Carters Automotive Now Open!!!
Old Feb 9, 2012 | 04:37 PM
cartersauto's Avatar
cartersauto
Vendor - Former Vendor
Default Carters Automotive Now Open!!!
Hey guys most of you know me as cpapasmurf, or Chris from the meets. Its been a long time coming, but finally I opened my own shop. I am still offering discounts to all of the forum members, and of course the great friends I have made here. please feel free to email me with any questions, quotes, or issues I might be able to help with. I look forward to continuing the relationships I have built. Thanks for all the support
Chris Carter
Carters Automotive
744 San Pablo Ave
Albany Ca,94706
510-647-9199
cartersautomotive@gmail.com
www.cartersautorepairs.com/
Old Feb 9, 2012 | 04:48 PM
SE5spd's Avatar
SE5spd
Nice!
So same prices as before?
You mind relisting them?
Old Feb 10, 2012 | 06:33 AM
Cali-Darkness's Avatar
Cali-Darkness
Congrats Chris
Old Feb 10, 2012 | 04:22 PM
cartersauto
Yes still doing low prices for the Z Members.
30,60,90K Services
$400 for Manual Transmission, $430 Automatic Transmission. This includes, NGK Platinum spark plugs, air filter, brake fluid flush, power steering flush, Coolant flush, automatic/Manual transmission fluid drain and fill, diff fluid drain and fill, and oil change. I am using all factory Nissan Fluid, and Filters.
Front and Rear Brake pad replacement $65.00 front $65.00 Rear - You can supply the pads or I can get a few different brands including Nissan, Akebono, hawk, etc at additional cost.
Spark Plug Replacement $145including NGK Platinum Plugs
Sway Bar install Front and Rear $70.00
Strut and or Spring install - Front and Rear $220.00
Coil over install starting at $220.00 Front and Rear Depending on the Kit. This does not include ride height adjustments.
Ride height adjustments-Starting at $50.00 and depending on how long we spend.
Exhaust Install - Cat Back System $65 Some systems will be more
Test Pipes/ Catalytic Converter install 75.00 for 03-06
$115.00 07-
Intake Plenum or spacer install - $70.00 (Upper Plenum not Lower)
Big Brake Upgrade install $180.00 depending on the kit.
Air Intake install $50.00 for 03-06
07-$85.00
Please ask me about anything that is not on this list. I can do anything and everything. I also work on most Japanese cars so please feel free to ask.
My shop address is 744 San Pablo Ave Albany Ca 94706
Contact me 510-647-9199 or by email cartersautomotive@gmail.com or here on the forum.
Old Feb 12, 2012 | 01:02 PM
SE5spd's Avatar
SE5spd
Just sent you an email for some installs!
Old Feb 12, 2012 | 02:34 PM
zxe010's Avatar
zxe010
Congrats Chris! I'm about to need my 60K service. I will hit you up to make an appt.
Old Feb 13, 2012 | 07:01 AM
ntrinsik's Avatar
ntrinsik
Awesome. I may have to hit you up for a 90k soon.
Old Feb 14, 2012 | 07:07 AM
cartersauto
Let me know when ever you guys are ready. We are normally here Mon-Friday.
Old Feb 14, 2012 | 06:19 PM
eracer's Avatar
eracer
How much would you charge to change a transmission? (CD008 to CD009) Plus the install of a new clutch and flywheel?
Old Feb 16, 2012 | 07:20 AM
cartersauto
Sean thanks for checking with on your transmission. I will let you know once I have it here and hopefully we can get it done next week.
Old Feb 16, 2012 | 08:40 AM
Spider Monkey's Avatar
Spider Monkey
Can you please move your shop up to Roseville?
Old Feb 16, 2012 | 09:05 AM
SE5spd's Avatar
SE5spd
Are you able to do diff installs?
Old Feb 16, 2012 | 09:36 AM
ITOzann's Avatar
ITOzann
Old Feb 16, 2012 | 10:06 AM
cartersauto
SE5spd, yes I can do diff installs. What are you looking to do?
Old Feb 16, 2012 | 10:46 AM
SE5spd's Avatar
SE5spd
get a os giken installed into a base model hr z
can u pm me a price for install?
Old Feb 17, 2012 | 04:43 PM
EastBayG35's Avatar
EastBayG35
Congrats Chris. Got to stop by and say hi. Might have some work for you. Will text you.
Old Feb 19, 2012 | 03:30 PM
willow350's Avatar
willow350
I think you did shock and spring install on my z several yrs ago. Still solid and no problem.
Old Feb 24, 2012 | 10:25 AM
datsunHEAD's Avatar
datsunHEAD
how much to install a shift **** i kid i kid,can this be for my350z.com members non Z's cars too
Old Feb 24, 2012 | 11:20 AM
TongMan's Avatar
TongMan
Do you have a dyno? Do you do any tuning?
Old Feb 24, 2012 | 04:01 PM
sid67jp's Avatar
sid67jp
He has no dyno for the moment nor tuning & alignment. But pretty much everything on auto repair he can do.
