Vortech v3 Project from over the pond...
Old Jun 14, 2010 | 01:24 PM
tylerxfire's Avatar
tylerxfire
go with the motordyne xyz for sure...
2.62 pulley has been used and talked about...it is overspinning the blower..the 2.87 is technically overspinning the blower at 6600 rpm according to vortech
Old Jun 14, 2010 | 04:02 PM
350z006's Avatar
350z006
+1 on Motordyne XYZ
+1 on overspinning with a 2.62 pulley...unless you purchase a 928 impeller ...
Old Jun 15, 2010 | 02:25 AM
wizard's Avatar
wizard
Originally Posted by zerosec
what EMS are u goin to use ?
Orisis Uprev
Old Jun 15, 2010 | 04:20 AM
Erdem's Avatar
Erdem
nice list!!!....
good luck with it bro
I talked with Mark @ Abbey today...
and I think I'm going to do little road trip soon, hopefully..
Old Jun 16, 2010 | 01:11 AM
wizard's Avatar
wizard
Originally Posted by Erdem
nice list!!!....
Thanks!
Better have your bank manager on speed dial!
Let me know when you plan to come down, we'll hook up at Abbey...
Old Jun 17, 2010 | 01:47 PM
zerosec's Avatar
zerosec
Originally Posted by wizard
Orisis Uprev
u can't go wrong with uprev
Old Jun 18, 2010 | 07:03 AM
binder's Avatar
binder
i modified a generic a pillar.
system setup looks good. I wouldn't worry much about the cosworth. For the gains you'll get it isn't worth the cost.
why aren't you running the 2.87 pulley? depending the dyno you might need to go to a 2.87 to get 400hp.
400hp is plenty safe on that engine because it won't have near the torque that a 400hp turbo setup would have. Torque is the issue. If it's properly tuned 400hp (which will be low/mid 300's tq) would be perfectly find for that engine. The only problems you would encounter is if the tune sucks.
Old Jun 18, 2010 | 09:29 AM
str8dum1's Avatar
str8dum1
the original setup with the 2.87 made 405wtrq on the dynodynamics, so close to 450DJ
Old Jun 18, 2010 | 09:34 AM
binder's Avatar
binder
your car was a freak of nature. i barely hit 360 tq dd when i was at 451 hp dd
i guess the lower compression on mine could be the cause since it's a built engine though.
Old Jun 18, 2010 | 09:45 AM
wizard's Avatar
wizard
Thanks for replying Binder...
I have the 2.87 as part of the kit, but my tuner (who posted earlier) isn't too comfortable with running it with this size pulley. In terms of engine life, if I run the 2.87, would it half it? Or is it safe for low boost run? It's the torque that kills the engine right? So will it be fine to run?
Old Jun 18, 2010 | 10:45 AM
Erdem's Avatar
Erdem
did you book a date, for tuning yet?
Old Jun 19, 2010 | 12:02 AM
Erdem's Avatar
Erdem
what happened to the previous owner?
he sold the Vortech kit pretty quick.. it's not even 6 months since he got it tuned?
Old Jun 19, 2010 | 11:22 AM
binder's Avatar
binder
reliability is in the tune. If it's tuned in safe parameters there is nothing that says it won't last as long as any other tune. There isn't a direct correlation. Truthfully i think rich had his tapped out for a lot of power. His was way more than the standard 2.87 tune. Something with his setup worked well i guess. My stock engine 2.87 tune wasn't near close to what his was for power and i didn't once worry about my engine life being an issue.
Either way, do what your tuner thinks is safe. There are tons of cars that have plenty of enigne life and no problems with a 2.87.
Old Aug 8, 2010 | 02:14 PM
wizard's Avatar
wizard
Some lovely parts arrived FINALLY!
Big thanks to Adam @ Z1 for some of this stuff. Chilli Red for the rest of the goods!
Apologies for the quality, they were taken with an iPhone.
First starting with the block that was wrapped like a mummy in a tomb!
Unwrapped
Used block, but quite clean
Getting onto the Vortech kit. Here's the intercooler:
Filter??
Bypass valve
Some lube!
Inchiba Y-pipe
AEM Boooooosssttt gauge!
AEM Wideband AF/R
3:12 Pulley
CJ Fuel Return system
Walbro 255 Fuel pump
Mmmmm K&N Oil Filter
And the most important part. Blower... MUCH bigger then I thought it would be. Tried to take a pic with my face next to it for a comparison...
_________________
Oh yes, one more, the Shine Auto (Nismo v2 style bumper):
Project is due to start tomorrow. Will try and post progress pics then...
Old Aug 8, 2010 | 07:45 PM
- bigc -'s Avatar
- bigc -
you're not gonna want to have this pic hanging around the interwebs...
Old Aug 11, 2010 | 06:03 AM
wizard's Avatar
wizard
Some more pics as the project progresses:
Front bumper off, accident bar off, headlights out...
coolant draining
Hole in the sump!
Another pic of the hole
Coolant and A/C unit drained
Old Aug 11, 2010 | 05:20 PM
djtimodj's Avatar
djtimodj
Dam ray did not know you put a hole in your sump! GL with the build mate.
Old Aug 15, 2010 | 05:15 AM
  #38
wizard's Avatar
wizard
Right so for anyone else still reading, some more updates on progress.
Luckily for me this project has progressed rather quickly.
Some more pics of where I am with this.
Crane for engine removal
Blower fitted
2.87 pulley removal
Engine, supercharger fitted, 3:12 pulley fitted, belt tightened. Apologies for dirty engine bay, I promise I'll clean it.. one day
Old cats and Y-pipe removed
Berk test pipes and Inchiba Y-pipe fitted
Pic to see how the 5Zigen fits into this
_____________________________________
Managed to fire her up and everything seemed to be running fine, but when I plugged in my computer, I managed to pull the P0300, MULTI CYL MISFIRE message from the ECU. I thought this could be due to the codes being stored from the last engine, so I cleared them and restarted the car but still got the same result.
I'm assuming this is something to do with the car running overly rich due to the 600cc injectors which have been installed? However when I turned off the cylinders one by one to check if they were firing properly, it appeared that cylinder 2 and 6 seemed weaker then the others (the revs weren't dropping as much with those cylinders). Anyone have any input on this?
Irrespective of this, I think the car will have to be trailored to my tuners workshop to stay on the safe side.
Things left to do are as follows:
- install af/r and boost gauges on a pillar gauge
- take out the nitrous kit and the rear wiper stalk
- take out the hks sld. Uprev should be able to de-restict?
Bodyshop work:
- spray front bumper and canards
- respray bonnet
- check both canards on front of car and make decision
- spray rear spats and fit
- re-install front bumper
More updates with pics to follow. Car due in for mapping on the 24th August.
Old Aug 15, 2010 | 03:09 PM
  #39
350Z_Al's Avatar
350Z_Al
Looking good, thanks for the inspiration! I'm at the parts collecting stage of my build. It should start once the car gets parked for the winter in about 2 months
Old Aug 15, 2010 | 07:32 PM
  #40
whitez33350ztt's Avatar
whitez33350ztt
nice setup ... if ur doingn the 3.12 u should be right around 400 to 420 whp on a dyno jet dyno.. i have an 03 with full bolt ons and cams with the stock 3.33 pulley and made 392 whp. so u should have no problem meeting ur power and should be very reliable as long as ur tune is good. i also used the uprev as my ems ,good luck
