Not Z Related Items Post your items for sale here that are not Z-related.
FS: DogCam Helmet Camera Systems UK
Old Jan 9, 2012 | 08:41 AM
angelo_balto's Avatar
angelo_balto
Default DogCam Helmet Camera Systems UK
Hi, I am selling (2) used DogCam Helmet Camera Systems UK kits.
Each kit is selling at $ 200,00.
DogCam Systems is the UK's Premier Specialists in Wearable Video Technology
DogCam Bullet cameras is a family run business founded in 2005 and ever since we have been at the forefront of helmet camera and head camera technology in the UK.
Each DogCam Helmet Camera System COMPLETE KIT Contains:
(2x) DogCam Camera
(2x) Protective lens cap
(1x) DogCam Switch (to setup a twin-camera system)
(1x) remote controller (adjusts day/night , nega/posi , tele/wide , pan/tilt and brightness)
(2x) DogCam Suction Mount
(1x) DogCam Microphone Standard
(1x) DogCam Microphone Yoga EM-8
(2x) Viosport rechargeable battery pack
(2x) 8 x AA Battery Holder
Bonus Items...!
kit (a) : Goggle mount
Designed to be used with the universal bullet camera mount above. An excellent way to mount your camera to your goggles.
kit (b) : Right angled Double Hook and Loop Mount
Much like the double hook and loop mount but with a 90° twist.
This is a great mount for handlebars, glider struts and any other bar under 1 1-2" in circumference. Makes for a very good roll bar mount if you don't require the extra adjustment.
____________________________________________________________ ____
ITEM SPECIFICATIONS
RF Concepts 21CWSHRX
High resolution 1/3" Color CCD Bullet Camera (Weatherproof version)
*1/3" DSP Color Sony EXVIEW CCD, High resolution It is the world's first High resolution Color camera in a bullet style. It is noticeable in that the unit is used with the most high end 1/3" Color CCD chip set
among the list of Sony grade. It is highly recommended for a special requirement where need more precise, more bright and high resolution such as for medical site, chemical plants, defense areas, precise Inspection equipments or for crowded big halls etc. The same design with a variety of different versions are also available
*Lens Exchangeable
The smart idea with user friendly mechanized housing makes it possible to adapt a wide range of different focal lens. Installers can change the lens with no special skill, very easily with no need of changing the camera itself in order to fix the suitable angle of view or adequate focal distance.
*Condensation free
Our weatherproof versions provide a perfect solution for moisture leakage against any harsh weather condition. The camera is completely sealed in a clear vacuum status to resist moisture or water from smearing into the camera under the fluctuating sunny and rainy weather.
*DAY & NIGHT Version with EX-VIEW HAD CCD
The model is compatible to use an EX-View HAD CCD which has a remarkable light sensitivity in both 470,000 pixels, high resolution and 270,000 pixe standard resolution. It can see clearly at 0.1 lux at F2.0. It is very suitable as a Day/Night surveillance when it is combined with IR Sensitive solution.
*Compact Size
Incorporating all innovative features, those are used with 1/3" DSP Color CCD format and made with the world's smallest size.
*Beautiful design
Our fine craftsmanship reaches not only to the picture quality and compact size but also to the products GD(Good Design) All we manufacture have their own unique face and shape firstly aiming to best fit to the environment decorative to any place.
*Easy Installation
Universal type of mounting structure plus user friendly developed camera design provide a useful way of installation mountable to any place such as on the ceiling,on the wall,on the shelf or at the corner providing adjustable 360 degree of camera angle without permitting any invisible position.
* IR Sensitivity (Option ) This option offers a solution for the camera to work with a separate IR illuminator for DAY/NIGHT view without affecting the coloration at day light.
* Audio Available ( Option ) * Reverse Polarity protection built in
MOUNTS:
(1) DogCam® ™ Suction Mount
This is the best way to secure your DogCam to a bike, helmet or car body work. These suckers suck hard at speeds of over 185 mph (on a track of course). Zinc bonded to steel silver clips that will never rust. Customize your cam by spray painting the clips. Price includes 3 suckers which is the minimum recommended for holding a bullet camera. Suitable for cameras 21 to 23mm in diameter.
MICROPHONES:
(1) Microphone Standard
We have designed this mic primarily for use in cars and on bikes but it works just as well for all other sports and gives you the exact adjustment to suit your filming environment.
(2) Microphone Yoga EM-8
You can turn the gain to 100% and record only the loudest vehicles noises.Will not make this microphone clip or distort.
BATTERY:
(1) Viosport rechargeable battery pack
Specifications:
12 volt li-ion rechargeable battery
on/off power switch
5 led-lights indicate remaining power supply
1/4-20 threaded bolt attaches to all tripod sockets
Contains:
12V rechargeable battery
AC 12V power supply
Charging unit
(2) 8 x AA Battery Holder
For anything else, pm (or e-mail at paris_balto@yahoo.gr)...
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
