Pacific Alaska, Hawaii
Water-cooled Turbo on the way.
Old Jun 5, 2007 | 12:00 PM
redline350ZZ's Avatar
redline350ZZ
Default Water-cooled Turbo on the way.
Well I just received a PM from Turbonetics and it looks like I will be able to get a water-cooled Turbo. This is awesome and if all goes well I can put my kit back on soon.
Old Jun 5, 2007 | 01:59 PM
636Racer's Avatar
636Racer
How much is the upgrade going to be? I may want to go this route if anything gets worse, or just to take preventive measures.
Old Jun 5, 2007 | 03:00 PM
redline350ZZ
I'm not sure on all the details but people with issues are having them fixed first.
Old Jun 6, 2007 | 02:45 AM
rr_z33's Avatar
rr_z33
i had a bad experience with turbonetics turbos. however theyre customer service +1
Old Jun 6, 2007 | 08:32 AM
andyisphat2004's Avatar
andyisphat2004
let me know $$ too,
Old Jun 6, 2007 | 12:43 PM
redline350ZZ
Yea the turbo stays hot long after cooldown. If you don't use the best oil it can coke on the internals. A water-cooled option will remove a lot of heat so it shouldn't be as much of an issue. This is one of those times that the best oil should be used.
Old Jun 6, 2007 | 02:38 PM
636Racer's Avatar
636Racer
Most of the guys I know who've used turbonetics turbos are fine with them, never had problems. A common upgrade for TurboBuick owners was the 60-1 turbo as well. But most of us (when I had my t-type) also made use of larger oil coolers as well, which was routed before the turbo. I'm thinking that it might be a better idea to just route an oil cooler before the turbo like my old car. The oil pressure would be static and shouldnt have much of a pressure loss. Gonna bring this up in the TN thread as well.
I'd like to know of any long term issue the wet bearing will have.
Old Jun 6, 2007 | 08:52 PM
punish_her's Avatar
punish_her
So this means your staying FI then?
So you still down with Todd comming out? Let me know man how things are going.
Old Jun 6, 2007 | 09:38 PM
redline350ZZ
Yes I spent 3 hours taking the kit off but hopefully I can get it back on in 5.
Old Jun 6, 2007 | 10:28 PM
punish_her's Avatar
punish_her
at least your getting practice.
Old Jun 6, 2007 | 11:00 PM
redline350ZZ
Oh yes I already memorized the parts I hate the most.
Old Jun 7, 2007 | 12:29 AM
andyisphat2004
brian,
are you gonna get the WG relocation?
Old Jun 7, 2007 | 12:52 AM
redline350ZZ
Originally Posted by andyisphat2004
brian,
I don't know if I need it
Old Jun 7, 2007 | 02:15 AM
rr_z33's Avatar
rr_z33
haha well good thing your doing it on your own. sonics has been pretty busy latley. punish is that your blue z outside of sonics?
Old Jun 7, 2007 | 10:30 AM
redline350ZZ
Yes
Old Jun 7, 2007 | 10:35 AM
andyisphat2004
brian,
i am leaning towards utec, are you still looking at flying htat tuner out/?
Old Jun 7, 2007 | 10:37 AM
redline350ZZ
brian,
We need to talk to Pun because we can 3 way spit the cost when he is ready.
Old Jun 7, 2007 | 11:17 AM
636Racer's Avatar
636Racer
Just be thankful that you didnt have to remove the exh. manifolds. I had to replace mines for the stock ones because I had those ceramic coated.
Old Jun 7, 2007 | 11:41 AM
andyisphat2004
yeah that is what i was thinking, he said just a plane ticket and dyno time right? hopefully i will be here through sept now
Old Jun 7, 2007 | 12:07 PM
redline350ZZ
I did remove them and heat wrap them without messing with the steer assy or draining coolant......ZING!!!
