VR3: My 2003 350z SP build 621whp 534wtorq @ 18.3psi. on 93oct
well only similarity is that both put the turbo's in about the same location and use a tubular manifold....beyond that they are diff, well as diff as they can be with the limited amount of space to play with there. Gonna look similar but really....one uses a burns collector other doesn't. Bend radius's aren't even close though....
They both bend in on each other which makes them look similar
Note *ever looked at the supra mani's......like 6 diff manufactures and they all look the same lol.
Note 2 - on drivers side looks like SP is trying to get a little more length on the rear tube by going forward more. And on the pass side it looks like SFR is getting a little more length on the rear tube in the same manner lol....I can't tell on primary sizes from the pics though, my eye's aren't that good lol.
SP
even less room on this side
SFR
This is similar but radius's are still much different....don't know the diff between the two from SFR though
And something even completely different....Stillen header
Tom
SP
SFR
Tom
on
My SFR do not have burns collectors. I believe mine are like the second SFR picture you have posted above.
Found pics of my manifolds I took along time ago.
I like this:
Compared to: Coolant pipe is right above the turbo on this setup. But it does have a shield looks like.
Professional
Those are very good points, and the SP and SFR manifolds are very good. There is an issue, however, when using stainless steel manifolds on cars that are going to be tracked on road courses; they tend to sag over time. In fact, before I purchased my GTM turbo kit, I was very, very close to going with the SP kit. Although SP did not think sagging was going to be an issue, they could not guarantee it would not happen over time if I track my car a lot. They were very straight forward and honest with me, nonetheless, and I really appreciate that. If someone wants stainless steel manifolds, I would have no problem referring them to either SP or SFR.
ya but those log manifolds dont have to use an oil sump and oil pump which is an extra system that can fail and destroy your motor.
Log manifolds can also spool faster since the turbo is closer to the exhaust ports. All depends on what you want. for a street car, logs are great. for a drag car, headers are better.
on
All kidding aside....I agree with you and Terry....If you are drag racing ...There is nothing better then SP/SFR.....
But I want everything on one setup.....and the SS setup could not provide that for me on a road course....and lag of that extent would not make it fun for my driving style.......
I use to have SS on my GT1 to extend the Twin Turbo's in the rear for better cooling....much more lag.... After a few hours of beating on it.....it was glowing red....It did not sag....but cooling and heating it to those temps..I am sure it would....I had to go back to cast iron mostly to shorten the distance to get less lag.
on
I don't like the Greddy ones because the turbos are inside the engine bay right next to the heads and close to the stock cast coolant pipe running to the back of the engine. These SP manifolds position the turbo lower and away from the engine bay. And I like the SFR ones also because of it. But everyone can use whatever their opinion is of what is better. I don't care.
Heat shields works wonders ....
^^^ yup heatshields due work....
I am not as even concerned of the whole log vs tubular mani's (thats not why I went the route I did)......
I find it interesting that people will still want to make serious power on internal wastegate turbos, and wonder why they can't hold more than 12psi of boost past 4500rpm.....(not directed at mike's setup obvioulsy, the WG is right there visible).
And I personally like the smoother flow of the downpipe's on the more remote located turbos (SP/SFR) vs the 2 harder turns for the turbos being tucked up...but thats just personal prefference.
tom
tom
on
tom
tom
#38
5000 degrees and titanium >>>> 1500 degrees and steel lol
Tom
Tom
#39
on
