FS: New Stage 4 Cyl Heads w/ Cams, New Sleeved Bare Block
Old Aug 7, 2011 | 02:22 PM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
Default New Stage 4 Cyl Heads w/ Cams, New Sleeved Bare Block
I had a spare motor that I was building for the drag car but no longer need it so have the following parts up for sale:
Brand New Darton Sleeves installed in a low mileage block. The sleeves have been installed and decked. You will need to have the cylinders bored/honed to match the size piston you are going to use 96mm-100mm. Will also need to be align honed after studs are installed. This is all normal during an engine build (Dynosty can do so if you would like them to build it).
Normal Price $2,995 plus core charge, Selling this one for $2,000 no core needed.
Stage 4 Cylinder Heads (ready to install) with full Brian Crower Valvetrain:
Ported and Polished - 5 Angle Valve Job
+1mm Intake and Exhaust Valves
Springs and Retainer Kit
New OEM Valve Seals
Stage 3 BC Camshafts
Valve Buckets have been adjusted to Camshafts
Normal Price $4,495 plus core ($750), selling this pair for $2,800 no core required
Old Aug 7, 2011 | 02:42 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
had you posted the heads a yr ago before I swapped my motor in I would have considered them. Especially for what I paid for my stage 2 cams..
BTW, have you guys heard anything more about the haltech IO box? Can wait to upgrade my setup to the IO box and while I am at it..an external map sensor.
Old Aug 7, 2011 | 02:52 PM
jerryd87's Avatar
jerryd87
ohhhhh if i dint have to pay sasha 2k on the 14th lol
Old Aug 8, 2011 | 07:16 AM
getnsidewayz's Avatar
getnsidewayz
sending u PM sir
Old Aug 11, 2011 | 06:21 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Are the heads rev-up or non?
Old Aug 11, 2011 | 08:20 PM
InjectedPerf
Revup Heads with BC Stage 3 Non Revup Cams. Revup Heads can be used on any VQ35DE block (model years 2003-2006) with the included block off plates. We have done this many times with excellent results.
Old Aug 21, 2011 | 11:37 AM
InjectedPerf
Still for sale. The port work and cams alone are worth over $2,000, not including the valve train and cylinder heads.
Old Aug 23, 2011 | 07:26 AM
black556's Avatar
black556
sent you a pm
Old Aug 24, 2011 | 05:11 PM
InjectedPerf
Cylinder Heads sold. Sleeved Block still available. $1,800 for the block.
Old Sep 2, 2011 | 11:07 AM
binder's Avatar
binder
greg, you are just giving **** away these days aren't you?
those are retarded prices!!
Old Sep 2, 2011 | 03:43 PM
InjectedPerf
Jeff, you don't even want to know. I am selling a big race motor, double sleeved, billet bottom girdle, dry sump, L19 main studs/head studs, etc. cost over $29,000 and letting it go for less than half, never ran or anything.
Magnetti Marrelli ECU with pectel engine harness, coils, data logging, cost over $16,000, would sell for $7k. Just don't have any use for this stuff anymore.
Old Sep 3, 2011 | 07:36 AM
binder's Avatar
binder
wow
Old Sep 3, 2011 | 01:01 PM
str8dum1's Avatar
str8dum1
that race motor sounds sick. whats the displacement?
Old Sep 6, 2011 | 09:08 AM
InjectedPerf
I believe it is a 3.6 or 3.7. More for higher revving. It is the same motor that VTR, Carl Stephens, etc have used in their full out drag cars. Comes with a Nismo crank, 280 cams, ported and polished heads, Ferrea valve train, cnc dry sump girdle with integrated main caps, Peterson oiling system, ATI pulley, aluminum or Carrillo rods, etc, etc.
Old Sep 6, 2011 | 08:43 PM
maximariceboi's Avatar
maximariceboi
Sick deal. Glws.
Old Sep 19, 2011 | 07:50 AM
InjectedPerf
Sleeved block is still available as is the big race dry sump motor. Sleeved block $1,800 obo.
Old Sep 29, 2011 | 02:23 PM
qmoney06's Avatar
qmoney06
I want that block so bad but can't throwdown that much for one right now. My rings are going bad on my 04 G35 block so I am looking to do some upgrades.
Old Oct 8, 2011 | 06:37 PM
MDK's Avatar
MDK
Goddamnit why did i have to see this
MM'08_350Z
Apr 22, 2021 09:42 PM
Workshop12
Mar 23, 2020 01:45 PM
cashmoney03
Sep 27, 2015 05:24 PM
foxsmp26
Sep 25, 2015 09:48 AM
