Pacific Alaska, Hawaii
Powerlab Install!
Old May 1, 2009 | 12:44 AM
Junior_PR's Avatar
Junior_PR
Originally Posted by the7thsin
Congrats. I'm jealous. I miss my boosted cars! Like everyone has already said, get the feed/drain issue under control. You don't want to cook the bearings because of a small mistake. I'm sure you'll throw down some good numbers. Good luck.
thanks! is already fix! just waiting on tune
Old May 2, 2009 | 01:00 AM
Fishbone's Avatar
Fishbone
Looks good! Congrats Bro!
Old May 2, 2009 | 01:38 AM
ATX350's Avatar
ATX350
Thanks for the great pictures!!! This will help me greatly. May I ask what you used the grinder for? Is it necessary?
Old May 2, 2009 | 05:54 AM
Ghost_shift's Avatar
Ghost_shift
Great looking install.
Old May 3, 2009 | 05:50 PM
Junior_PR's Avatar
Junior_PR
Under the headlight, there was some metal that got in the way of the charge pipe coming from the IC. So i gring a lil to make the pipe fit better and male the install easier!
Old May 26, 2009 | 10:56 PM
bigfaa's Avatar
bigfaa
DUUUUUUUUUUUUUDDDEEEE!!!! hows this guy? =] so sick now with the turbo! that's a clean install and three days is actually not bad at all. Good job guys, TURBO + CARLOS = WIN!
Old Jun 4, 2009 | 04:41 AM
nosurf2day's Avatar
nosurf2day
How you liking the Power labs kit, I was thinking of switching to this kit or the momentum kit. I eventually want to go bigger numbers. I have the TN kit and put it in myself. It too is a pain in the **** but takes only a day if you stay on it.
I see you put down over 400 on which dyno? If its the same dyno as what I ran on, your numbers are much higher. Dyno Dynamics runs 12.5% lower than the standard that everyone goes by the Dyno Jet. My car is from what injected performance says should be putting down 447hp on the dynojet.
EDIT***Nevermind, i watched your dyno video, you were on a dyno jet.****
Your car sounds great!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
