Dynosty presents Walbro 485, E85 fuel pump
Old Mar 7, 2013 | 07:32 AM
  #41
str8dum1's Avatar
str8dum1
you have more than enough injector. you need more fuel pump
Originally Posted by 350z006
I'm trying switch to E85...my current setup uses 1000cc/Walbro 400 for 91 Octane w/ meth...I will also be running with an ATI crank instead of my fludampr, so my boost will probably increase as well...
So just to make sure I have some margin, how big should I go with the injectors to run E85? Or shoudl I just focus on upgrading my fuel pump to the 485 or a twin pump?
Old Mar 14, 2013 | 06:41 PM
  #42
OldManZ350's Avatar
OldManZ350
Any Info?
Originally Posted by phunk
I just finished building a custom twin pump assembly with one walbro 255 and one walbro 485. Its headed out to someone who is going to be testing it in a high power car that is converting to E85 i believe.
Should be interesting to see how all this pans out. It was a nightmare for me to assemble (will get better with practice im sure).
Old Mar 15, 2013 | 10:43 AM
  #43
str8dum1's Avatar
str8dum1
he swapped a 255 for 485 and then had to align the inlet with the hole in the canister.
I replaced one of my 255s with a denso hi flow. it doesnt align with the hole in the canister, but works fine. But for a production part, i'm sure Phunk wanted it all lined up.
Old Mar 25, 2013 | 12:56 PM
  #44
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Keep the sales coming!
Old Mar 25, 2013 | 03:47 PM
  #45
Ruthless18x's Avatar
Ruthless18x
Can you PM me price to ship my fuel basket to you for installation, including the price of the pump?
Old Mar 25, 2013 | 04:35 PM
  #46
OldManZ350's Avatar
OldManZ350
Did you guys ever get the Twin pump 255/485 worked out?
Old Mar 25, 2013 | 04:45 PM
  #47
rcdash's Avatar
rcdash
Yes they did! Hal needs to spend more time posting OR... Hal you could send me more pics of my car and I'd post for you!
Old Mar 29, 2013 | 12:37 PM
  #48
Dynosty's Avatar
Dynosty
Thanks for the orders keep them coming!
Old Mar 29, 2013 | 04:45 PM
  #49
phunk2's Avatar
phunk2
A couple were built, no problems reported yet, but mileage and use is unknown.
Old Mar 31, 2013 | 11:31 PM
  #50
ReStylin's Avatar
ReStylin
How much hp will the 485 max out on with ID1000 and the RFS that you sent me with cosworth rails?
Also do you have these in stock. If yes Send me invoice, I need it shipped Fedex Priority (Overnight) to Canada.
If you dont have these in stock, buy can garuntee me it by Thurs, send invoice
info@autovertising.ca
Old Apr 1, 2013 | 06:30 AM
  #51
Dynosty's Avatar
Dynosty
Max HP will depend on a few factors, such as boost which directly relates to fuel pressure which directly relates to pump flow. Assuming a great flowing system with minimal restriction, the 485 should support around 900WHP - while the injectors would support slightly less, around 850WHP. These numbers are estimates only, and based on WHP using gas as the fuel on our Dyno Dynamics. In your case, using the stock fuel pump hanger, there will be some restriction there thus lowering flow slightly.
They are in stock and we can ship out today.
Old Apr 2, 2013 | 04:04 PM
  #52
str8dum1's Avatar
str8dum1
they maxed one out about mid 600s on E85 on supras. So if you only run pump gas/race gas, you'd really just need 1.
Old Apr 2, 2013 | 10:21 PM
  #53
thatv35guy's Avatar
thatv35guy
That’d be awesome… I’m trying to run a single pump to make 550whp on E85…
Old Apr 3, 2013 | 10:52 AM
  #54
Dynosty's Avatar
Dynosty
Thanks for the orders!
Old Apr 12, 2013 | 01:44 PM
  #55
Dynosty's Avatar
Dynosty
Its Friday!
Old Apr 15, 2013 | 10:00 AM
  #56
Dynosty's Avatar
Dynosty
Up for a Monday
Old Apr 19, 2013 | 10:22 AM
  #57
Dynosty's Avatar
Dynosty
Old Apr 22, 2013 | 12:06 PM
  #58
Dynosty's Avatar
Dynosty
Great product! Thanks for the orders
Old Apr 29, 2013 | 10:19 AM
  #59
Dynosty's Avatar
Dynosty
Old May 1, 2013 | 10:13 AM
  #60
Dynosty's Avatar
Dynosty
