Shop Builds Temp moving posts for some clean up of this section.
SP Project G35 Sedan.... MONSTER!
Old Apr 3, 2011 | 07:52 PM
  #281
GBoger's Avatar
GBoger
Old Apr 10, 2011 | 10:41 PM
  #282
Reid@SP's Avatar
Reid@SP
Sorry guys, been very busy over here lately. I'm working on getting the dynos and video up!
Reid
Old Apr 14, 2011 | 10:17 PM
  #283
Reid@SP's Avatar
Reid@SP
Originally Posted by str8dum1
dunno.. their 3.5L shop car made 1026 at 27psi. IP is making 775dynodynamic at 27psi on their 3.5L as well. This a 4.2L stroker (20% bigger!), albeit thru a lossy tranny.
But with that tranny, he should only need ~700hp to chop high 9s passed, if it can hook with 1.3-1.4s 60'. transbrake TH400 on the strip FTW!
The 4.2L isn't going to make any more peak power than a 3.5L, the real difference will be in the mid-range. This thing spool so fast!!
Old Apr 15, 2011 | 06:45 AM
  #284
midz350's Avatar
midz350
Update? dynos and videos?
Old Apr 15, 2011 | 08:06 AM
  #285
str8dum1's Avatar
str8dum1
well that assumes you didnt match the heads/cams to the new flow or adjust the turbine A/R either to compensate for increased flow......
Old Apr 26, 2011 | 06:24 PM
  #286
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
BUMP
Old May 12, 2011 | 07:56 PM
  #287
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Question
Vlad is very excited for the upcoming season. Before when the car was on the dyno, we couldn't do anything past 25psi without the tires rubbing. The fenders have since been very slightly widened and we had it back on the dyno to be sure it would clear the tires. All is good now!
We have also integrated the e-throttle control with the ProEFI. I'll have some videos shortly of the car on the dyno. It makes excellent power and spools unbelievably fast. The converter is also perfect for the drag strip which will be very obvious once I post up dyno charts. Much more to come!
Reid
So what happened? What were the dyno results?
Originally Posted by RudeG_v2.0
Glad to hear the good news!
I forget from our past discussions... What is the stall set at on that torque converter and what gear does he have in the rear end? Don't Supras typically run a 3.7 gear in the rear end with that trans?
^ Also BUMP for an answer to my prior post.
Old Jun 21, 2011 | 08:11 PM
  #288
Reid@SP's Avatar
Reid@SP
http://www.youtube.com/watch?v=jKdf6VOS7RY
The car makes approximately 1300HP to the crank with the TH400 trans!!
Final Number: 951whp @ 30psi
There is a lot of room left in this setup. The turbos won't lose their efficiency until well into the high 30psi realm if not higher. This will be an excellent start to get Vlad deep into the single digits.
Old Jun 21, 2011 | 08:26 PM
  #289
str8dum1's Avatar
str8dum1
awesome power thru that tranny! thats exactly how i have my exhaust as well
do you know the spring rate on those rear springs?. I wanna swap to those SPL toe arms as well. Toe bolts suck
*and i didnt get that iBoost switch in the package from Jason
Old Jun 21, 2011 | 08:45 PM
  #290
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
VERY NICE! Congrats!
Still curious about what you guys have the stall set at and what gear you're running in the back.
  #291
Reid@SP's Avatar
Reid@SP
I'm not sure on the suspension, maybe Larry can chime in on that. I'll call Jason first thing tomorrow for you for the iBoost setup!
Reid
Old Jun 24, 2011 | 03:39 AM
  #292
Andrei's Avatar
Andrei
This sedan picked up where the SP 350z left off. Will it run the same time or better? I see the custom diff brace with support on both sides. Very nice.
Old Jun 24, 2011 | 04:38 AM
  #293
Reality350's Avatar
Reality350
Holy Fukn sleeper!
Old Jun 24, 2011 | 06:09 AM
  #294
thom000001's Avatar
thom000001
The 350z had a 6spd trans...this has a Turbo400 auto.....all things being equal, this should be quicker....
tom
Old Jun 24, 2011 | 06:35 PM
  #295
str8dum1's Avatar
str8dum1
should be ALOT faster. look at the TH400 cars VTR runs. their traps are pretty slow but their ET's are almost a second faster than similarly powered manuals
Old Jun 25, 2011 | 07:01 AM
  #296
TTRANK's Avatar
TTRANK
Awesome power, that thing is going to shock some people!
Great work as always.
Old Jun 25, 2011 | 07:20 PM
  #297
Resmarted's Avatar
Resmarted
Sounds AWESOME.
Great job guys!
Old Jun 28, 2011 | 12:14 PM
  #298
GBoger's Avatar
GBoger
hello 8 flat
Old Jul 5, 2011 | 10:09 PM
  #299
Phamspeed's Avatar
Phamspeed
Wow this is an amazing car!!
Old Sep 3, 2011 | 04:20 PM
  #300
luxxxz's Avatar
luxxxz
i think i seen ur car somewhere, you around midway airport ever? cause of those rims i think i saw it
