Pacific Alaska, Hawaii
starting problem
Old Feb 19, 2010 | 09:22 AM
ni-z-mo's Avatar
ni-z-mo
Default starting problem
2007 350z stock about 39xxx miles 6-speed
I notice my car when I start it sounds like it is struggling before the engine actually turns. This recently just started. I checked my battery and the voltage is fine so I dont think its the battery. Any idea what else it could be that would make my car have a hard time starting?
thanks
Old Feb 19, 2010 | 09:34 AM
sn0's Avatar
sn0
Spark or fuel. Check those two systems.
Old Feb 19, 2010 | 10:31 AM
ni-z-mo's Avatar
ni-z-mo
I thought the spark plugs are suppose to last a long time cus they are iridium? my car is only 39xxx miles.
Old Feb 19, 2010 | 11:48 AM
abakja1's Avatar
abakja1
thanks
If for sure with a voltmeter your battery is good and >11.45 V or more (whatever you consider strong), it should "try" to turn over....Turn on your headlights to give you an idea that your battery has enough cranking power..
Check to be sure your terminals are clean and no acid or white powdery substance on it,..take a battery terminal cleaner to it and reconnect..
Highly unlikely is a blown alternator or battery fuse in the engine bay fuse box, or maybe fuel pump/injector fuse in the interior fuse box...
If it trys to start but doesnt start, then its not the battery or power...
Thats when you can get "mechanical" and look around in the engine bay for loose plug wires, disconnected items, etc...Did you work on your car recently or anything else different before the problem started?
Good luck..
Old Feb 19, 2010 | 03:09 PM
ni-z-mo's Avatar
ni-z-mo
i voltmetered it and it read 12.7V the call is stock no engine mods. Ive been doing all the oil changes myself thats about it. the car tries to start but it doesnt. but if i stop trying and wait for it to rest or something then it starts but not strong like it used to.
Old Feb 22, 2010 | 08:54 AM
GZire's Avatar
GZire
'07..........why not take it to the dealer? BTW I'd vid clip your issue so they don't pull the "cannot verify" thing on you.
Old Feb 22, 2010 | 03:57 PM
abakja1's Avatar
abakja1
Sounds like you are not getting enough juice to the car even though the battery is strong...Terminals are clean right? No white oxidation or acid oxidation on any of the cables or terminals? if so, clean it with terminal brush and spray with terminal protector after...for now, sandpaper is good enough..
If it was fuel problem, the car should crank strong and not weak like you are describing..
Old Feb 22, 2010 | 04:47 PM
ni-z-mo's Avatar
ni-z-mo
just fixed it, it was the battery even though the voltmeter measured the right voltage there wasnt enough juice coming from the batter. It was just weird cus the car is only 2 years old.
Old Feb 22, 2010 | 04:52 PM
toogood131's Avatar
toogood131
Same with mine, the stock battery don't last too long
Old Feb 22, 2010 | 05:00 PM
Waiz's Avatar
Waiz
I had a similar issue and found out it was the throttle body.
All issues went away when my shop put a new one in. The VQ both Z's and G's are known to have the same issue.
Old Feb 23, 2010 | 10:24 PM
abakja1's Avatar
abakja1
Was it an oem battery?
OEM should be done with in a couple years anyways...
Get a Optima battery as they got em at Costco and you can return if you have charging problems and your Optima battery dies out in less than a year.. Lighter than oem and plenty cranking power. Sears Platinum worked out the best in holding charge if you have stereo, lights, alarm as it did in my Subaru,..It seemed to hold power better than Optima, but it's like 2x heavier to me...
Uriyo_
Sep 8, 2021 08:46 AM
