Cams
Old Mar 28, 2006 | 11:38 PM
dbmtrx123's Avatar
dbmtrx123
Default Cams
In my quest for gaining as much N/A hp as I can without building the engine, I stumbled on a set of cams called Pro-1. They claim big power, compromising every day driving. That's fine with me, well actually more of what I'm looking for. Anyone know anything about the Pro-1s and how they compare to JWT, Stillen, Nismo etc? Most people I talk to seem to agree that the JWTs are the best making somewhere around 13 RWHP. Any info on any cams would be appreciated. Thank you.
David
Old Mar 29, 2006 | 07:12 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
how much more hp gain on this Pro-1?
Old Mar 29, 2006 | 07:56 AM
dbmtrx123's Avatar
dbmtrx123
I'm not sure, I was hoping that someone would know. All that was said about it was it has a big horse power gain and that it sacrafices drivability for performance.
Old Mar 29, 2006 | 08:48 AM
nateg35's Avatar
nateg35
Talk to Ted @ Scott Performance in Santa Clara....he's the cam expert
Old Mar 29, 2006 | 09:03 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
this is what Sharif @ Forged Internals told me when i asked the same question as you (since i found a deal for Nismo cam around $600)
Upgrading cam shafts is one of the most expensive NA mods you can do. I usually dont recommend it, unless someone is committed to staying NA, and they have no plans to build the motor.
THe majority of people that install cams, do so in conjunction with a full engine rebuild. Installing cams, alone is about $1200-$1500 in labor alone, and with an NA car, you can expect about 20whp max improvement.
Old Mar 29, 2006 | 12:04 PM
dbmtrx123's Avatar
dbmtrx123
If it costs that much just to install cams, I might as well go ahead and do new heads and connecting rods as well. Just go ahead and do it all at once I suppose.
Old Mar 29, 2006 | 01:47 PM
dimebagdolf's Avatar
dimebagdolf
CAMS are great in conjunction with forced induction, but as an NA mod, it's not much bang for your buck.
Old Mar 29, 2006 | 02:30 PM
LOU's Avatar
LOU
If you are staying NA and want the most top end power you should look into the Tomei 268 cams. If you have a pre rev-up engine then you may want to think about some heavy duty springs and raising the rev limiter to 7100.
Unless you are looking to get crazy. Then the part list grows and grows.
nateG35, not to start any ****, but Ted buys his cams, he doesn't grind them himself.
Old Mar 29, 2006 | 02:34 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
dimebagdolf, you have 430whp at 7psi and still not happy?
Old Mar 30, 2006 | 08:54 AM
dbmtrx123's Avatar
dbmtrx123
those are the highest duration cams I've seen so far.
pslamp32
Feb 8, 2017 09:07 AM
B Esquire
Sep 24, 2015 07:52 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
