Pacific Alaska, Hawaii
350Z Running strong.
Old Feb 15, 2007 | 08:02 PM
redline350ZZ's Avatar
redline350ZZ
Default 350Z Running strong.
Well I got my car back again and Seth@Sonic did an awesome job to get my car running after a defective part was found This guy does not sleep and does top quality work...lol but I am very happy with how things are turning out, there was some problems due to me wanting the newest parts out but everything was fixed and I got a chance to drive around for about 10 miles so far checking it all out and so far everything is ruining how it should. If everything goes to plan the next visit will include bigger injectors, fuel system and a bump to 12psi probably in the next few weeks.
Now to devise a plan to get 1000 miles with minimal stop lights...hmmmmm
Old Feb 15, 2007 | 09:29 PM
FEARSM's Avatar
FEARSM
Good deal. Feels good doesnt it? I was definitely glad to get my baby back on the road.
Old Feb 16, 2007 | 09:20 PM
redline350ZZ
Well up to 45 miles now did a 25 mile drive tonight and all went ok. After it started to rain I decided to call it quits for now. More 2 morrow.
Old Feb 16, 2007 | 09:23 PM
redline350ZZ
BTW whats the best battery I can get on island for my Z and where can I get one??
Old Feb 16, 2007 | 11:12 PM
punish_her's Avatar
punish_her
Yeah I know the fealing man, got up to 70 miles when mine **** the bed on me.
Cant wait till mine gets back in.
Old Feb 17, 2007 | 01:59 PM
redline350ZZ
85 miles and the smoke has died down a lot.
Old Feb 19, 2007 | 02:33 PM
redline350ZZ
140 miles. The smoke is odd it only comes sometimes....wierd might be the Turbo....
Old Feb 19, 2007 | 04:09 PM
FEARSM's Avatar
FEARSM
Does it only come under boost?
Old Feb 19, 2007 | 04:16 PM
redline350ZZ
Nope it varies a lot. It's not all the time so I don't know. I'm gonna continue to put miles on it then do a compression test later. I don't think its the engine tho.
Old Mar 7, 2007 | 03:04 PM
redline350ZZ
420 miles, smoke is gone and that's a good sign. It must have just been the rings setting in place. Could also have been the catch can I installed, who knows. Just waiting on Sonic to figure out how and when we can shoot for the 500WHP mark. Until the GTK series Turbo upgrades come out, if ever. I will be limited to about 500 unless I go custom.
Good new is more people have been up to 650WHP on stock sleeves.
And I will be upgrading my clutch line this weekend because I have been boiling my fluid and the pedal has been sticking to the ground preventing my 1000 mile goal.
Old Mar 7, 2007 | 04:46 PM
FEARSM's Avatar
FEARSM
Sounds good. Let me know when you take it to the dyno. I would like to check it out.
Old Mar 7, 2007 | 05:40 PM
redline350ZZ
Yea I can't wait to get this part done so I can get my car in for body work and order some new rims.
Old Mar 7, 2007 | 06:50 PM
FEARSM's Avatar
FEARSM
Good deal..thats where my car is now. Changing a few things on the setup.
Old Mar 15, 2007 | 08:42 PM
redline350ZZ
RC Eng 550cc Injectors are in. On Tuesday I get my return fuel sys, TXS Boost control solenoid and the Plug and Play clips for my Injectors.
Old Mar 15, 2007 | 09:27 PM
punish_her's Avatar
punish_her
The 550's will help alot on the power end and I think with the current setup you have the turbo will be out of its efficency rang long before you max out the injectors.
What fuel system did you go with and did you get the walbro 255 fuel pump? That helps cut the fuel starvation and low fuel pressure when you start putting the power down.
You may want to ask arround on how to set up the pressure guage to the UTEC. It was tricky for some, or so I've read. But once you got it it seems to be working fine for most people.
The plug and play clips are definately a good thing to have. They just prevent future wiring issues.
Sounds like every thing is comming together and Im getting left behind because of the shipping issues for the engine.
Old Mar 15, 2007 | 09:51 PM
andyisphat2004's Avatar
andyisphat2004
That is the one thing that blows about living in hawaii, nothing can ever get done fast....
Old Mar 15, 2007 | 10:13 PM
redline350ZZ
I went with the CJ Motorsports Fuel return sys that supports up to 550WHP.
The Turbonetics kit came with a 255 fuel pump so thats already taken care of the only thing I wonder about is that the canister is modified with a couple of 5/8 holes drilled in based on what the TN kit told me to do so I don't know if that will be a issue later.
What pressure gauge do you mean for the UTEC? I already have a MAP sensor that supports up to 70psi installed so if you mean fuel pressure that's new to me. I figured just use a old standard dial gauge for tuning based on whatever Seth wants to do.
I am most likely looking at a mid April tune session now because I may not get my car on the road again for another week due to the clutch line and I want to diagnose the Passenger side rear tire noise that may be a wheel bearing about to die. Minor issues tho.
Old Mar 20, 2007 | 11:15 AM
redline350ZZ
My fuel return sys, Boost control solenoid and Injector plug and play clips arrived today.
Old Mar 20, 2007 | 01:05 PM
highmiles's Avatar
highmiles
thats great to hear man!
Old Mar 26, 2007 | 04:27 PM
bboypuertoroc's Avatar
bboypuertoroc
I'm curious to see what your setup can do. Sounds real mean bro.
