Shop Builds Temp moving posts for some clean up of this section.
SP Project G35 Sedan.... MONSTER!
Old Jun 15, 2010 | 06:49 PM
  #241
GBoger's Avatar
GBoger
daaayyyyuuuummm. That curve is teh sex
Old Jun 16, 2010 | 06:49 AM
  #242
str8dum1's Avatar
str8dum1
Originally Posted by Reid@SP
UPDATE: The car made 833whp @ 25psi (uncorrected) and 848whp @ 25psi (corrected). It was spinning the tires at that power level which won't do much for power numbers but it's going to be killer on the drag strip when it gets the power down. Look at that power curve!!
So when are you actually going to run some real boost?
Old Jun 16, 2010 | 06:53 AM
  #243
SoundPerformance's Avatar
SoundPerformance
Sound Performance
Id love to turn it up!! Unfortunately all the pulls at over 30 psi just resulted in a huge amount of tire smoke. We even tried to VHT the dyno rollers!! It helps quite a bit. We cannot put any weight in the trunk to aid traction because then the tires rub badly. The damn G35 sedan wheel wells are just too small!!
Old Jun 16, 2010 | 07:09 AM
  #244
BornSlippyZ's Avatar
BornSlippyZ
Love that dyno sheet Op!
Old Jun 16, 2010 | 08:05 AM
  #245
thom000001's Avatar
thom000001
Swap the whole engine/trans setup into my car to make dyno pulls!!!!!!
Tom
Old Jun 16, 2010 | 08:27 AM
  #246
QuadCam's Avatar
QuadCam
Time to tub it out with a 4 link and a 9".......wheelie time in the sedan!!!
Old Jun 16, 2010 | 08:38 AM
  #247
str8dum1's Avatar
str8dum1
any idea what rpms those speeds relate to? 134 around 8000 rpms?
Old Jun 16, 2010 | 08:46 AM
  #248
SoundPerformance
Sound Performance
5500 - 7200
Old Jun 16, 2010 | 08:56 AM
  #249
str8dum1's Avatar
str8dum1
strong work. 4.0L on those 6262s looks MUCH better than on my 3.5L
was this thru an exhaust?
Old Jun 16, 2010 | 09:00 AM
  #250
SoundPerformance
Sound Performance
Yes actually through the stock muffler with one of our boost actuated cut outs !!
Old Jun 16, 2010 | 10:49 AM
  #251
str8dum1's Avatar
str8dum1
lol, so no exhaust
Old Jun 16, 2010 | 08:21 PM
  #252
Reid@SP's Avatar
Reid@SP
lol, so no exhaust
It is basically no muffler really. The cutout is located directly before the stock muffler so it is still going through the Y-pipe and all through the rear.
Reid
Old Jun 16, 2010 | 08:24 PM
  #253
Reid@SP's Avatar
Reid@SP
Yeah it was sort of a double edged sword scenario. If we turned the boost up higher than 25psi, the tires would spin. Then if we put someone in the trunk, the tires would rub! Something will have to be done here, most likely some major fender rolling.
Reid
Old Jun 17, 2010 | 09:29 AM
  #254
GBoger's Avatar
GBoger
get er done
Old Jun 28, 2010 | 10:45 PM
  #255
Andrei's Avatar
Andrei
Reid
It's not even past 30 PSI yet. Updates?
Old Jun 29, 2010 | 08:42 AM
  #256
SoundPerformance
Sound Performance
Cant do anything until the tire issue is resolved!!
Old Jul 11, 2010 | 11:40 AM
  #257
SoundPerformance
Sound Performance
Small update. Yesterday at the RPM car show in chicago, this car won the dyno competition!! They used GRD's Dynapack dyno which only reads up to 800 RWHP but at reportedly only 17 psi this G35 pegged the dyno!!! A few other cars that we built also pegged the dyno but they gave top honors to this G35 probably because it did it at the lowest boost level! Congrats Vlad!!
Old Jul 11, 2010 | 11:45 AM
  #258
str8dum1's Avatar
str8dum1
guess there were no FI 6.0L V8's?
800whp at 17psi on a DD when you only made 640whp at 17psi......
I wanna get dyno'd at GRD for sure then!
Old Jul 11, 2010 | 11:47 AM
  #259
SoundPerformance
Sound Performance
guess there were no 6.0L V8's?
Yeah, those numbers do seem high to me too but I can say that the G35 has SERIOUS traction issues on our dyno. Maybe with the DD dyno that actually attaches to the axles it gave a true reading??
Old Jul 12, 2010 | 09:31 AM
  #260
SoundPerformance
Sound Performance
Sorry, I was misinformed. He pegged the dyno at 25 psi. Not sure what he made at 17 psi.
