Extremely low oil pressure 2003 Enthusiast 151k
I have anothing 03 Enthusiast with 151k miles. When I cold start the car, the oil pressure is at about 60 at an idle. Once it's warmed up, it sticks around 30 and then after driving for about 10-15 minutes, idle pressure is under 15. It knocks a little bit with the A/C off and the oil light comes on. Would this be a bad oil pump? I've read that an overrev incident can cause damage to the oil pumps on VQ35DE's, but ive had the car for 2 months and it wasn't me that caused it. I've also noticed a slight rattling at Redline, which seems to tell me it is an oil pump. Can anyone confirm or help me out?
Haha, +1 today. I noticed the same thing on my 07 Nismo. HELP!!!!
At cold startup, i'm at 90psi @ 1800-1900 RPMS
Warms up and drops to a bit below 30psi at idle
Went for a drive and after a couple miles, it drops below 10 PSI.
I called Z1 motorsports to buy a new sending unit, one of the tech guys said it is the gallery gasket. It will start to do this when failing and absolutely recommended to stop driving. After research, I guess it was a paper gasket that will slowly start to leak. These guys have a steel reinforced one:
http://www.nisformance.com/EPS-Tunin...rykitrwdhr.htm
Anyone else have to find out that they needed to replace a "Gallery Gasket"?
Any "How-to's" for replacing this?
I know, and a Google,search shows the 2 terms used interchangeably. But I've always heard galley from the machinists I've known over the last 40+ years and working on my Alfa engines. Either way, looks like a ***** to get to that gasket, so I hope that is really your problem.
Thanks for the reply!
Problem solved. It was the gallery gasket for sure. The top gasket was blown. Mechanic took some pictures and I'll post them tomorrow.
I picked everything up at Concept Z
Here is gasket parts list:
Timing Chain Cover Seal O-Ring
Part #: 15066-JA10A $8.36 Qty: 2
Nissan OEM Rear Timing Cover Oil Gallery Gasket, Upper Large
Part #: 13533-JK21A $30.10 Qty: 1
Nissan OEM Rear Timing Cover Oil Gallery Gasket, Lower Small - Nissan 350Z 07-08 VQ35HR Z33
Part #: 13533-JK21B $4.70 Qty: 1
Nissan OEM 13042-3HD0A Intake Camshaft VTC Seal
Part #: 13042-3HD0A $34.92 Qty: 6
Nissan OEM 13510-31U10 Front Crankshaft Oil Seal
Part #: 13510-31U10 $10.74 Qty: 1
Nissan OEM VTC Variable Timing Control Solenoid Gasket RH
Part #: 23797-EY01A $4.20 Qty: 1
Nissan OEM VTC Solenoid Cover Gasket
Part #: 23797-JA10B $3.30 Qty: 1
Subtotal: $96.32
Shipping (Ground): $14.64
Total: $110.96
Extras:
Replaced all tensioners and chain guides (less than $200.00)
Labor was for 8 hours @83.00 an hour
I went a tad above 1,000 with cleanup/dispose fees, new oil + filter. 1/3rd the price from Satin (Nissan).
Subtotal: $96.32
Total: $110.96
Extras:
1k for a 14 dollar gasket replacement :-(
Yeah... Tell me about it. I have a lift and all the tools, but just no time. 10 years ago in my early 20's I would have bought a case of beer and bang out the job after beer 22. I work 14 hours a day, wife, and a 3 year old. I'm lucky to just have the Z...lol! I had to sell my 03 track a few years ago when our son was born
One thing I did not like from the local Nissan dealership was that they would not just take the front timing cover and replace the gasket, even though I gave them the part numbers. The only route they would take is replacing all the covers (rear, left and right cam covers). I think they quoted me just shy $3,100
My nismo has 47,500 miles... i believe the throw out bearing is making some noises now. Clutch replacement coming soon i think. I did a 5th gear hill pull and it took it like a champ, no slipping.
I wonder if the T.O.B noise is also part of the 1000 problems the Z's have... LOL!
