Shop Builds Temp moving posts for some clean up of this section.
My Vortech dyno posted! 407.9whp
Old Dec 6, 2007 | 04:54 PM
invazn's Avatar
invazn
Originally Posted by 98MODMTR
Numbers can and have always been backed up at the track. If it puts down 407whp, it will trap appropriately.
so SlowHuH should run low 12's with good driving.
Old Dec 7, 2007 | 05:58 AM
THE TECH's Avatar
THE TECH
Originally Posted by Wired 24/7
Church's dyno is definitely not a WHP number. It is great for showing gains and tuning, but not great at replicating dynojet or DD results.
Can't say I totally agree with you there. The Dynapack is the closest to pure WHP numbers as you can get. With most other dynos, you are going to get lower numbers just due to possible traction or friction loss to the rollers. Also, this dyno, like any other dyno, is not meant to try to corroborate another dyno since they measure the hp somewhat differently.
Old Dec 7, 2007 | 06:34 AM
undrgnd's Avatar
undrgnd
You guys are overlooking the grounding kit. I was thinking the same as you until I saw the grounding kit in his mods. Now I'm convinced.
Old Dec 7, 2007 | 06:44 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
what gear did they dyno in?
Just weird to see the hp and tq graphs dip like that. Mine is about as linear you can get.
Old Dec 7, 2007 | 08:20 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
had to laugh at that
Old Dec 7, 2007 | 08:31 AM
carfi179's Avatar
carfi179
Originally Posted by Audible Mayhem
hey, its a dynopak, so the numbers are going to be really high.
i have no problem with people posting their numbers and being excited, just know when you are on a certain type of dyno, the numbers will be higher than normal. you would probably make around 360-370 on a dynojet.
congrats on the Vortech and have fun!!! there are a couple big dips in the graph though...
Nice explanation. Seems to be really high #'s with just few engine mods, I'll try to get dyno'd at church and see how it really compares to DJ at GTM.
Old Dec 7, 2007 | 09:17 AM
G35asian's Avatar
G35asian
Originally Posted by Hexxum001
I have the 2.87 pulley and have never hit 11psi. I got as high as 10.8psi before but never 11psi. So yeah, those numbers seem to be a bit off. But hey whatever. As long as the OP has a good tune and is having fun, that's all that really matters.
Tell me about, I was shocked too . I have my boost gauge warning set for 11psi and it actually went off that time when I was redlining 4th. I usually average around 10 - 10.5 at redline in 4th gear (this is tracked by my Utec datalogs and boost gauge, they are pretty parallel in readings). Remember that I have a non revup so my pulley layout is different then yours . Also, Triji who has a similar setup to me is hitting about 9.4 psi with his redline at the stock 6600 rpms. I am revving my car to 7000-7100 which helps to build more boost up top
Old Dec 7, 2007 | 07:46 PM
Triji's Avatar
Triji
Yup, I hit 9.4 pretty regularly... Heck, I'll take a pic of it tomorrow... Gotta ignore my AFR's in the pic tho cause when I recall top peramiters my AFR's read 9.6 cause of the spike right as you let off of boost.
Old Dec 8, 2007 | 11:08 PM
DMK's Avatar
DMK
I hit 10psi on the stock pulley around 7000 rpms. Data logged with the SS box recently. Probably due in part to the colder weather in Socal.
Old Dec 20, 2007 | 04:12 PM
str8dum1's Avatar
str8dum1
sorry to bring up an old thread, but you guys do realize that the dyno sheet themselves say flywheel HP. So of course his HP is correct. Its not RWHP
Old Dec 20, 2007 | 04:22 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
...could have been a typo.
The high hp numbers are due to the grounding kit he has as someone already stated
Old Dec 20, 2007 | 05:28 PM
Cannysage's Avatar
Cannysage
wrong. they take off the wheel and hook up the machine directly to the hub, but it's still whp this prolly explain the higher numbers but its very accurate, in terms of measuring gains. It would've been nice if the op had a base dyno, at the same shop.
Old Dec 20, 2007 | 11:36 PM
MOTOWIPEOUT Z's Avatar
MOTOWIPEOUT Z
Never mind the dyno debate. Enjoy that new power, congratz!
Old Dec 20, 2007 | 11:41 PM
iStan's Avatar
iStan
ZR
+1
How does a normal consumer get true flywheel hp measured?
Old Dec 20, 2007 | 11:49 PM
sentry65's Avatar
sentry65
the burninator
actually there is a type of dyno called a MAHA dyno that all the german car manufacturers use that can measure flywheel hp within 1 or 2 hp. It's kinda complicated how it does it. There's only about 5-6 of them in north america and pretty much is the most expensive dyno made selling for around $200k
Old Dec 20, 2007 | 11:54 PM
iStan's Avatar
iStan
ZR
^Thus, normal consumers will NOT have flywheel dynos. The End.
Old Dec 21, 2007 | 12:47 AM
  #38
sentry65's Avatar
sentry65
the burninator
hehe, well I know a local shop to me that's getting one and having a wind tunnel built with it to generate 80mph wind
Old Dec 21, 2007 | 12:56 AM
  #39
DMK's Avatar
DMK
Even though the dyno says Flywheel, its actually whp. The print out for a dynapac always has "Flywheel" at the top. You have to look at the TCF (Transmission Correction Factor). If it's 1.0 then is whp, if its 1.15 then there is a 15% correction factor in there.
Old Dec 21, 2007 | 07:34 AM
  #40
G35asian's Avatar
G35asian
I'm assuming that you are referring to Dyno Comp? Damn, do they have money to spend or what! I guess thats what happens when you service ferrari's, lambo's, porsches, etc. lol
