Pacific Alaska, Hawaii
help removing hard water spots :/
Old Jul 2, 2011 | 01:45 PM
Towelie's Avatar
Towelie
Default help removing hard water spots :/
just like the tittle says does anyone on the island know how to remove hard water spots. this is something new for me I guess its from all the salt in the air or somthing lol. so I was woundering if anyone on here as had the same problem and what did they use to get rid of the spot. thanks a million
Old Jul 2, 2011 | 02:26 PM
415mm's Avatar
415mm
Professional
i had some really tough hardwater marks on my wheels and someone recommended a mix of vinegar and water to me and it worked really well. try 50/50
Old Jul 2, 2011 | 03:05 PM
Lefix's Avatar
Lefix
I used 3M Rubbing Compound, made the car shine like new afterwards
Old Jul 2, 2011 | 03:37 PM
1_BAD_Z's Avatar
1_BAD_Z
I've used this before with good results.
Old Jul 2, 2011 | 07:05 PM
GZire's Avatar
GZire
Was it a 50-50? I thought it was less vinegar?
Old Jul 2, 2011 | 07:20 PM
350ZTheStandard's Avatar
350ZTheStandard
What about 600 grit sandpaper??? Let us know how this works out for you.
https://my350z.com/forum/cleaning-an...-detailer.html
you can ALWAYS use the search feature
Old Jul 2, 2011 | 11:19 PM
scubadiver87's Avatar
scubadiver87
Just did work on my wifes black BMW using mequiars rubbing compound and then polishing compound. Worked very well if you ask me. All by hand too, takes a little time though. Could be a little overkill if it's just spots though. Someone I know also mentioned lime a way and water mixed 2/3 water 1/3 lime a way.
Old Jul 4, 2011 | 01:55 PM
mcsoap's Avatar
mcsoap
if its on the paint, it depends if the your waterspots are etched in. If thats the case, chances are your only options is wetsanding. but even then it gets difficult, i never tried the vinegar method. but im sure it only works to a point. 3m rubbing compound is the best!! lol be sure to correct the paint with a haze remover after you use compound
Old Jul 12, 2011 | 10:11 AM
island03z's Avatar
island03z
Mine was really bad cuz of the damn sprinklers next to my stall but I had to spring for a nice porter cable 7424 buffer and a good polish like pinnacle xmt #2. That stuff get's ANYTHING out including swirl marks. Even cut through paint burn that these detailers did to my boss' 911 turbo.
For window water spots go to Long's and get A-1 waterspot remover in the car section. It's amazing on windows but DO NOT get that **** on your paint [even tho it says its paint safe, it's not, I tried ]
ablaine
Nov 29, 2016 10:13 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
