Need help.
I need some help with getting my car up and running again. If anyone is willing to Come to my house and help that would be awesome. I don't trust any mechanics in my area and the nearest Nissan dealer is 1 1/2 hours away from where I live. I'll pay for your gas and pay you for helping. But you must know what you're doing. Lol
How did you check for vacuum leaks? I prefer brake cleaner. If there are no leaks and you are sure all electrical connections are good then you really need to check compression, I don't have one at the moment but they're pretty cheap. If you have to drive the car pull the injector wire for cyl 3. I had an emergency 3 cyl 180sx for a few days once.
Yeah the is a cel. I keep getting a p0300 code. But before that I got a p0303 code. I've checked as much as I could and I can't find anything. Compression is the only thing but I don't have the tool to do it.
see if someone can do a compression/leakdown test as you may have crappy compression in that cyl...
You can also use a noid light to see if the injector harness if firing properly as well
P0300
Possible cause:
* Improper spark plug
* Insufficient compression
* Incorrect fuel pressure
* The injector circuit is open or shorted
* Fuel injectors may be faulty
* Intake air leak
* The ignition signal circuit is open or shorted
* Lack of fuel
* Drive plate or flywheel
* Front heated oxygen sensor may be faulty
P0300
Possible cause:
* Intake air leak
* Lack of fuel
P0300
Possible cause:
* Intake air leak
* Lack of fuel
P0300
Possible cause:
* Intake air leak
* Lack of fuel
