370Z Brakes & Suspension 370Z stoppers, coils, shocks/dampers
Rear sway bar measurements?
Old 09-24-2015, 04:12 PM
hulkout
hulkout's Avatar
Default Rear sway bar measurements?
Hey guys. I have a 350z with a rubbing true dual exhaust. Worse yet I need to get it upgraded to 3". I would love if the rear sway from a 370 would fit, because clearing it with a custom exhaust could be done with ease. I realize Motordyne has a rear sway that's supposed to increase clearance, but I would like to review this option as well.
Would anyone be willing to measure important dimensions on their rear sway bar for me?
My rough measurements:
38 3/8" end link to end link
33 1/2" bushing to bushing (measured at outsides of bushings)
1 9/16" bushing width
Not sure what else to measure. :\
Old 09-24-2015, 04:36 PM
Received 3,263 Likes on 2,321 Posts
Originally Posted by hulkout
Hey guys. I have a 350z with a rubbing true dual exhaust. Worse yet I need to get it upgraded to 3". I would love if the rear sway from a 370 would fit, because clearing it with a custom exhaust with ease. I realize Motordyne has a rear sway that's supposed to increase clearance, but I would like to review this option as well.
Hotchkis 3-hole adjustable: 15/16", 23.8mm - However, depending on attack angle (which of 3 holes you use), such rotation my still interfere.
Me personally, I'd rework the exhaust a bit (after choosing sway bar setup) rather than compromising on a sway bar based on exhaust clearance. But that's my preference/priority. Handling over moderate power increase.
Mic
Old 09-24-2015, 04:41 PM
hulkout
hulkout's Avatar
Mic
I am exactly opposite. I have a built engine, twin turbos, ect, last dyno 620.5 whp. Totally stock suspension. Hey, I'm working on it. . I would be after a good aftermarket 370z sway bar. But I'd like to know if it physically fits.
Old 09-24-2015, 04:51 PM
Received 9,060 Likes on 6,523 Posts
motordyne sways, they dip down more to accommodate larger diameter exhausts IE tdx2
Old 09-24-2015, 04:58 PM
hulkout
hulkout's Avatar
Yes I know; and Its an option. However, I would like to review this option as well.
If someone could please measure I'd appreciate it!
Old 10-22-2015, 07:26 PM
Received 2,296 Likes on 1,653 Posts
Considering the sub frames are interchangeable between a 350z and 370 , and the only the traction arm is slightly longer. I bet it's the same bar
Old 05-22-2016, 02:30 PM
hulkout
hulkout's Avatar
I finally got around to trying this today with a stock 370z rear sway bar. The bar physically fits just fine. I even reused the end links from the 350z. There's a small lip on the bottom of the 370z sway bar bushings that isn't there on the 350z bushings that needs to be cut off. You have to use the 370z bushings because the 350z bar is smaller. I was able to reuse the bushing brackets after spreading them a little. My custom exhaust didn't fit with the new bar so I had to Put the stock bar back. But I'm thinking TD 3" anyway.
Old 04-28-2017, 09:00 PM
hulkout
hulkout's Avatar
Not the best pic but it's on. I didn't cut off any of the bushing like I mentioned. I just smashed it down. I doubt it'll go anywhere. This is a bolt on mod. I have seen some other people trying this lately with success. But just to be clear the 370z/g37 rear sway bar is a bolt on mod for the 350z. And probably the g35.
Lt_Ballzacki
08-06-2021 06:19 AM
04-04-2016 07:52 AM
Quick Reply: Rear sway bar measurements?
