GT Motorsports® VQ35DE Head Packages
Old Dec 1, 2006 | 09:44 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Default GT Motorsports® VQ35DE Head Packages
We are in the process of designing our site, so please bear with us. Until then, we will make the introduction of our products here.
Now: GT Motorsports® VQ35DE Heads
We offer 5 stages of head upgrades. Here is what each features:
Stage 0:
Cleaning and inspecting cylinder head
Resurface cylinder head with an RA finish
Radius/5 angle valve job
Pressure testing cylinder head (cylinder head is disassembled completely)
New viton valve stem seals
(OEM valves and springs)
Stage 1:
Ferrea® valve springs
Ferrea® titanium retainers, locators, and keepers
Stage 2:
New exhaust and intake valve guides (bronze)
Machine spring seat to accept single or dual valve springs
Moderate port and polish
Ferrea® standard-size stainless steel valves
Ferrea® titanium springs (single or dual option)
Flow bench cylinder head
Stage 3:
Ferrea® 1.0mm oversize stainless steel valves
Install new valve seats
Ferrea® dual titanium springs
Stage 4:
Ferrea® 1.5mm oversize stainless steel valves
All cylinder head stages include something that no other head manufacturer uses: RA Finishing of the head mating surface. This is a finishing process that ensures the optimal finish for proper sealing of the head gasket. Simply machining the head perfectly flat is not enough. A mirror-like finish is not optimal to proper head gasket sealing. The RA finish puts the right amount of grit onto the surface of the initially machined head, helping it most optimally “bite” into the head gasket when the heads are torqued down to proper specification. This process has been proven by many OEM and performance builders to provide the best sealing possible. Chrysler vehicles, that were notorious for head gasket sealing issues, fixed their already problematic design by factory RA finishing of the heads. Combining this technology with the superior head design of the VQ35DE, allows for the best possible mating of the heads and the block of any internal combustion engine.
Availability:
Now
Turnaround Time:
2-4 weeks
Prices: (MSRP)
Stage 0: $1047
Stage 1: $1913
Stage 2: $3693
Stage 3: $4021
Stage 4: $5642
Thank you.
Next: GT Motorsports® Short/Long block packages
Pictures:
Note the first picture below. In the porting process, we machine out the portion of the guide for more superior flow. This has been done on very high end exotic race cars (Porsche). The last picture shows the Stage 4 (most extreme) porting available; note the large size of the port.
Attached Thumbnails -mvc-362x.jpg   -mvc-359x.jpg   -mvc-351x.jpg   -mvc-348x.jpg   -mvc-347x.jpg
Old Dec 1, 2006 | 09:51 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Default More pictures
This is the process of installign the new valve seats.
Attached Thumbnails -mvc-294x.jpg   -mvc-293x.jpg   -mvc-290x.jpg   -mvc-289x.jpg   -mvc-283x.jpg
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
This it the testing process for the RA finish that's put onto the surface of the heads.
Old Dec 1, 2006 | 09:52 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Some of the end product
Old Dec 1, 2006 | 09:53 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Some flow bench numbers
Here you can see the flow improvements between the stock and Stage 3 heads, obtained from our testing. This was the final product.
"Cyl 1" designation in the legend of the chart denotes the stock heads, while "Cyl 2" stands for the stage 3 heads, all shown as a function of valve lift. The improvement is evident between the two, to an extreme degree. Notice also that our cams, introduced a few weeks back, have a lift of 0.423"/0.435" (Turbo/NA), allowing the system to actually take advantage of the greater flow (see the chart and where .423-.435 lift falls on the graph).
Old Dec 2, 2006 | 12:02 AM
sugarspunZ's Avatar
sugarspunZ
I am impressed with your work. i cant wait to get mine installed and on the road. i am getting another job to afford all this madness.
Old Dec 2, 2006 | 12:15 AM
aalzuhair's Avatar
aalzuhair
Nice work Sam you guys are doing an excellent job in making the 350z on hell of a car .. Thank you
Maybe you guys can come up with a billet block on day
Old Dec 2, 2006 | 12:17 AM
jran76's Avatar
jran76
Looks great. Quality work, very impressive. Keep it up Sam.
Old Dec 2, 2006 | 12:22 AM
symalik's Avatar
symalik
nice stuff, great new products
Old Dec 2, 2006 | 05:14 AM
QuadCam's Avatar
QuadCam
thanks for posting the flow charts.
I remember someone stating that these heads flow upwards of 400 cfm per port and I was having a hard time believing it. thanks for showing your numbers!
Old Dec 2, 2006 | 03:56 PM
L.A. Roadster's Avatar
L.A. Roadster
Sam,
Will a n/a engine benefit from any of this? Or are you targeting FI specifically?
Old Dec 2, 2006 | 04:13 PM
Fairlady_z33's Avatar
Fairlady_z33
i must say that im truely impressed with your work Sam and your crew at gtm i just wish the prices wouldnt be so high but again great work
Old Dec 2, 2006 | 04:57 PM
priscilla ls1's Avatar
priscilla ls1
Working on any head and cam packages? Would you take a core exchange?
Old Dec 4, 2006 | 05:20 AM
dTor's Avatar
dTor
Originally Posted by L.A. Roadster
Sam,
This is the only way to make REAL power with any engine. Bolt-ons are just ancillary at this point.
So yes, n/a engines will benefit greatly.
Old Dec 4, 2006 | 08:12 AM
BamBam's Avatar
BamBam
Looking Good as always Sam..
Good job on getting the pics up for everyone to see the details of the hard work you guys do.
Old Dec 4, 2006 | 08:41 AM
sentry65's Avatar
sentry65
the burninator
how much more do the stage 4 heads flow compared to the stage 3 heads with the only difference being 1.5 mm instead of 1.0mm valve size increase?
Old Dec 4, 2006 | 08:51 AM
ChromiumBlue7's Avatar
ChromiumBlue7
same question here ^
Old Dec 5, 2006 | 01:20 PM
rcdash's Avatar
rcdash
are u sure that's not backwards? looks like the Cyl1 is flowing much more than Cyl2. I'm confused
Old Dec 5, 2006 | 05:15 PM
JRoC's Avatar
JRoC
Head package including cams?
Old Dec 5, 2006 | 08:23 PM
SPRacing's Avatar
SPRacing
What Stage Are Most Of You Guys Doing?
