Shop Builds Temp moving posts for some clean up of this section.
Forged Performance: Cosworth Plenum test on Philthy's Car
Old Jan 23, 2008 | 04:28 PM
IIQuickSilverII's Avatar
IIQuickSilverII
Sharif..on a 350z do you think the strutbar will still fit even with the cosworth planum plus that spacer???
Old Jan 23, 2008 | 04:29 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by Motormouth
scramble boost on the passenger side center console? weird.
It's a timed duration scramble boost...not something you have to keep your finger on.
Old Jan 23, 2008 | 04:30 PM
Sharif@Forged
Forged Performance
The GT Spec Carbon bar fits easily. I'll have to try a stocker on L's car the next time its in here....or on Dilsher's car.
Old Jan 23, 2008 | 04:31 PM
rrmedicx's Avatar
rrmedicx
Thanks Sharif for showing that spacer too. I heard that Cosworth didn't think long and hard enough about most of us that have aftermarket fuel components and that the plenum simply wouldn't fit. Nice to see that theory didn't hold up.
Is that spacer a Forged Performance piece? Glad to see the plenum is still do-able for those of us that have upgraded fuel parts. It looks like it is supposed to be there. Very clean.
Thanks for sharing.
Old Jan 23, 2008 | 04:36 PM
IIQuickSilverII
Thanks for sharing.
i think the spacer is a MD product...i think Injected has 'em too...
regardless i am glad to hear sharif saying that i wont be loosing my strut bar i was worried
Old Jan 23, 2008 | 04:43 PM
thawk408's Avatar
thawk408
Originally Posted by Sharif@Forged
That test is ALL YOU man! Ready when you are!!
LOL, why stop at 20?
I always though scramble boost was very unsafe. How does it work?
Old Jan 23, 2008 | 04:54 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
+1 for an explanation of scramble boost
Old Jan 23, 2008 | 05:07 PM
Crom's Avatar
Crom
+1...is it wired into to fcon to change anything other than the amount of boost for a set time ?
Old Jan 23, 2008 | 06:36 PM
Sharif@Forged
Forged Performance
When the button is depressed, it activates a higher boost level on the HKS EVC6 for a set period of time, such as 30 seconds. The way I setup the FCON mapping, we can run one map per fuel octane level...not per boost level....so it makes it safe and convenient to switch to higher boost on the fly, but for a short period of time. If you want high boost all the time, then simply change the setting on the boost controller directly.
Old Jan 23, 2008 | 06:39 PM
Crom's Avatar
Crom
..Thanks...^ You could get in trouble w/ a button like that.
Old Jan 23, 2008 | 06:40 PM
monokuroboo's Avatar
monokuroboo
CHRIS (350) FTL
haha just don't have a boost-happy passenger
Old Jan 23, 2008 | 07:22 PM
doug's Avatar
doug
the red button is for ejecto seat cuz
Old Jan 23, 2008 | 07:31 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
Looks awesome, should have it polished.
Old Jan 23, 2008 | 07:41 PM
Zivman's Avatar
Zivman
Now for the results, with testing performed at low boost.
The overall peak power increase was a modest 13whp, but the change in power at 6600rpm is a huge 30whp. The Cosworth plenum definately flattens out the power curve towards redline, and results in a larger power gain as redline approaches.
Was this just running the car on the previous tune? If you retuned with the addition of the plenum, can you comment on any affect it had on the AFRs?
Old Jan 23, 2008 | 08:00 PM
ibkarlito's Avatar
ibkarlito
1) If you have upgraded fuel rails, and longer (non OEM) injectors, you will need one of these: Cosworth Plenum Spacer Kit This gives you the clearance needed to run upgraded fuel rails and larger/longer injectors.
Looks good!
Can you elaborate on the "Cosworth Plenum Spacer Kit??"
Does it come with the Plenum??
Optional??
Cost??
Different sizes offered (ex. 1/4" or 1/2")??
....if so - what size was used for these tests??
Do you expect to yield different results Depending on size of spacer?? Worth trying??
Additional waiting period for this kit??
Same as MotorDyne spacers??
The results look promising - thanks for sharing Sharif!!
Karl
Old Jan 23, 2008 | 08:10 PM
jumpin800agl's Avatar
jumpin800agl
8 to 11
Results certainly look promising. Congrats to Philthy and Forged.
Old Jan 23, 2008 | 08:14 PM
copec's Avatar
copec
Those look like great gains to me! I love to see flat top ends like that, the mean hp has significant gains across the whole rpm band!
Sorry for my crappy search skills, what other mods does this car have? Does it have ported heads and/or different cams?
Old Jan 23, 2008 | 08:16 PM
  #38
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Nice work Forged!
Great looking car Phil! Very clean and well thought out.
I was stressing this session more than I bet Phil was. I am soo glad this thing holds boost, and I just happen to get a dud.
I can wait to make it back from Vacation and try again.
Thawk408!!!
You will see 20 plus PSI (knock on wood) when I get back.
Old Jan 23, 2008 | 08:18 PM
  #39
eagletanggreen
Got Track!!!!!
When did those turbos hit full boost....like 2500rpm?
Old Jan 24, 2008 | 02:21 AM
  #40
Philthy's Avatar
Philthy
Boost Junkie
This thread is useless without some VIDS!
Thanks for posting the results up, Cosworth Plenum is a hit IMO...
