Pacific Alaska, Hawaii
Rear brakes suck....
Old Feb 22, 2007 | 08:35 PM
redline350ZZ's Avatar
redline350ZZ
Default Rear brakes suck....
So in my quest to solve the noise from the passenger side brake assembly I decided to get new pads and get the rotor turned.......well......lol....uh...yea the damn rotor was so rusted I wasted 3 hours trying to remove it so finally I went and bought a gear puller and ripped that joker out. Yes I did loosen the emergency brake gear to remove the tension it was just so damn rusted from being alive since early 2003
BTW to get rotors turned is 13.00 at checkers and I may upgrade later to a big brake hit not for now tho. I can't find a good pads anywhere so I just may end up getting a 50.00 ceramic set temporarily.
Old Feb 23, 2007 | 05:46 AM
andyisphat2004's Avatar
andyisphat2004
i had the same problem with removing the brakes on my wife's car. they wouldnt come off at all. i needed a rubber mallet and had to beat teh sht out of them.
andy
Old Feb 23, 2007 | 06:44 AM
redline350ZZ
I didn't want to beat them to see if they could be salvaged. We do like what only 20% of our braking in the rear.
Old Feb 24, 2007 | 08:37 PM
redline350ZZ
Damn got the brakes changed but the spring like squeak sound is still there. It changes while speeding up or down so crap IDK what it could be now. Need a second opinion.
lol, it's kinda like a duck "Quack" but more metallic like.
Old Feb 25, 2007 | 12:01 AM
andyisphat2004
is it the same as before? most pads will have a wear indicator which is probably what you had before. if hte noise is different now, it is probably due to vibration. did you put grease in there when you were installing them? there is also a vibration absorber (almost like a glue) that you can apply to the back of the break pads prior to installing them. oh yeah, and i dont think pounding with a rubber mallet does any damage.
andy
samansharif
Sep 25, 2015 12:31 PM
