Shop Builds Temp moving posts for some clean up of this section.
*** GT Motorsports 4.24L Stroker Kit Preliminary Dyno Results ***
Old Feb 7, 2007 | 11:59 AM
  #61
Old School's Avatar
Old School
Shift_Boost
<~~~*strokes his rod while thinking about GTM's rods in the stroker kit.*
Old Feb 7, 2007 | 12:23 PM
  #62
Kenk2's Avatar
Kenk2
Professional
Dirty old man.. I didnt think you could get it up??
Old Feb 7, 2007 | 12:33 PM
  #63
IIQuickSilverII's Avatar
IIQuickSilverII
Old Feb 7, 2007 | 12:38 PM
  #64
Old School's Avatar
Old School
Shift_Boost
lol. I'm not that old. Sometimes it gets so hard, so fast....it jerks me clean out of my chair. lmao.
That is f*ckin hilarious!!! lmfao.
Old Feb 7, 2007 | 02:57 PM
  #65
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Good work Sam!
Old Feb 7, 2007 | 03:52 PM
  #66
r0mey's Avatar
r0mey
very nice job cant wait to see final numbers
Old Feb 7, 2007 | 04:19 PM
  #67
Z_rican's Avatar
Z_rican
Old Feb 7, 2007 | 06:00 PM
  #68
mraturbo's Avatar
mraturbo
Great work.
Hope to see the car soon.
M
Old Feb 7, 2007 | 09:36 PM
  #69
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Impressive build projects and power numbers on both cars! Like the others, I look forward to seeing the dyno results with 24PSI.
But I can't help but wonder and ask if running 24PSI on a motor bored and stroked to 4.24 liters is pushing the limits of the block? Is 24PSI really safe and reliable after increasing the displacement that much?
From what I've read, it isn't recommended to run 700+whp on a 3.5L without sleeving the block.
So Sam, what do you think is the most PSI you can run safely and reliably with your stroker kit?
Old Feb 7, 2007 | 11:33 PM
  #70
turismo's Avatar
turismo
I dont think you need to run a sleeved block until you get to the upper limits of 650-700, maybe a tad bit more. Sleeving is just for security reasons, but knowone has had a block fail due to sleeving. Even the ones that have made over 700hp
Old Feb 7, 2007 | 11:42 PM
  #71
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I think you misinterpreted what is said. I intend to get my block sleeved when I get my motor built. I wasn't suggesting that sleeving would cause the block to fail. I have concerns/questions about running high boost levels on a VQ block that has been both bored and stroked out to 4.24 liters.
Old Feb 8, 2007 | 12:42 AM
  #72
Triple8Sol's Avatar
Triple8Sol
Wow...I'm another guy waiting to see where this goes with some higher PSI. Curious as to what it would do NA as well...
Old Feb 8, 2007 | 01:09 AM
  #73
silver nismo's Avatar
silver nismo
Well done sam... just like the otheres can't w8 to see the 24 psi #s
Old Feb 8, 2007 | 08:11 AM
  #74
BamBam's Avatar
BamBam
<snip>
Sam's stroked engines have Darton MID sleeves, so I would think this alleviates the question as to loss of structural integrity when doing the overbore.
You can check out the first post in Sam’s thread https://my350z.com/forum/showthread....224931&page=11
Old Feb 8, 2007 | 08:27 AM
  #75
sentry65's Avatar
sentry65
the burninator
the question is can the structure of the block handle 24 psi reliably? I didn't know the issue of head lift was solved without some internal reinforcements
Old Feb 8, 2007 | 08:33 AM
  #76
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Thanks
That does alleviate my concern about the block. I checked out the link... that kit looks awsome and it's potential sounds promising.
Old Feb 8, 2007 | 08:39 AM
  #77
BamBam's Avatar
BamBam
Yea, I guess that is a good question. I don't think anyone has an answer to that at this point. The follow-up to that is what is a definition of reliable? I have to guess if you run your car hard, for an engine like this to last 2 years before a teardown for inspection would be a good bet.
I would also guess that 'most' people would not run their car on that boost level as it would be pretty difficult to control on the street. 24 psi would be a 'Race' map designed for race gas, short bursts and specific situations; not to be used on the street under daily driving conditions.
The people I have talked to say generally they run between 12 - 16psi on the streets or for everyday driving. I guess you make a scramble for the 24 psi, but you had better be sure you have really good gas first.
Oh, I forgot about the headlift question... As far as I know, the increased cooling mods and upgraded headstuds (torqued to the CORRECT specs) has resulted in no known headlift... I could be wrong on this, but that is my understanding in my discussions with a few different shops around the country.
--B
Old Feb 8, 2007 | 08:41 AM
  #78
InjectedPerf's Avatar
InjectedPerf
Injected Performance
Not sure the actual question as I am not currently running GTM's setup, but the actual block will hold 24psi. We have run 28psi so far.
--B
Old Feb 8, 2007 | 09:10 AM
  #79
Quamen's Avatar
Quamen
Another thought that came to mind is that HKS head gaskets are great for the unsleeved because they help the walls but I wonder if there would even be a gain on a sleeved block as sleeving seems to eliminate what the HKS gaskets were designed to do.
Old Feb 8, 2007 | 09:19 AM
  #80
sentry65's Avatar
sentry65
the burninator
well i'd love to see 24 psi, but the thing is that 24 psi on a 4.24 liter engine is a lot more power the block has to deal with than on a 3.5 liter engine
24 psi on a 3.5 liter engine = around 19.8 psi on a 4.24 engine in terms of power being made
