oil totally emptied all over floor
Hi guys new member
Im posting because my 03 350z with 98k miles is having an issue. I just brought home my car from the mechanic yesterday where it passed inspection and I got an oil change done.
I took the car out this morning for a joy ride for about an hour. It drove good and oil gauge was normal. I brought the car home and an hour later I took the car back out and drove it up my street only to realize the oil light was on with 0 oil pressure. So I turned and drove it back down my street where I realized that all the oil is all over my garage floor and driveway. What happened? My shop doesn't open until Monday so I thought id post here and see if you guys might know what it is. The engine is also louder and making more clicking noises but I figured that's probably because the oil is totally empty and its running dry
I just had my car pass inspection yesterday AND an oil change so im wondering if they put the wrong oil in or something? im semi joking but I mean seriously ive never had a problem with this car then all of a sudden I get an oil change done and have an oil issue not even 24 hours later. Its kindve fishy to me. But im not a mechanic
Welcome- this could be a serious issue. Anytime you find the oil pressure light is on means you should shut off the car right away. By continuing to run your VQ, you may have damaged the rod or main bearings, which is why you're hearing those sounds. If oil is all over the floor, the shop may not have secured the drain plug or oil filter properly. You can easily check this by jacking up your Z and looking at those parts. You might want to inspect it before you call the shop Monday.
I’ve had this happen before when I took my old VW for a oil change at a quick lube place. They didn’t secure the drain plug all the way and my oil spilled out. My oil light came on but i was able to turn it off right after the oil light came on. Took it back to the shop by having it towed and it was bone dry. They claimed no damage was done but I heard noises like you’re describing. Needless to say I sold the car a couple months later for piece of mind.
Climb under check the plug and oil filter... hopefully
it didn’t damage the car either way I would not be happy when I called that shop... good luck getting them to take blame if something is messed up now. Go get 5 quarts of some oil after u check those things and never return to that shop.
Oil filter not tighten or drain plug like others have stated. Do not drive the car, check drain plug and oil filter to see if it has been tighten to spec (watch a few youtube videos to learn how), refill with new oil. No one touches my car except me, this is the exact reason why.
Have you looked where it’s coming from?
this and take lots of pictures...
I hypothesize that they didnt tighten the filter or plug 100% and it vibrated loose during your hour long cruise but you didnt lose enough oil to damage the engine at that point. But as soon as you parked it, oil dripped out over night just a tiny tiny tiny stream and by the time you started and drove the car it drained enough.
I'll venture to say that the engine is toasted and you'll be replacing the engine. I dont think you can run a car but a minute or two without oil - too much friction and too much heat and if youre hearing bad/unnatural engine sounds it's already too late.
I would park the car (and NOT add oil)until you can contact the shop and get resolution from them. They might fess up and cover the rebuild/replacement, they might say it's on you.
totally agree ... when I do have to give it to a shop (for instance, an alignment, and I understand not everyone can do this) I load a 'valet mode' map with no boost control solenoid influence and I set my rev-limiter to 3500rpm.
how long did you drive the car (time and distance) with no oil / oil pressure at 0psi??
The oil drain plug or more likely (imo) the oil filter gasket. I've seen a few times where the old gasket is sort of stuck to the mating surface and doesn't get removed. Eventually the pressure blows apart those two pieces of rubber.
I bet adding a quart may show the leak really quick. My bet is oil plug was hand tight, and is not there now.
Btw, post dog pics
Btw, post dog pics
When I had my issue the guy fessed up. It was his first week but I told them not to fire him because everyone messes up. It’s not like someone died from his mistake. I got lucky that I shut the engine off right after the light came on though.
You would think the OP would come back here, review all the excellent feedback provided, and give an update on this major issue with his vehicle...
I had this happen after an oil change when the filter gasket failed on a FRAM filter (vehicle was a BMW 320i).
How did your bimmer fare in similar circumstances?
This was back in 1991 or so - I had changed the oil, took a short drive to work and when I came out from work I noticed the pool of oil. So, it likely happened on the drive and finished spilling out when I parked or as it sat. The rubber gasket on the filter had failed and oil passed out around it (the filter had been sufficiently tightened).
I was able to replace the filter, top off the oil and then get back to the house to clean everything up. Luckily, there was no damage and the vehicle was driven for several years still before the body rusted away too much to keep using the car (darn recycled-steel experimentation of the early 80's - the thing rusted in the middle of panels with no source to the start of the rot).
Op here,
Sorry it took me so long to provide an update. My gf just got home from a business trip so I was spending time with her and trying not to stress out about my car.
I don't have anything to jack my car up onto so I didn't personally check the drain plug. Those are on my to buy list though because from here on out im doing my own oil changes. I called the mechanic and they agreed to fix whatever was wrong so instead of paying a tow truck $100 to tow my car 2 blocks away I instead just poured 5 quarts more oil in my car and drove it to the shop. I figured since it took all night to drain last time I should be ok especially because The shop is very close literally 2 blocks away. By the time I got there though my oil was empty again already so I regretted driving it there. Pulling up to the shop becaue it was out again my engine was making some sounds that I can only describe as scraping and grinding. But it was only for a few seconds. Hopefully I didn't screw up.
They said it was the oil washer which I think someone mentioned above. When I drove the car home the engine sounded fine but like I said that was only a couple blocks. Im going to take it out tonight and take it through the rev ranges and drive it hard and see what happens.
Heres some pics of my car and also a pic of my dog because someone asked for one. Hes 4 months old. Thanks everyone for your help I appreciate it
I still really wont feel out of the woods until I take the car out tonight for some fun. But even after that ill need a few months to prove to myself my engine didn't sustain serious damage
I haven't run a crush washer in a decade - I think it wasn't tightened. Hats off to the shop for backing their work. Happy the everything is intact. On your ensuing test drive did the engine sound normal?
I almost re-home'd a 18month year old Shepherd ... but it sounds like he has anxiety and loneliness issues and they'd only be perpetuated with my work schedule. I hope he finds a good home!
I’ve replaced my crush washer once in 160k miles
great looking long coat GSD
