GT Motorsports Turbo and NA/SC Spec Camshafts
Old Nov 30, 2006 | 08:12 AM
  #41
BrianLG35C's Avatar
BrianLG35C
Any details on their head packages yet?
Old Nov 30, 2006 | 03:03 PM
  #42
Nathan's Avatar
Nathan
Originally Posted by Sam@GTM
We are in the process of designing our site, so please bear with us. Until then, we will make the introduction of our products here.
Now: GT Motorsports® Camshafts
Our cams have gone through a lengthy and careful design process. We will be offering two different designs (both for the non-revup 2003-2004 model year cars for the time being; the latter design is currently in development).
1. GT Motorsports® Turbo Spec camshafts for the VQ35DE
2. GT Motorsports® Stage I NA/Supercharger camshafts for the VQ35DE
The GTM® Turbo Spec cams were designed by taking a complex set of variables into account. Turbocharger compressor maps and the flow characteristics of the VQ35DE were integral in developing the cam profile. The very specifications that were attained (following several revisions and countless computerized simulation trials) allow for the maximum possible volumetric efficiency over the broadest possible rpm range. Given the high exhaust manifold pressures (that exceed intake/boost pressures) found on turbocharged systems, volumetric efficiency, aside from duration/lift, is also dependent on internal exhaust gas recirculation, which is a function of intake/exhaust cam overlap. The specifications below minimize that overlap, while retaining the highest practical cam duration, to yield the highest possible performance.
Specifications
Intake: 256 deg (stock 238)
Exhaust: 264 deg (stock 240)
Lift: 0.423” (intake and exhaust)
Overlap: 18 deg (at 0.045” lift) – less than stock
GT Motorsports® Stage I NA/Supercharger Spec camshafts for the VQ35DEThe challenges of designing NA cams are much different from turbo cams. Much greater emphasis was placed on intake resonance, which has proportionally greater effect on performance than on turbocharged vehicles. Our research showed that to maximize volumetric efficiency, an asymmetrical lift for intake and exhaust was required, in addition to the asymmetrical cam duration. It was also found that a higher lift on the intake side paired with a slightly lower exhaust side lift, achieved the greatest performance gain on the broadest possible rpm range. Higher overlap in this case is possible, as reversion is not as much of an issue.
Specifications
Intake: 264 deg (stock 238)
Exhaust: 256 deg (stock 240)
Lift: 0.435” (intake) and 0.423” (exhaust)
Overlap: 22 deg (at 0.045” lift) – more than stock
Note: the cams are cut from chill cast billet (same as the OEM Nissan camshafts) and ground on factory centerline for perfect precision.
Availability:
Now
Prices:
1. GT Motorsports® Turbo Spec camshafts for the VQ35DE: $1165 (MSRP)
2. GT Motorsports® Stage I NA/Supercharger Spec camshafts for the VQ35DE: $1165 (MSRP)
Thank you.
Next: GT Motorsports® 6MT chromoly billet gears
This is not a criticism of your camshafts, but there is no known way that your turbo spec camshafts have less overlap than stock.
The specs of both the Inlet & Exhaust cams show a larger duration than stock. (I am assuming that these comparison durations are measured at the same lift)
As the exhaust cam is fixed (no VTC) the stock ex cam has a closing position of 8 deg ATDC, your cam has 24 deg more duration so the closing position of your cam will be aprox 20 deg ATDC.
The stock Inlet cam has a static opening position of -6 deg BTDC (that is 6 deg ATDC) Your inlet cam has 18 deg more duration than stock & in the static postion your cam would open aprox 3 deg BTDC.
Old Nov 30, 2006 | 03:27 PM
  #43
GurgenPB's Avatar
GurgenPB
UltimateSleeper
You can manufacture the cam to move the entire profile forward/backward (which retards/advances it's opening for the exhaust cam, opposite for the intake cam) relative to it's position markers (located on the aft plate). So yes, you do have longer duration, but it extends more into the intake/exuast strokes then the stock cams do, hence less overlap. This would be akin to having an adjustable cam sproket like they do on so many cars. THe VVT can't compensate, since it can only go by the cam position gaps on the signal plate of the cam, which are in an unchanged position.
Old Nov 30, 2006 | 04:18 PM
  #44
Nathan's Avatar
Nathan
Yes I am aware that the ground profile can be advanced or retarded on the cam blank ( JWT advertises a 2 deg advance on there inlet cam)
The stock cams only have 2 deg of overlap ( Ex 8 ATDC In 6 ATDC ) at there advertised duration which is measured @ aprox .010" lift.
GTM cams @ .045" lift are 18 deg overlap. This figure would be much higher @ .010". So how is 18 deg at best, less than 2 deg
Old Nov 30, 2006 | 08:07 PM
  #45
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Originally Posted by Nathan
This is not a critisism of your camshafts but there is no known way that your turbo spec camshafts have less overlap than stock.
No worries, not taking this as criticism, I will shed some light on your comments later due to my current time restraint .
Old Nov 30, 2006 | 08:13 PM
  #46
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Originally Posted by BrianLG35C
Are the turbo cams available/in stock from GTM or their vendors now?
Brian the cams are in stock .
Old Nov 30, 2006 | 08:26 PM
  #47
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Sorry for the delay ,things been really hectic lately,we will be posting the press release tomorrow with a lot of good detailed information .thanks for your patience .stay tuned
Old Nov 30, 2006 | 10:33 PM
  #48
redline350ZZ's Avatar
redline350ZZ
I'm waiting for my Turbo cams.
Old Dec 1, 2006 | 12:37 AM
  #49
sugarspunZ's Avatar
sugarspunZ
Me too
Old Feb 16, 2007 | 06:57 PM
  #50
Devil Z's Avatar
Devil Z
So these cams will increase my top end with no sacrifice of low/mid end power I presume?
I'm a newbie with camshafts so if someone please explain to me the full benefits of the Turbo spec Cams. They are something really affordable for me at this time so this might just be the next performance mod I make.
Old Jan 6, 2008 | 05:23 PM
  #51
JETPILOT's Avatar
JETPILOT
I installed the turbo cams and they are hot cams with the Greddy TT. The short overlap adds alot of meat to the powerband. It idles like stock. No one would ever know that they were instaleld by listening to the car idle. Definetly worth the money along with the JWT springs and retainers. Besides the Greddy TT kit this is the best mod I have done no question.
JET
Old Jan 6, 2008 | 06:23 PM
  #52
QuadCam's Avatar
QuadCam
Jet,
Your car has a fairly healthy cam lope at idle, I though when I hear it idling. It's not crazy, but it sounds like the car has bigger cam than stock. ......a bit of a rumpity, rump, rump sound to it.
Old Jan 6, 2008 | 07:14 PM
  #53
JETPILOT's Avatar
JETPILOT
I thought that was the exhaust. But your the second person to tell me that. My friend who is a mechanic says it sounded like cams. But you can't really hear much over those high output fans. They sound sick!
JET
Old Feb 15, 2008 | 03:41 AM
  #54
fwdracer1838's Avatar
fwdracer1838
HR cams avaliable yet?
Old Feb 25, 2008 | 12:18 PM
  #55
QuadCam's Avatar
QuadCam
I am curious to hear the response from GTM regarding less overlap on the turbo cams. It says that all cams are ground on the factory centerlines.....that being true.....how can you have less overlap than the stock cams? if you shifted the centerline, it would be possible.....
please enlighten us GTM...................................
Old Feb 25, 2008 | 12:19 PM
  #56
QuadCam's Avatar
QuadCam
I just noticed that this quote came 14 months ago. Maybe we won't have any "light shed" on us.
Old Feb 26, 2008 | 07:54 PM
  #57
g356gear's Avatar
g356gear
Any word or product announcements on N/A cams for the HR's yet??
EnjukuRacing
Sep 30, 2015 06:55 AM
