if you decide not to go with the optima, i'd suggest get a duralast battery from them. not saying its better than any others just cause i work there, but its made by johnson controls also and they got killer warranties. autozone will replace just about anything...
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
nanotech
Oct 2, 2015 05:02 AM
