Converting a Mig To a Scratch start Tig
Old 09-21-2018, 04:31 PM
Subd
Subd's Avatar
Default Converting a Mig To a Scratch start Tig
seen a video with a guy running a tig torch off a mig welder while back, been using the tig torch on my mig for awhile now, its scratch start, but it works, thought id posts some pictures of how to set it up, for those interested, haven't seen anyone show how to do it on any website,
tig torch with separate gas line
used vise crips to hold the dinse while I pulled the sleeve off the connector
take the bolt off that holds the dinse connector to the wire
put the plug on and crimp it,
hook up the gas line
hook the tig torch to DC- don't forget to hook up your ground clamp here its not shown plugged in,
you have to hook up your mig gun but don't put any wire into it just disable the wire
I used a clamp on the trigger, dial in your volts and start to tig weld
Old 09-21-2018, 05:37 PM
bealljk
bealljk's Avatar
interesting ... TIG DC only??
Old 09-21-2018, 06:54 PM
Subd
Subd's Avatar
dc only you can weld aluminium but looks bad
Old 09-21-2018, 11:04 PM
bealljk
bealljk's Avatar
A old buddy said one can weld aluminum using DC if the material is cleaner than clean ...
Old 09-21-2018, 11:44 PM
Subd
Subd's Avatar
its so annoying when people say "it can't be done" or "it won't work" if you google converting a mig to tig, so many forums with people saying why it can't be done, but obviously it can be done, I never thought of the idea of hooking up a tig torch to a mig someone else did, I seen it and I thought wow I can save money that was my first thought,
but that person hats off for creativity,
pertaining to your statement about welding aluminium with dc, "it can't be done" or "it won't work" I bet It can be done and look good, by the right person then he can make a video of how to do it so I can learn,
Old 12-28-2018, 09:59 PM
Prius1Sentra0
Prius1Sentra0's Avatar
Hi! DC Aluminum tig welding can absolutely be done. HOWEVER. It depends greatly on the series of aluminum, tungsten selection and obviously shielding gas. As we all know, most series of aluminum can't actually be welded, but I'm sure the OP knows his material. Also, DC will work but it won't have as good penetration as AC does, nor will it be as clean a weld or as easy a puddle to control. Awesome job with the adaptation of the MIG machine, post yer welds!
fairtex
Cleaning & Detailing
03-01-2007 04:20 PM
G352NV
01-30-2006 09:37 PM
Quick Reply: Converting a Mig To a Scratch start Tig
