First time Laguna Seca!!!
Old Mar 22, 2007 | 08:35 AM
alving's Avatar
alving
Default First time Laguna Seca!!!
I went to 'Seca yesterday with NASA. It was a phenomenal day. The Z impressed me and I ran a 1:52, on stock tires! Tires got really greasy and the Z wouldn not rotate, just plow towards the end of the sessions. I'm hoping better tires can resolve that.
On the front straight it sounds incredible....I love this car! Here are pictures, I was the ONLY Nissan Z there
http://rides.webshots.com/album/558303035IOKEbz
Old Mar 22, 2007 | 08:43 AM
Sk8fe's Avatar
Sk8fe
Any in-car video?
Old Mar 22, 2007 | 09:02 AM
alving's Avatar
alving
No And I always have some sort of in-car action. Don't have a rolbar camera mount like in my Datsun...and I thought one of these wouldn't work on the Z:
In-car video for sure October 21 when we go back to Seca!!!! By then I'll have some real tires and hopefully a stiffer a setup.
Old Mar 22, 2007 | 09:50 AM
scotts300's Avatar
scotts300
Brakes before any of the above.
Old Mar 22, 2007 | 09:58 AM
alving's Avatar
alving
Why? I was getting frustrated with turning the car in turns 2-3 and 8A-9-10...it wanted to go straight, no front end bite. That's all tires, no?
If I get brakes are you saying I can brake later and go slower in faster out? EVen with stock tires?
Old Mar 22, 2007 | 10:19 AM
scotts300's Avatar
scotts300
I'm saying that if you get better tires, you'll have more straight-line braking grip that'll demand more of the brake system. The car was understeering one, because of poor grip, but two, because you didn't slow down enough to take the turn at a speed your tires could handle (aka your braking)
Let's hit T-hill together
Old Mar 22, 2007 | 03:47 PM
Playboy's Z's Avatar
Playboy's Z
man i was going to go to this but i had midterms today. missed out. if you go again man i have a membership with nasa so id be down.
Old Mar 23, 2007 | 12:10 AM
nofeardude87's Avatar
nofeardude87
how much does it cost? any experience or special equipment needed?
Old Mar 23, 2007 | 06:57 AM
scotts300's Avatar
scotts300
Different groups and different tracks command varying prices. You can go to Thunderhill on a weekday with Speedventures for $175, or you can go to Seca on a demand weekend for $350. You need an SA2000 helmet for most groups, and most tracks rent them if you don't have one. Some groups require fire-retardant gloves as well. Almost all organizations have a novice class and provide instruction.
Send me a pm if you'd like to discuss this further offline; however, there are many members here that can guide you or help you with your first event.
Speaking of Laguna Seca:
Old Mar 23, 2007 | 09:03 AM
alving's Avatar
alving
CHeck these pictures out from my friend, just pick a corner and click!!!
http://www.jumpside.com/lagunaseca/
One of my favorites:
http://www.jumpside.com/lagunaseca/turn8/img_2046.htm
Old Mar 23, 2007 | 12:59 PM
hiz-n-herz's Avatar
hiz-n-herz
Are these the re040 tires? I am wondering if the 050's are any better. Still a street tire though... not sure what can be done to overcome that without going to r-comps.
It also seems to me that the z brakes are really front biased. That, in combination with the lack of rebound damping in the stock rear shocks, which pitches the car forward during braking and weights the front-end, it's no surprise that the front tires get overwhelmed.
I think Koni SA's on stock springs with the rebound damping turned up would be a good improvement on the track.
Were you able to get the brakes to fade?
Old Mar 23, 2007 | 02:15 PM
alving's Avatar
alving
Stock RE040 tires. Did not play with tire pressures. The TPS actually registered as high as 49!!! THe first 3-4 laps of every session were great, but after that the tires would scream and chatter, I spent most of the time sliding through a corner rather then being firmly planted.
You know I don't think I got the brakes to fade...never dipped into ABS. I didn't drive 10/10ths. If I floored it and braked hard at every corner they'd probably fade...I'm a novice driver and I still have confidence issues with braking!
Old Mar 26, 2007 | 11:49 PM
ayumihkk's Avatar
ayumihkk
is there any in car camera device that people recommend using for recording races or off road meets
Old Mar 27, 2007 | 08:32 AM
alving's Avatar
alving
I/O port if you have a rollbar:
http://www.ioportracing.com/
For mounting to the headrest posts:
http://www.filmtools.com/cruisecam.html
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
