Shop Builds Temp moving posts for some clean up of this section.
MRC Motorsports: Presents Rome wasnt built in a day...
Old Dec 12, 2007 | 06:54 AM
  #101
tonester1011's Avatar
tonester1011
CF God
Nice!! Now Romes just gotta learn how to drive that bad boy!
Old Dec 12, 2007 | 06:55 AM
  #102
Audible Mayhem's Avatar
Audible Mayhem
My350z
very nice rOme !!
i bet youll get all the bitches now, drop top and big numbers!!
good job julian, very nice looking graph.
Old Dec 12, 2007 | 09:03 AM
  #103
ct350z's Avatar
ct350z
turn up the boost or ban!!!!
Old Dec 12, 2007 | 09:04 AM
  #104
BamBam's Avatar
BamBam
CONGRATS ROMEY...
That is looking like some AWESOME power and the graph is smooth too..
Enjoy man, but be safe this winter... Cold tires and wet/icy roads are not good for us guys will summer tires and gobs of power.....
Old Dec 12, 2007 | 09:08 AM
  #105
Philthy's Avatar
Philthy
Boost Junkie
Very nice ROMEY!
Old Dec 12, 2007 | 10:11 AM
  #106
Alberto's Avatar
Alberto
Cranky FI Owner
Very nice, I cant wait to see some race gas tunes
Old Dec 12, 2007 | 10:34 AM
  #107
taurran's Avatar
taurran
Nice powerbad. I'm interested in seeing how that will stack up with a built/sleeved APS TT.
About "smoothness" of graphs... anyone that's seen raw dyno data with no smoothing will tell you it's very rough and jagged. Some dyno brands seem to be prone to providing smoother readout than others as well.
Old Dec 12, 2007 | 10:40 AM
  #108
bacalhau16's Avatar
bacalhau16
Im sure the car is a blast to drive. I understand trying to play and safe and all, but I wouldnt think that something closer to 500whp, would be that much more abusive with your setup. Perhaps a couple different maps would be cool so atleast you can run more boost when you want.
Old Dec 12, 2007 | 10:49 AM
  #109
doug's Avatar
doug
i see you are still on page #1
Old Dec 12, 2007 | 11:34 AM
  #110
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The DD has no "smoothness" function to it, or a way to adjust it. It has really tight and fast sampling rate, which makes it all the more challenging to get a smooth graph. It picks up blips that other dynos will not.
The DJ has smoothing, and its usually listed in the upper left hand corner, as a value between 0 and 5. 0 is no smoothing, and 5 is max smoothing.
The dyno that has the capability to do HUGE smoothing is the Mustang Dyno. The filter value can be set to a mind-numbing level, so that only the most massive change in power will show a blip. With the filter level set very high, the graphs all look like they were drawn by a steady hand.
Old Dec 12, 2007 | 11:39 AM
  #111
IIQuickSilverII's Avatar
IIQuickSilverII
+1 id be nice to always see 0 smoothing or at least show if its used or not
Old Dec 12, 2007 | 11:41 AM
  #112
Sharif@Forged
Forged Performance
I agree....
We have the lowest reading dyno, and the most unforgiving when it comes to graph smoothness.
Old Dec 12, 2007 | 11:44 AM
  #113
doug's Avatar
doug
The DD has no "smoothness" function to it, or a way to adjust it. It has really tight and fast sampling rate, which makes it all the more challenging to get a smooth graph. It picks up blips that other dynos will not..
so if i get this right.. if shop A's dyno looks like the colorado rockies with DJ and shop B's dyno looks like a baby a$$ with DD.. it has nothing to do with software, but has to do with the tune ...
question.. would adding alot of timing on the top end cause the high RPM section of the graph to look like the colorado rockies? i am curious if the car was pulling timing it would cause that? just curious
Old Dec 12, 2007 | 12:23 PM
  #114
Julian@MRC's Avatar
Julian@MRC
Goot Gawt damn...Doug is back in full effect.
Old Dec 12, 2007 | 12:30 PM
  #115
doug's Avatar
doug
^^ no sir.. i'm just a curious observer <--- the smilies mean i am joking
Old Dec 12, 2007 | 12:53 PM
  #116
Jim@Showstoppers's Avatar
Jim@Showstoppers
Romes and Julian rule.
Now get on the other parts Rome.
Old Dec 12, 2007 | 02:20 PM
  #117
rcdash's Avatar
rcdash
Originally Posted by MRC Motorsports
DD raw dog..
My dyno reads about 7% higher than FP in GA due to the altitude and atmosphere.
How do you know?
Elevation in Spotswood, NJ is about 40 ft above sea level.
Elevation in Marietta, GA is about 1100 ft above sea level.
I believe there is a 1 psi pressure drop for every 2000 ft of elevation. So air density is actually less in GA by 1/2 psi.
Humidity is higher in GA. And this should serve to increase power output (I think) since increased humidity acts like increased pressure. I would think this serves to negate the elevation but I don't know by how much.
Anyway just curious how much data substantiates this 7% figure and if Sharif concurs. I would have hoped that two DD dynos would have read much closer, even uncorrected.
* The power curves look really good - kudos for time spent getting that kind of result.
Old Dec 12, 2007 | 02:24 PM
  #118
Julian@MRC's Avatar
Julian@MRC
Originally Posted by rcdash
How do you know?
whats the average barometer in GA?
Old Dec 12, 2007 | 02:29 PM
  #119
Julian@MRC's Avatar
Julian@MRC
Looks like 23.5 millibars from CWOP data over the last 26 weeks.
We on average arearound 29.5-30. A change in Barometer makes a HUGE difference on the HP output from region to region.
Old Dec 12, 2007 | 02:30 PM
  #120
rcdash's Avatar
rcdash
I take that back - it was the mean error from one of their recording stations - kind of useless - oops - hang on.
All I can get is current 30.1 in in Atlanta and 30.2 in today in Newark. Not much difference there.
EDIT: Anyway I thought I remember you saying someone had dyno'd at the two places (obviously at diff times) and it read lower, but I can't find that thread. Bottom line is that based on a single data point? (Fine if it is, not contradicting since I have 0 data points )
