Drag Radials
Old Jan 22, 2005 | 11:33 AM
350fanatic's Avatar
350fanatic
Default Drag Radials
what do yall recommend?
im thinkin between Bfgoodrich or Nitto's?
anyone with these tires or had em in the past please chime in.
ive heard that the Bfgoodrich has a lot more traction vs the Nitto's
Old Jan 22, 2005 | 08:54 PM
corsair's Avatar
corsair
It's funny you asked this question. I was just at Zcar Garage the other day and we were talking about this. Rob says he has tried both and it's BFG all the way. I was going to get the Nito 555 series but not now after talking to him. He said Nittos have traction problems.
Old Jan 23, 2005 | 09:44 PM
fowlman01's Avatar
fowlman01
When's the next drags???? I'm ready.
Old Jan 23, 2005 | 10:09 PM
4myZ350's Avatar
4myZ350
to go drag?
Old Jan 24, 2005 | 05:58 AM
fowlman01's Avatar
fowlman01
Originally posted by 4myZ350
to go drag?
Up late having a little prune juice Jack????
Old Jan 24, 2005 | 10:02 AM
corsair's Avatar
corsair
Jack loves that prune juice.
When's the next drag event?
Old Jan 24, 2005 | 10:04 AM
fowlman01's Avatar
fowlman01
That's what I was asking you. I dunno
Old Jan 24, 2005 | 11:14 AM
4myZ350's Avatar
4myZ350
it's in S.F. I don't know what CLUB .
Old Jan 24, 2005 | 11:26 AM
fowlman01's Avatar
fowlman01
It could be at any number of them..................very good comeback Jock!!
Did you work at Finocchio's??? Black Cat?? I bet you cut quite a figure in your "outfit".
Old Jan 24, 2005 | 11:46 AM
4myZ350's Avatar
4myZ350
WILT ! I only worked laides(lol) CLUB'S
Old Jan 24, 2005 | 11:54 AM
fowlman01's Avatar
fowlman01
Hey pervert!! lets get this back on topic. We don't want to know about your sordid past.
Old Jan 25, 2005 | 08:59 PM
corsair's Avatar
corsair
Looks like there is a Test & Tune this Saturday at Sacramento Raceway.
Old Jan 26, 2005 | 06:05 AM
fowlman01's Avatar
fowlman01
I will be doing a show this weekend..........
Old Jan 26, 2005 | 12:44 PM
350fanatic's Avatar
350fanatic
ill be at infineon on the 29th.. whose going?
too bad i dont have my DR's yet
Old Jan 26, 2005 | 01:01 PM
arvin's Avatar
arvin
Hey Rey, can I get a drag of that good stuff.
Old Jan 26, 2005 | 02:36 PM
myz8a4re's Avatar
myz8a4re
i have some info to share on both drag radials mentioned. ive used several different sizes of each brand from 15" to 17" on my mustang. yes the BFG's do grab better than the Nittos, but the nittos have much better carcass flex characterisitcs over BFG. if you care about handling what-so-ever than the nittos are the way to go. if straight line traction is all you care about than the BFG's are the best choice. both will make a huge improvement over street radial tires anyways. when heated they both grab greatly over stock tires/radials. the BFG's seem to grab more even while spiining, forward momentum is more appearent while spinning. i went from 17" nittos to 16" nittos to 16" BFG's to 15" BFG's. i went from street handling to all out drag. naturally the 15" tires hooked better with the large sidewalls. also the nittos are known for running a little narrower than other tires of similar size. so the BFG's seemed to have alot more meat on them width wise! the sidewall was obviously softer wich is where the benefits are found, the compound is basically the exact same. best of luck!
-justin
Old Jan 26, 2005 | 02:43 PM
corsair's Avatar
corsair
Thanks for the input justin. Will these tires fit on a z?
26X11.50X16
Old Jan 26, 2005 | 02:48 PM
corsair's Avatar
corsair
What's goning on there on the 29th?
Old Jan 26, 2005 | 03:24 PM
myz8a4re's Avatar
myz8a4re
26X11.50X16
these sizes your mentioning are from either ET streets or ET drags. it really depends on wich ones you get. the ET street series tires run 11.5" from sidewall to sidewall, the ET drags are 11.5" from tread edge to tread edge not including the sidewall bowing, so they are much wider.....the rim width & offset of the rim are going to tell you more of wich tire will fit the z to be honest........
-justin
Old Jan 26, 2005 | 04:08 PM
350fanatic's Avatar
350fanatic
umm.. bracket drags?
im rollin wit hassan and two other ppl.
hassan will be runnin his firebird n the other two they got a cobra and a AWD turbo eclipse...
