Anyone has driver side window problem?
Old Aug 17, 2006 | 09:28 PM
Moodie's Avatar
Moodie
Minivan Racer
Default Anyone has driver side window problem?
My driver's side window started acting up and stop working at times. I've read the repair section for info, found it, but I am mechanically challenged. If anyone local can help, I'm more than happy to buy lunch....
Thank you.
Old Aug 17, 2006 | 09:56 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Yeah the repair is not that difficult but it requires two as one holds the window while you take apart the door. I'd help but I only did it once and if we get stuck somewhere we are screwed. Do you have a new motor already since that may be the problem.
Old Aug 17, 2006 | 11:10 PM
Shift33's Avatar
Shift33
I had both my windows fixed by Nissan when I had Audrey. They replaced both motors because they couldn't find the problem. I did it after warranty and the dealer did it for free because of their "good faith" warranty.
Old Aug 17, 2006 | 11:26 PM
jinsei888's Avatar
jinsei888
dood, moodie, it's a DIY! haha, I've done it on 3 cars so far, so you could say I've got it down. We need a tech day or something...
Old Aug 17, 2006 | 11:57 PM
iNi_REALiZED's Avatar
iNi_REALiZED
I'm having the same problem as well.... I think I should just take it to the dealer.
Old Aug 18, 2006 | 07:22 AM
jvega's Avatar
jvega
I am having the same problem, it's eratic, on both windows. Happens more often on hot days.
I would be down for a tech day.
Old Aug 18, 2006 | 08:08 AM
Moodie's Avatar
Moodie
Minivan Racer
Terrence, I'll buy you lunch if you have some time to look at it. Let me know.
Old Aug 18, 2006 | 08:09 AM
Moodie's Avatar
Moodie
Minivan Racer
Which Dealer???
Old Aug 18, 2006 | 08:12 AM
Luscious Luke's Avatar
Luscious Luke
Bring it on over, I'll fix it. I am the master at panel removal now along with relay and switch issues on those window motors. Let me know, I'm home all weekend.
Old Aug 18, 2006 | 08:42 AM
Moodie's Avatar
Moodie
Minivan Racer
Thanks Luke. May take you up on your offer. I'll PM you.
Old Aug 18, 2006 | 02:53 PM
MyZNeo's Avatar
MyZNeo
I had the same problem on the driver's side, luckily I have an extended warranty for that kind of c#*p. Window motor was replaced. Good Luck...
Old Aug 18, 2006 | 06:34 PM
Shift33's Avatar
Shift33
I went to San Leandro Nissan the last time to get it fixed.
Old Aug 18, 2006 | 06:38 PM
myehrick09's Avatar
myehrick09
I just had mine replaced 2 days ago. Unfortunately, I have to pay a $50 copay with the extended warranty.
Old Aug 18, 2006 | 06:48 PM
jinsei888's Avatar
jinsei888
Moodie, where's around do you live? The school semester at SJSU starts next wednesday, so I'll be up in SJ very often for now; PM me
Old Aug 19, 2006 | 08:01 AM
Moodie's Avatar
Moodie
Minivan Racer
Thanks Terrence. PM sent!!
Old Aug 19, 2006 | 08:32 AM
harrieyu's Avatar
harrieyu
i've noticed taht if you hold the panel into the door or push rather...then the window works...i was frustrated one time playing with the switch and banged the door and it worked...
Old Aug 20, 2006 | 04:17 PM
cwerdna's Avatar
cwerdna
To the OP, are you still under the basic (or extended warraanty if you bought it)? BOTH of my windows failed (driver's side first and passenger shortly after) on my 04 Z. The dealer replaced the both power window motors and regulators under warranty.
Old Aug 20, 2006 | 06:13 PM
jinsei888's Avatar
jinsei888
you know what, when I do moodie's window, a bunch of you should just show up and check out a tutorial, then you can all probably fix em all at once
Old Aug 20, 2006 | 08:08 PM
kaybee650's Avatar
kaybee650
I go to san leandro nissan , i usually go to bob jehs... his door is on the right... or flor can help also, she's a nice lady.
Old Aug 21, 2006 | 07:31 AM
jvega's Avatar
jvega
Terence,
My window has stopped working.
I am in San Mateo. Can I give you some gas money to fix mine?
