Old 01-19-2017, 03:18 PM
  #12521
Received 3,271 Likes on 2,328 Posts
Originally Posted by dboyzalter
Anywho got some good pictures for you jerks who think getting the exhaust off is easy
Mike loves showing us his salvage findings from the Titanic.
Old 01-19-2017, 04:42 PM
  #12522
HRMoneyPit
HRMoneyPit's Avatar
Socal FTW!
The following 2 users liked this post by HRMoneyPit:
CK_32 (01-20-2017), pyshin (01-19-2017)
Old 01-19-2017, 07:33 PM
  #12523
the rook
the rook's Avatar
Put Zeke in the shop to get the front lower ball joints installed and get a front and rear alignment after I installed my kinetics rear camber gear and oem sway bushings front and back. Hopefully I get some noticeable increase in handling :-)
Old 01-20-2017, 02:51 AM
  #12524
To my amazement I was able to get 3 bolts off.
Wonder if those 02 sensors are going to play my game.
Old 01-20-2017, 05:09 PM
  #12525
the rook
the rook's Avatar
Alignment specs with adjustable rear camber and toe arms. Stick toe bolts.
Old 01-20-2017, 05:23 PM
  #12526
Originally Posted by the rook
Attachment 380538
Looks like your next endeavor is adjustable FUCAs. Heh heh....
But wait....
How's steering response? You should definitely feel it sharpened up with the new +toe settings and good caster numbers.
You lucked out on the rear toe.
Old 01-20-2017, 05:39 PM
  #12527
the rook
the rook's Avatar
But wait....
Yeah I got some fortune on the toe.
As for the front.... I will go with adjustable hardware after I decide to buy a full coilover setup.
The camber adjustment raised the rear up a quarter inch or more and I can't stand the sight of it. Lol.
Looks like rolled fenders and a good DD coilover set are in the future for me. I'm assuming if I go lower I'll have to use my extended toe bolt kit (at least I already bought it). The alignment shop also recommended camber shims if I go lower. Honestly never heard of them but I'll be researching in bed tonight.
I'm well aware that I'm pushing for a far less practical stance but I have a vision for the appearance of my Z and I cannot shake it. Stupid. Obsessive. Impractical.
Well that about sums my 38 years on this planet up!
Old 01-20-2017, 05:41 PM
  #12528
the rook
the rook's Avatar
But wait....
Oh and steering response and cornering are drastically improved. The alignment, roll center ball joints, and sway bar bushings made a huge difference.
Poly bushings in the camber gear are undoubtedly helping as well.
Old 01-20-2017, 06:45 PM
  #12529
jhc
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
Jesus, Mary and Joseph. Mike, you have my sympathy and a can of PB Blaster and Liquid Wrench otw.
Looks like your SawsAll is in good shape!
Old 01-20-2017, 07:01 PM
  #12530
CK_32
CK_32's Avatar
A can?
That's like giving a water bottle to a Forrest fire. I don't think that's enough lol
Old 01-21-2017, 05:23 AM
  #12531
That $20 harbor freight sawzall was the best $20 I might have ever spent. I just hope it stays strong when I start cutting the car into pieces... Im getting sick of looking at it out in my yard. And I have other things on the to do list come spring time... This mild January in the northeast has been most appreciated.
Old 01-21-2017, 05:26 AM
  #12532
the rook
the rook's Avatar
I put my Harbor Freight Sawzall through mortal hell and it seems to be holding up fine. Lol. It's about a 50-50 chance on Harbor Freight stuff as to whether it's going to last or not I guess. But my grinder is also holding up strong.
Old 01-21-2017, 06:35 AM
  #12533
Their $6 02 sensors tool also worked like a champ. And the breaker bar has exceeded my expectations. Now that I can't find anything made in America at sears harbor freight is my spot.
Got another manifold bolt out... The last 2 are presenting me with a bit of a challenge even with the vice.
Old 01-21-2017, 06:55 AM
  #12534
the rook
the rook's Avatar
The only thing I had to do to my breaker bar for Harbor Freight was put Loctite on that Phillips screw because it kept backing itself out.
I was not aware they made the socket for O2 sensors but I will be purchasing that very shortly. Lol
Old 01-21-2017, 07:18 AM
  #12535
the rook
the rook's Avatar
Front plate delete. Paint matches far better than the pic.
Gotta get around to the rear wiper delete at some point.
Old 01-21-2017, 07:23 AM
  #12536
Serhat Yildizci
Serhat Yildizci's Avatar
Default much needed wash
Washed mine inside and out and getting around to claying it definitely makes you feel better about your car!
Old 01-21-2017, 12:34 PM
  #12537
I got this one, worked out great and offered more clearance for removal with without cutting the wire.
http://m.harborfreight.com/3-8-eight...nch-97177.html
Got the other 2 out of the catalytic converters. One came out good one got messed up.
Got my bleeder screws out of my rear brembo calipers... So I only messed up 1 out of the 8... We will see how that pans out.
Took apart the interior of the G... Another few days and its sawzall time... The wiring is crazy for these cars.
And I only had one minor set back
Old 01-21-2017, 02:43 PM
  #12538
CK_32
CK_32's Avatar
That's a bust.. hate when that happens. Especially when ever oil and dirt crum finds the cut.
dboyzalter (01-21-2017)
Old 01-21-2017, 02:51 PM
  #12539
CK_32
CK_32's Avatar
Got my brake and lamp inspection done, next is smog.
Old 01-21-2017, 02:58 PM
  #12540
BluestreamDE
BluestreamDE's Avatar
Hit 450 miles on the new motor. Gradually laid in some boost to about 5500 rpm. Z was screaming and pulling pretty well from the previous tune I had before with the stock motor and HFCs, just running kinda lean (12.5afr) to about 5200rpm so I let off the gas. Excited on the retune at the end of the month.
